People riding on 20's
I will post pics as soon as I get around to washing the car, they are Maya GR5's silver with a polished lip.
The extra width may cause rubbing of the inside lining of the wheel well (especially with different offset) and at maximum acceleration (weight transfer to the rear if your car is lowered) it apparently triggers ESP and the whole rear "wiggles until the car levels off after accelerating. Stay with the first size I mentioned and check the offsets.
If you like the wheels but they have more than 10mm too much offset, say ET44 front instead of ET 30, you can get hubcentric flanged spacers from H&R which will push your wheels out to the desired offset, without resting the entire wheel weight on the lug bolts only.
Good luck.
I think that it would be a mistake to go to a lower profile tire (even with the extra width).
I also think that with your living in Florida that you made a mistake going with the Pilot A/S's.
I suggest you go with Michelin PS2, Goodyear Eagle F1 GSD3, or Continental Sport(Extreme?)Contact 2's -- and I would very strongly suggest that you fit them in a size and profile that matches OEM overall diameter.
Have you tried to see if they rub with four people in the car. I have 285/25-20's with rolled fenders and no rubbing whatsoever.
I did want to try a 295/25 so that I can finally get rid of the conti's and get ps2's. Luke at the tire rack said that with my offset the 295's may rub. I think my car is also a little lower than yours.
I'll make it easy here are the diameters, as you can see the larger sizes in the 20" are much closer to oem diameter but the width on the 295 might be a problem that is why i'm asking if anyone using 20's currently has experience with any of these sizes.
245/40/18 25.7" dia.
265/35/18 25.3"
245/35/20 26.8"
255/30/20 26.1"
285/30/20 26.9"
295/25/20 25.8"
Does your car have 20's on it and if so what size tires are you running, or have run?
( i have 19's)
Props to Loren for his work on this topic.
https://mbworld.org/forums/w211-amg/129998-k2-back-kleemann-295-wiggle-tranny-leaks-freaks.html
https://mbworld.org/forums/w211-amg/130864-wiggle-resolved-ps2-295-versus-285-285-wins.html
https://mbworld.org/forums/showthread.php?t=129998
https://mbworld.org/forums/showthread.php?t=130864
Thanks for everyone's responses.
Can someone help me on this? Is it true? and what's the bolt too, I'm guessing camber...
I will work on picture....
