20" wheels for 01' e55 -help!!!
Old Mar 4, 2006 | 11:45 AM
edub's Avatar
if anyone can tell me if 20"s will fit on the w210-well i know they willl but with springs and #1 pads will there be any rubbing.
looking for
20x? front
20x? rear
tires?
offset
with or without springs
i need this info A.S.A.P up coming car show!
thank everyone.
Old Mar 4, 2006 | 12:33 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Dubs are not recommended for any W210 E-Class. It is possible but you may need to buy custom built forged rims usually prices well over $1k each. Without the proper offset the tires will rub inside - See this I just posted today about offset:
https://mbworld.org/forums/wheels-tires-suspension-brakes-forum/139356-2000-e55-custom-wheel-tire-sizes.html
You would need a tire size of something like:
Front/all
235/30/20
245/30/20
Rear
265/25/20
275/25/20
285/25/20
You will need to find these rims sizes for the front:
20x8.0 with offset around et31 using 245 front tire
20x8.5 with offset around et25 using 245 front tire
Good Luck in finding those size.
Old Mar 5, 2006 | 12:26 PM
edub's Avatar
I see
Thanks for the good info!
quick qestion tho- with all this 235 up front on a 20x8 will it still rub if i use the H@R's?
i have looked for people who run this set up and i can never tell if they are 19"s with a real slam or just a 20" rim on stock suspension.
are there any pictures or other member running 20"s?
i just don't want to spend a decent amount of money and then have the tires rub.
thanks
Meara_Image
Old Mar 6, 2006 | 10:33 AM
E55 KEV's Avatar
Veteran: Air Force
sorry, can not answer that
Old Mar 8, 2006 | 11:49 PM
mysticblu999's Avatar
Mercedes AMG
thanks
Meara_Image
we use 19s around here! lol i know that a 245/30/20, is the same hieght as a 245/35/19. as for the back i never could find a 275/25/20 but i do know that pirelli makes a 285/25/20. they also make the 245/30/20. those tires is the only way you could do it right, or you would look like a 4x4....
Old Mar 9, 2006 | 03:29 AM
jl88's Avatar
Don't put 20's on a w210. It requires modification to the front fender well for it to fit correctly. I've seen it done on 2 w210's. Both times, it took a while for the body shop to get it right.
Just stick with 19's.. or buy a w211 and get 20's on that.
Old Mar 9, 2006 | 11:16 AM
E55 KEV's Avatar
Veteran: Air Force
jl88, were those cars E55's? Plus, are you referring to rolling the fender lip? The fender lip on the E55 is already rolled. I think 20's are too big for W210 I would not have made the recommendation for the 245 width front tires for a non AMG car. So, further body mods may not be needed.
Old Mar 9, 2006 | 11:39 PM
edub's Avatar
see i like 19's i think they make the car look proper on some h&r's, but some how my car got nick named EDUB and i thought lets follow through with that name.
19" what am i looking for offset wize for front and rear?
what about 19's front 20's rear? has anyone done that?
and YES w210 E55's COME WITH ROLED FENDERS! you have to be stupid not to know that if you own one!
thanks-
Old Mar 11, 2006 | 01:58 PM
deuce zer0's Avatar
E63
i have a set of 20 inch lowenharts in the garage i had on my non amg 210. I used 225/35/20 and never rolled my fenders. I never had any issues with my tires rubbing fenders either.
Old Mar 13, 2006 | 12:08 AM
E55 KEV's Avatar
Veteran: Air Force
You would have if you tried to run 245 width up front. Fender rolling is not needed going from the OEM 215 to 225 or perhaps 235.
Old Mar 13, 2006 | 02:31 AM
AMG_55's Avatar
mymbonline
225 all around on an e55
get 19s, 245 fr. 275 rear.
Old Feb 22, 2014 | 08:54 PM
AMGBOI's Avatar
96' Mercedes-Benz E320
I own a 96 e320 w210 model and I'm looking at a set of 20's as well but they're 8.5 wide and 40offset, I have no clue about fitment or nothing but I heard if I run the tire profile you run it will be okay as well. I just don't know about the widtch of the rim with the offset, is this a problem rubbing?
I don't mind driving slow over curbs or bumps, or for corners either but I'm just wondering if they'll fit and if so whats involved to make them fit?
Best Regards!
Old Feb 22, 2014 | 09:08 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
holy necro-post! that's nearly a decade!
Old Feb 22, 2014 | 10:55 PM
GregMB's Avatar
....and completely wrong forum too. Awesome.
-G
