any problems with 99 E55?
However, I'd like to hear from everyone out there who owns one or used to own/drive one:
What kind of inherent problems are there for the 99 E55?
I have C320 01 model and am pleased with the multifunction steering wheel, COMAND, and BiXenons..I am afraid that I will miss all of these...
but...the gain in HP may make me forget about all these nice features..
please list any problems/concerns you have with 99 E55..
thanks in advance..
Considering the little problems here and there with the new Benz, I am just worried to get an E55 without factory warranty..
any thoughts??
just curious when you said freshened bodywork and build quality:
could you explain more?
based on JD Power Ratings, the 99 seems to be better than 00 (in terms of long term tests), correct me if I am wrong..
Just take your time until you find exactly what you want!
if not, do you know of anyone who is thinking to sell their E55?
thanks for the input as well.
piccofly@yahoo.com
Had to replace driver-side headrest motor - under warranty
Had to replace catalytic converters due to interior deterioration - under warranty
"Check engine" lighting due to problem in fuel sender (not major issue, really) ~$500.
Wear items:
Had to replace brake pad and rotors - not a big deal, but be aware, if you're a bargain hunter/on a budget, a brake job for this beast is ~$1300. Be sure you check out the brakes on any used veh., as you don't want to spend thousands off the bat.
Had to replace tires - again, not a big deal, but a full set costs ~$1000 for anything decent. Snow tires are a must if it snows in your area, ~$800, then about $100 to change them each season, unless you buy new rims as well at about $1000.
Driver side-leather seat has apparently burned a hole through from the heated seat element. I have not had this looked at yet, but I plan to ***** up a storm on this one - no heating element should burn through the seat!
Leather gearshift knob - The dog chewed it. $30 (ebay)
It is the most reliable veh I have owned, and at 50000 mi, these are typical items I would expect (except for the gear shift :-). Overall the car is fast, comfortable, and prestigious. At the prices used ones are going for, I would go for it. The extra few options with the 2000MY may be worth it, if it's within a few thousand or so. Starmark is definately preferred as repairs can be pricey. Don't underestimate the cost of maintaining this car - It was a bit of a surprise to me (an oil change/checkup at the dealer is $200).
that's my concern to buy 99 model without a warranty since it would be very costly and realizing how finicky and perfectionist I am in terms of car.. (dealer visit is regular)
FYI....there is a 2001 E55 on Ebay with 47k for $38k. Not a bad deal.
thanks much for the extensive overview of your E55..i really appreciate it..
