Ridiculously low W211 E55 trap speed. What's to blame, my car or the track?
Elevation is around 4000ft
Good luck.
To Enable -
1. Make sure temp is displayed on screen
2. Insert key into ignition
3. Turn key until dummy lights (all the extra lights on the dash) are on
4. Turn key until all lights are off
5. Turn key back to first click
6. Press mileage (reset) button on left-side of dash 3 times fast
7. Use page up/down keys on left-side of steering until "Dyno" is displayed on dash
8. use +/- keys to turn "on" dyno mode
9. Start engine with key
To Disable -
1. With car off, go to Dyno screen using page up/down keys on left-side of steering wheel
2. Turn key until dummy lights turn on
3. Change Dyno setting to off using +/- key
4. Turn off car
I took this off a video published and tried it this morning. Works well. Hope I didn't miss a step.
Good luck.
I am running Klee Stage 2...K&N's LSD AND Drag Rads and on a 65 degree partly cloudy day.....couldn't get er under 12.7.
Welcome to hell....elevation will play the role of Satan.
The only other advice I would give would be to try the SGC method....he ran close to 12 flat on Conti's with no LSD bone stock (just K&N's). He swears by the method of no power braking at all....just catch a good light and start from idle.....1/4 throttle to get the car over the initial inertia, then quickly yet smoothly get her down to the floor. I know most cars at the track BANG it right off the line...but hardly any over them are over 4100lbs, YET push 516ft lb torque right off the RPM bat.
Very hard to launch these beasts without LSD....good luck.
When you Drive from Johannesburg 6000ft) to Durban at the coast, 350miles, when you get there your car is 18% more powerful and feels fantastic.
At 4000 ft elevation you have lost 12% of combustible oxygen in the atmosphere, which shows in your times. Other cars at the track may have different fuel profiles to compensate for it.
Take your car to a better, lower (altitudinally) strip and see how it runs. I understand your disappointment. Don't feel so bad.
LSD is 1st on my mods list...then Wettraer 530 HP chip( cause its only costs 500 Euro here, compared to 2k euro in Germany)...With those mods I should be as fast a Brabus K8 kit which is also 530 Hp, LSD (40%) shortened rear axle...but Kleemann 60% is even better...Yes...
If timing the throttle with 1/4 1/2 full way down seems tricky, try setting in winter mode, power brake and floor it right from the start
PS hopefully you weren't running on more than a 1/4 fuel in the tank
