Start-up engine fan noise / gear shift questions - HELP
Old Mar 29, 2006 | 09:59 PM
sac73's Avatar
2006 E55, 2007 R350
Hi everyone, 2 quick questions please:
1) when I first fire up the engine, for the first minute or so, the engine sounds very loud, and the noise seems to come from some kind of fan or something, and when I open up the engine bay to see what's going on, I couldn't really tell exactly where the fan noise was coming from except it was fairly near the top of the engine, but it goes away in about a minute or two. It was more of a fan noise than engine noise Is this normal operating producer for the 55 engine at start-up?
2) when pushing the car fairly hard in 2nd gear (up to around 5k rpm), I shift gear into 3rd by using the botton, but the engine doesn't shift right away and the rev kept on going for a bit. Is this normal? How fast or slow is it suppose to shift? (in S mode)
Thanks.
SAC
Old Mar 29, 2006 | 10:20 PM
Mad TKD's Avatar
all normal
Old Mar 29, 2006 | 10:21 PM
eagleeye's Avatar
07 ML63; 05 E55 (sold)
Originally Posted by Mad TKD
all normal
Yup, my 05 does exactly the same thing. I love the start up noise.
Old Mar 29, 2006 | 10:30 PM
sac73's Avatar
2006 E55, 2007 R350
thanks guys for the quick response! so the engine noise is normal (sounds like a big *** jet engine or something!!), what about the gear shifting part? is the delay of shifting under hard driving normal?
Old Mar 30, 2006 | 10:10 AM
regor60's Avatar
06 E55 Black
Yes the delay is normal if your pushing high revs. It assumes you want to continue in that fashion even if you slightly lift from the accelerator, I've noticed.
Old Mar 30, 2006 | 11:17 AM
sac73's Avatar
2006 E55, 2007 R350
Thanks!! I wish there was a redline marked on the dial because the damn thing revs up so quickly it can get pass the 6k mark really quick!
Old Mar 30, 2006 | 12:08 PM
bfnnrgn's Avatar
SL65
Mine goes into the red all the time while really 'driving' the beast.
Old Mar 30, 2006 | 03:03 PM
moose's Avatar
Its the kompressor
What you hear is the supercharger, they make a whinning noise. The noise sounds like I have a bad power steering pump. I personnaly hate the noise but like what it does...
Old Mar 30, 2006 | 03:07 PM
saveur's Avatar
I get the same thing on my 06. As for the shifting, it's pretty irritating. When I drive hard, I usually run it up pretty close to the redline, and when I push the shifter button to upshift, I always end up bouncing off the limiter because the shifting is too slow. Now I just leave it in Sport mode, and find that it actually does a pretty decent job of upshifting/downshifting when I want it to.
Old Mar 30, 2006 | 05:13 PM
Mad TKD's Avatar
Yep I agree just leave it in sport mode. It down shifts and up shifts pretty damn good. The only time I really use the buttons is to down shift. The up shifts though are pretty good.
