Lower your E55 by 20mm/ 0.8" for 80 cents!
Old Dec 13, 2008 | 10:26 PM
  #126
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
the car doesn't monitor ride height...it simply reads a voltage whether it's stock or lowered (fooled) by washers, links, or elm.
i'll believe you about the handling since i don't believe my car can handle to begin with.
Old Dec 13, 2008 | 10:45 PM
  #127
jangy's Avatar
2015 S212
Slow down. You are making my point for me. Lets drop the ELM one for now, since it is a digital platform that is deeper than the washers.
The voltage is only the signal that the computer looks for. So, you can have an OEM car and a washer lowered car sitting side by side and both will read the same voltage (i.e. the computer in both thinks the same thing). That is actually my point. Once you start adding weight transfer dynamics, why would it be so silly of me to say that the washered car will NOT act as it was designed? Either way, I'm done. I've played with it for years and even wasted a few shocks along the way. If people wanna use washers, more power to them.
Just put a set of rears in the front and it will at least hold a curve. In the end, we all drive a boat.....
Old Dec 13, 2008 | 10:46 PM
  #128
chiromikey's Avatar
Originally Posted by jangy
...In the end, we all drive a boat.....
amen!
Old Dec 14, 2008 | 12:43 AM
  #129
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
from what i have been told by shops and mb dealers that installed elms and links, is that all of them do the same thing. they fool the computer into thinking it's at a diffferent height by modifying the voltage signals going to it. IMHO paying a 1000$ for that is weaksauce, i do see the option that puts a display in your car and lets you raise the car and lower without fiddling with the module useful. in the end washers are cheap, reversible, i used locktite for a peace of mind. i am planning on a elm with a control but there are things i wanted before it (tune, pulley, wheels, TB, replace shotty audio system) and the washers are temp hack/fix
Old Dec 14, 2008 | 12:54 AM
  #130
jangy's Avatar
2015 S212
Not even close. AGAIN!!!! God, I wish those that cared paid attention. Links and washers DO NOT modify the voltage. they move the sensor so that it must shift to maintain its happy voltage. In the end, the car thinks the car is at stock height but it isn't.
It all comes to this. are you dropping it for looks or performance? If performance and you are using washers, then check yourself because either you are actually shallow ro are making a huge mistake.
Old Dec 14, 2008 | 01:29 AM
  #131
prodigymb's Avatar
washers and links physically fool the sensor to make the control module lower the car, but how does that happen? voltage ! car gets a higher reading than it should "thinks" it's too high and lowers it self. modules do the same thing, except isntead of physcially moving the sensor they alter the sensors' voltage signal that are sent to the ecu to once again make the car think it's higher and lower it self.....that is why you have to tap into all 3 sensors.
i am not shallow but i won't easily fall for manufacturers claims about ELMs.
hook your car up to dealer star on a MB allignment rack and check the voltage readouts of sensors on your car, measure the height from ground to fender, disconnect ELM, lower the car using star to that same exact height, compare voltage values and they will be different. because once you disconnect star you will get car to low message and it will raise back up.
how are the cars with modules able to bypass the "car too low" message, i would assume it's because the car doesnt "know" it's too low?
and my car is lowered for the sex appeal hehe. in my opinion this car has absolutely NO potential to handle well and the lack of available aftermarket components (sway bars, braces, tower bars etc) doesnt help ....not to mention that it weighs over 4000 pounds.
Old Dec 24, 2008 | 08:37 AM
  #132
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
Originally Posted by Vic55
I have heard horror stories about washer lowering on airmatics. The washer doesnt allow the bolt to lock on and in the end the bolt comes off and your suspension drops to the ground. My buddy did this and he heard about this issue and made the change just in time. The bolt was loose and it if came off the entire assembly would have failed. This type of lowering have been around for a while and there is a reason why its not so popular.
Ever heard of loctite
Old Feb 11, 2009 | 11:40 PM
  #133
RenntechE55's Avatar
CLS55 AMG 030
ok so i dont have my car in front of me but been reading this for a bit now and wondering if i can take the bolt that holds the sensor and switch it to a longer bolt so more thread is exposed so the nut is not at the end of the bolt for more safety. I'll be looking tomorrow so i have a more clear understanding of the sensor.
Old Feb 11, 2009 | 11:59 PM
  #134
bassn_07's Avatar
2006 E55 AMG
The blue stuff works well.
Old Feb 12, 2009 | 01:56 PM
  #135
John V.'s Avatar
Former Vendor of MBWorld
2007 CLK63 Cab
I actually started my business with this thread. After reading it and playing around with my CL back in the day.
The washer method does work for the front if you just wanna lower it a bit. Any more and you have to pop the sensor bracket off, grind the old bolt off cause its welded on to it and then replace it with a longer 1. With that you can put more washers on and still have lots of thread so the bolt wont come off. Now the hard part, rear. On all Mercedes you have to shorten the Link to lower it. Was just looking threw my computer but couldn't find any pics of how I did it. Was really M.M. Ended up unbolting the stud that the link attaches to, attaching a metal strap to the bracket with nylon bolts and then put the stud on the other end of the strap. Would use about a 1" strap. Leaving the bolt just snug on there for now would alllow the sensor arm to hang down and spin 180 dergress. After doing that the level was way off. Had to move the car a bit and then reach underneth to pivot the sensor arm to get the height I wanted.
All in all the method did work but........... just took way too long. To do the whole process would take almost 4 hrs. Now you can see why I invented the my Fully Adjustable Lowering Links. Can literally lower the car in 20 min and return it back to stock, totally indetected, just as fast.
Old Feb 12, 2009 | 10:33 PM
  #136
III II I I AMG's Avatar
2003 e55
what exactly is this kit that you invented and how does it work
Old Feb 13, 2009 | 02:50 AM
  #137
John V.'s Avatar
2007 CLK63 Cab
Check out my site to help you understand better. There are pictures of each Lowering Kit for each vehicle I can do in the gallery section.
Old Feb 13, 2009 | 09:00 AM
  #138
CLS55 AMG 030
I did the washer lowering yesterday only used 3.2mm of washers to lower and used red lock tight there was still thread at top of the bold i think it looks a lot better
Old Feb 13, 2009 | 11:40 AM
  #139
jangy's Avatar
2015 S212
Guys!!
We have two topics that anyone wanting to lower an Airmatic car needs to be clear on.
One is if the ELNs "work" better than mechanical sensor adjustment (washers or links). Some say the ELNs are critical (myself included) and some say it is the same (those that don't run ELNs). Make up your own mind. The difference is in handling for me.
Second, and MOST important, is using washers with the current bolt. I am seeing more and more loctite threads. Do you guys not understand the design of that nut and bolt? The nut is OVAL and the bolt is taperred off. Can you put a small washer in and still be able to TQ down the nut? Yes, but it can rip loose. It is not caused by the vibrations but by a jarring (potholes) incident. Loctite will do NOTHING in that case.
If you choose to modify your links (washers, etc.) PLEASE do it safely and don't just make assumptions based on this thread.
Old Feb 13, 2009 | 12:22 PM
  #140
liquiddi's Avatar
2009 E63 AMG
I used the blue loctite and 3 washers on each side and I have been good to go for a month now. It's a neat little cheap trick. I like it.
Old Mar 22, 2009 | 09:17 PM
  #141
JoeVal's Avatar
C350 Elegance
My 2 cents: a) There are precision washers at any industrial or automotive fasteners store. I'd use brass or aluminum, over stainless, just in case I have to grind them off.
b) I would also replace the bolt if, after the spacers are in place, it cannot engage past the top nut by at least one and 1/2 threads. Use a longer bolt with a tensile strength #7 or higher (just take the sample to the store or read the number or marks on the head).
c) Loctite is good, but make sure you use after you know you are happy with the setup. The blue when it cures will need a torch heat to loosen, and the red is no picnic either.
It all looks sound, specially since nobody had anything negative to report since 2003. Awesome wheels. enjoy them.
Old May 26, 2009 | 09:06 PM
  #142
jgdynamics's Avatar
E500,CLK500K, E55
nice, im going to try this mod on my cousins 05 e500 tomorrow... wish me luck,
Old Jun 2, 2009 | 08:36 AM
  #143
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
I just did my fronts the other day, and it was simple. I threw in four washers at first but decided to back it off to 3 because it was slammed a bit much for the wheels I have on the car.
To all the naysayers - I mean, really... you guys are making a mountain out of a mole hill. You're just spacing out a bolt on a non load bearing part, which in effect adjusts the suspension in the same manner a lowering module will. The only difference is that you're making the change manually instead of electronically. As long as the installer is smart enough to thread and tighten down the nut so it doesn't just fall off while driving, then it'll be fine. It's so easy a caveman could do it.
Old Jun 2, 2009 | 04:44 PM
  #144
efivefiveamg's Avatar
2004 E55
Anyone know a good place (or anyone want to personally help me) in Irvine to get this done to my E55? I'm only looking for a very modest drop front and rear.
Old Aug 20, 2009 | 10:59 PM
  #145
Triple.Sevens's Avatar
2005 SL500
Best. mod. evar. Took 30 minutes all I needed was a jack! Now on to the rears.
Old Aug 21, 2009 | 01:18 AM
  #146
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
why not using STAR ?
i didn't lowerd my car
but most of my friend did it using STAr and they are satisified. no problems or anything and the shop do it for them sor about $50 only.
3 settings will be changed.
i think using STAR easier and safer
unless you have other thoughts.
Old Aug 21, 2009 | 02:48 AM
  #147
2005 SL500
You clearly haven't tried it, you'll be so upset that you spent the extra money when you find out how simple the concept is. Of course I'm the kind of guy that changes his own oil so...
Old Aug 21, 2009 | 02:57 AM
  #148
Ali_E55's Avatar
i like to do things alone
but i don't have STAR
i feel the ride is nice when im in their cars.
i don't think i will lower my car ^_^ i like to keep my car stock from outside
Old Aug 24, 2009 | 08:08 PM
  #149
B on my Benz's Avatar
E.FIDDY.FIVE AMG
hey, can you post pictures of your e55. I want to see them. Will this ruin the car at all??
Old Aug 25, 2009 | 12:34 AM
  #150
evoklr's Avatar
something that can use more power
On the front, I used a 5mm thick nut instead of a stack of washers in the front. Red Loctited the nut on top. The rear sensor bracket was lowered maybe 2mm by dremeling/extending the oem mounting hole. There is a tread of how to do it. Didnt think it would work, but it lowered the rear maybe an inch. Been this way for a year with no issues, rides the same as stock to me. I dont think an ELM can make it feel $1500 better, plus there is no reason to ever raise it up from this on a daily basis, if you do encounter a steep driveway, the normal raise button still works.
At least try it, its free!!
Lower your E55 by 20mm/ 0.8" for 80 cents!-img_2155.jpg
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
