Carlsson 19" 1/16 BE Wheels
Brilliant Edition?
I am in the process of ordering a set and am a little concerned that the rear wheel, which is 10" (11" / 280mm outside dimension) is too wide for the 275/30/19 PS2 and the 295/30/19 PS2 maybe too wide for the car, even with ET45 offset.
I would appreciate any advice, even if you have experience with other brands 19x10" rear wheels and tyres. I know that the 9.5" wheels with 275/30/19 tyres are more common.
Go with HRE...that's what I'm doing
~ Ian
Who did you talk to? Call 305-715-0000 and maybe you need to reconfirm.
Brilliant Edition?
285's and 295's are too wide... just because of the shoulder.
Lastly, you can run an aggressive 28mm offset on a 19x10 with 275/30-19 Michelin PS2 tires - WITHOUT fender rolling.
Brilliant Edition?
you've got wrong information! Carlsson 1/16 UL 8.5 + 10x19' will fit to W211 E55 AMG. In Germany 19' is the most common size of tuning wheels for your car. The recommended tire dimension is 245/35 for front and 285/30 for the rear. For me the forged 1/16 UL is the best wheel for E55 AMG, strong, very light (unsprung masses) and the design is extraordinary nice, you should go for it!
Best regards
Sauerkraut
We can be reached at 305-715-0000.
Kind regards,
Robert
Carlsson North America
Best regards
Sauerkraut
What offsets did you use on the front and rear? I heard that Carlsson only makes one offset, ET45 and then snaps on adaptors to suit each car to end up with 30, 35 etc.
