where is the fm antenna?
Old Jul 18, 2005 | 01:19 PM
sporters78's Avatar
2003 porsche 996tt Ruf, 2005 SL55 Renntech
My dealer tells me that my fm radio does not pick up stations too good because i have tinted the back window. is this bs or is there someway to move the antenna so that i can pick up more stations
Old Jul 18, 2005 | 04:36 PM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
No, it's not BS if you used a metalic based tint because it's in the window. If that's the case, get it re-tinted with a different material and the reception will come back.
Old Jul 18, 2005 | 10:07 PM
jangy's Avatar
2015 S212
I thought the radio antenna was that nub on the outside of the rear window?
Old Jul 18, 2005 | 10:11 PM
Can Drive 55's Avatar
2005 E55
I believe that is Tele Aid and maybe the cell phone antenna.
Old Jul 18, 2005 | 11:13 PM
benzmodz's Avatar
W203 slightly modified
The metallic lines inside the glass are the antenna. The amplifier is in the C-pillar and the wires run directly to it.
There is a set of solder joins where the inside wires meet the surface to copper wires.
So anything that goes on the glass will potentially alter the radio function.
Old Jul 19, 2005 | 11:33 AM
chem0's Avatar
2004 E55 AMG
So what other material would you guys recommend to get for nice tint and good reception?
Old Jul 19, 2005 | 04:13 PM
BklynBenz's Avatar
CL500
go with huper optik
Old Jul 20, 2005 | 08:15 AM
HarveyKorenzo's Avatar
99 Corvette, 04 BMW M3 (Wife's car), 04 Mercedes E55.
I've had the same problem with the radio and tint on a Lincoln... so this time with my E55 I went with LLumar non-metallic film. The radio works fine. I understand that the film may not last as long and might discolor after awhile so I'm prepared to have it re-tinted a few times if need be.
Old Jul 20, 2005 | 08:18 AM
LLumar window film is made by CP Films, Inc. Phone 540-627-3000.
