Higher stall converter
Old Sep 7, 2005 | 12:58 PM
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
I noticed that while folks are trying to get the best 1/4 mile times, the stall speed has not been brought up. I wonder if it would be possible to have a higher stall converter installed on the W211 E55.
Old Sep 7, 2005 | 01:18 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I am sure you could have a company make one, but the torque you would place on the drivetrain would be just unreal. Half shafts would be popping like corn.
I still can't believe there is a guy in the Northeast dropping his E55 from neutral to drive at higher r's. Wow...that is nuts.
Old Sep 7, 2005 | 01:20 PM
medici78's Avatar
Does anybody have the part number for the T/C? Maybe it is shared with other models. I was also thinking maybe a V6 T/C would have a higher stall speed and bolt in.
Old Sep 7, 2005 | 02:10 PM
E55AMG99's Avatar
1951 Caterpiller D6
The ECU and TCU need to know about too.
Old Sep 7, 2005 | 02:15 PM
vrus's Avatar
2003 E55 AMG
Interesting idea.. Personally I think it would create more shock to the drivetrain to have a higher stall.. Car already makes a tonne of torque down low.. Higher stall will just make it harder to launch on street tires.
I dont know if I would want to put that in the car as you will most likely shorten the life of the tranny.
Old Sep 7, 2005 | 02:27 PM
Grumpy666's Avatar
If you think you have traction problems now - wait 'till you install a higher-stall torque converter . . .
Most factory converters stall in the 1400 - 2000 RPM range. And the same converter will stall higher in a car that has more torque down low. If you hold the brakes and rev the engine on your E55, at what RPM point do the tires break loose?
The purpose of a higher stall is to get the engine into the beefier part of the torque curve curve sooner. There is actual torque multiplication occurring. Do you think the E55 needs this?
Putting a V6 converter in the Beast is a recipe for disaster. The internal vanes are designed for specific applications and can actually do damage if mismatched improperly. I would not recommend this.
Although the idea of higher stall is good, it would be more applicable to the E500 or similar car.
Old Sep 7, 2005 | 02:50 PM
medici78's Avatar
The only reason I thought of a V6 converter was the assumption the stall speed would be higher. Back in the day, I had a modified S10 converter on my '96 Impala SS with a head/cam package. It made a world of difference on that car.
Old Sep 7, 2005 | 03:08 PM
Grumpy666's Avatar
Yeah, that was a fairly common transplant back then. But don't you think that a 200+ rwhp Impala vs a V6 is a much closer match than the 400+ rwhp Beast vs a V6? Wait a minute - scratch that comparison - it's much better to compare the low-RPM torque numbers, which would make it much, much worse.
One other thought - modified converters usually means that the vanes are changed, which will affect how torque is coupled.
Old Sep 7, 2005 | 03:27 PM
medici78's Avatar
It was actually a 350rwhp Impala, which is why I invited the comparison. Stock Impalas pulled 230rwhp or so.
Old Sep 7, 2005 | 05:09 PM
AMGE's Avatar
04 E500 Brabus Wagon
stall converter option?
I think a higher stall on a S/C E55 would not yield the desired results unless additional efforts to significantly improve traction were also made.
Old Sep 7, 2005 | 07:01 PM
Grumpy666's Avatar
It was actually a 350rwhp Impala . . .
I promised to be kinder and gentler, so I won't comment on this.
OK - I lied: Not on an LT1 with only a head and cam package. Especially through the 700R4 tranny.
The LT1 in the mid 90's Impala was rated at 275 HP. And unlike current LS1 engines, that was a fairly accurate rating. I've seen 'em on chassis dynos near sea level huff and puff to get over 200 rwhp. Some wouldn't get there. With a 20% DT loss number, 350 at the wheels implies 440 at the crank. Nope - no way. The best head/cam package and still be a little streetable would give about 75 more. So that would give you 350 at the crank and maybe 275 at the wheels.
Old Sep 7, 2005 | 08:10 PM
Evolution Marine's Avatar
2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Thumbs up Good Conclusion !
The E55 does not need it's TORQUE multiplied any more than it already is. As AMGE says the E55,s traction is at or a little beyond what is manageable now. - Bob
Old Sep 7, 2005 | 08:32 PM
AmenMercedesGo's Avatar
2005 E55
I'll find it soon, but I recall someone on Dragtimes posting the use of a SL55 converter in their E55. For the SL it probably stalls higher to launch the heavy roadster.
Old Sep 7, 2005 | 08:52 PM
vraa's Avatar
The beauty of the E55 right now (and with all the guys modding theirs) is that they are still daily drivers.
By ramping up the stall speed, you remove that ability
Old Sep 7, 2005 | 09:01 PM
E55AMG99's Avatar
1951 Caterpiller D6
That was probably Jim Cannon's W210 E55 that he upgraded to W211 engine specs. AFAIK, the torque converters for K motors are all the same.
Old Sep 7, 2005 | 09:05 PM
WayneE's Avatar
'72 Suburban
If you want to get technical, it wasn't a 700R4 at that point, it was the 4L60E in the 94-96 Impalas.
A mild head/cam (duration @ .050 ~220-230 i/e)/header package on any LT1 engine would net you 330-360rwhp. I can show you examples, including dyno graphs (dyno from my head/cam/long tube LT1). The stock iron heads on the Impy really struggled, but once you swapped to aluminum heads (like the LT1/4 in the Corvette and F-bodies) they responded very well to mods.
Back to the original topic, I think that if you ran a sticky tire, you'd see huge gains going with a looser converter. But you do risk damage to other parts I'd check with tuners like Renntech to see if they have experimented with it in any of their cars.
Old Sep 7, 2005 | 09:06 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
These guys are nuts, aren't they? They're already driving one of the fastest cars in the world, and they want to turn it into an F1 killer..
I hope I never get that fanatical about Horses!
Old Sep 7, 2005 | 09:08 PM
vraa's Avatar
It's not a bad thing, I'm just saying...
BTW: I'm as obsessed as they are, because half the fun is having a problem.
Old Sep 7, 2005 | 09:10 PM
CE750's Avatar
I wouldn't turn down a CL65... don't get me wrong.. but.. anyway. I'm going to get an E55 at some point in the next couple of years.. maybe I'll be on here asking the same crap! :p
anyway.. sorry don't let me hi-jack the poor mans quest for Horses!
carry on...
Old Sep 7, 2005 | 09:47 PM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
If you want your E55 to kick like a mule, (before you snap the drive train like a matchstick) put it in NEUTRAL, rev to 3800 RPM (Neutral rev limiter), then shift into DRIVE, and you will never forget the experience! Then get out of the car and put all the bits left behind in the trunk. Now, wait for a tow truck...
Old Sep 7, 2005 | 10:13 PM
medici78's Avatar
I'm sure you already read WayneE's response to this post so all I will add is that my car also was upgraded to aluminum heads. These results are well documented and common for LT1's. Next time you call BS on someone, do a little bit of research.
Back on topic:
I dont think the weak link on our cars is the tranny. If the same tranny can handle the power of the 65 engines, I dont think a higher stall would do as much damage as folks think. However, I would like to know what experience people have had with breaking drivetrain parts besides the tranny on the W211 E55.
Old Sep 7, 2005 | 10:36 PM
Grumpy666's Avatar
Yes, thanks for the technical clarification. For others, the 4L60E is basically a 700R4 with computer control.
The reverse-flow LT1 heads replaced the L98 heads, which were the performance heads of the 80's, and offered a 20% intake flow improvement. They could easily support 400 HP on a properly modified engine. They proved to be a good interim design prior to the Vortecs.
My point was, and still is, you will not get 120 rwhp by adding a mild head and cam package to the Impala LT1. If that were the case, you could take this 4000 pound car that runs mid 15's at low 90's mph in stock trim and have it run in 112 mph range. That's the low end of what a stock E55 does. Think about it.
Old Sep 8, 2005 | 01:07 AM
medici78's Avatar
I looked at my dyno sheetand found out it only made 321rwhp. Baseline dyno was 223rwhp. My mistake. However, this was done with the mildest cam MTI recommended (with aluminum head upgrade). It could have easily been up to 120rwhp gain if I had gone with a hotter cam. All told, it only gained 98rwhp.
Even so, How do you figure a 350rwhp car would put it to "the low end" of what a 400rwhp (E55)car does with similar (possibly less) weight. Think about that.
Old Sep 8, 2005 | 05:13 PM
Grumpy666's Avatar
The proof is in the posting. Show us your documented dyno sheets. And don't try to scam us like WayneE did.
For those of you who clicked on the link that WayneE provided for his mildly-modified LT1 engine (dyno from my head/cam/long tube LT1), click on this link (http://www.purplecar.org/) to see the 1996 Firebird that belongs to that graph. Read the description of the mods to the car. Big heads, big cam, high compression pistons, larger throttle body, high-lift rocker arms, yada yada yada. There are big bucks in that engine. You just lost all credibility, Wayne.
It's simple math. Take a 4000 pound car, add 440 HP (350rwhp w/20% DT loss) and plug it into well-documented equations and you get 112 mph at sea level. Here's a link if you'd rather just do plug 'n chug: http://www.ajdesigner.com/phphorsepo...horsepower.php
Enter 4000, select pounds, enter 112, select mph, hit Calculate. Scroll down after you hit calculate to see the HP calculation.
I still stand behind my original statement re: your rwhp claim that a mild head/cam LT1 will produce 350 rwhp.
Only now, Wayne has substantiated it.
This will be my last response to either one of you guys on this topic.
Old Sep 8, 2005 | 06:26 PM
WayneE's Avatar
'72 Suburban
I'm not here to lie or misrepresent anything. I built everything on that car (it was mine until about 2 yrs ago) - I know what I had in it at the time of the dyno.
I'll can post graphs from other LT1s that I've built, friends have built or had a hand in building. I'm no newbie and have nothing to gain by misrepresenting an old GM engine. :p How many LT1s have you built? Raced? Or are you an Internet expert?
The point is, you're 100% incorrect and no matter how you try to spin it, that fact does not change.
