Video in motion & MP3 enabled Command
Old Aug 22, 2006 | 04:42 AM
  #76
OzE55's Avatar
2003 E55
Originally Posted by tigerlam92
Hi,
I have the same issues. I can play CD-MP3 and DVD-MP3 on the top single player but not on the 6-disc changer. That's no problem for me since I'm quite happy that it can play the DVD-MP3 on top already.
My questions is can/how to make it so the DVD movies will work. It is currently outputting CD-Error as well. I can access all the secret menu without any problems. I don't have the "movie in motion block" but I do have the driver distraction menu.
TIA!
Its normal that DVDs only play in the top slot.
Mine are the picture posts above - for reference.
When I put the mp3 DVD or a DVD movie in the slot- the first screen shows a 'DVD Movie' icon and, beside it, a 'compact disc' icon. The movie then plays when I push the 'video' button on the left side of the COMAND.
If it plays an mp3 DVD the hardware must be correct it must be a software setting or version problem or DVD problem. Try another commercially available, good-quality, DVD AND make sure the region setting matches on the DVD and in COMAND. It might be that the DVD wont play because of some copyright software if the regions dont match.
cheers
Old Aug 22, 2006 | 04:58 AM
  #77
E55 RUSS's Avatar
E55K
OSZ...
I tried to watch DVD...put DVD in...it start to read but the says no DVD or cant read...
What should I do ???
Also how can I make (EURO) my DVD to work while driving ???
Old Aug 22, 2006 | 06:08 AM
  #78
OzE55's Avatar
2003 E55
Originally Posted by E55 RUSS
OSZ...
I assume your COMAND looks the same as in post 58, above.
Try another DVD with the car engine off (gear selector in park with park brake on) - does it work?? Is the region code on the DVD and the setting for the car the same??? - check in the menus above.
There are settings in the engineers menu which MIGHT allow DVD playback while driving - you will have to try the options (write down the original settings BEFORE you start changing things!). I dont watch DVDs while I drive - I watch the other crazies on the road!
Old Aug 22, 2006 | 06:27 AM
  #79
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I dont either but it keeps the wife's eyes off the speedo ...!
Old Aug 23, 2006 | 01:31 AM
  #80
tigerlam92's Avatar
E55
cheers
Thanks for the help!
My command unit and version is exactly like post 58.
I will try setting it to US region and try another movie.
For the drive distraction, if I uncheck everything does that mean the movie will work in all situation?
For the DVD MP3, it appears that the command unit only sees the first 60 directory. Does any know if it sees directory within directory?
Old Aug 23, 2006 | 04:45 AM
  #81
E55 RUSS's Avatar
E55K
My command the same but I cant get to Engeniring menu....
Do I press all the button at the same time ???
More detailed intsructions please...
Also I went to other menu, the one you use for Dynomode but European cars do not have Dynomode, Confiremed Service one and now getting this message that I missed service B by 90 days ...anyone know how to clear this problem ???
Old Aug 23, 2006 | 05:10 AM
  #82
OzE55's Avatar
2003 E55
Posts 19 and 21 in this thread explain, in detail, how to get to the engineers menu.
Does a DVD movie play in the slot with the engine off and the key in the 'acessories' position???
Old Aug 23, 2006 | 05:13 AM
  #83
OzE55's Avatar
2003 E55
Just try one option at a timne and see what works.
I placed my 1000 mp3s in about 6 directories (alphabetical) and it reads them all. I suspect (but haven't tried) sub-menus wont be read. I suggest you keep it simple.
Old Aug 30, 2006 | 06:24 PM
  #84
SS3E55's Avatar
E55
------- new input and a SUMMARY of what I think is going on ------
Just today I went in for service D and asked for a SW upgrade to Command - the tech was great - he did the upgrade and now I have full MP3 playing, although now I cannot get into engineers menu. So looking again through this thread I think we can see this :-
1) Some commands have the MP3 from factory (late models - like all 06's and many 05's)
2) you can get upgraded to this level (it appears now I have this)
3) If you are earlier than 04 (despite you car production date I mean the SW date in the command) then you cannot get this engineers menu at all
4) if you are between the date in #3 and the MP3 enabled versions (#1) then you can either :-
4)a) follow the instructions and get to Engineers menu BUT not get
to the second level (*#<) to enable MP3 <-- this "was" me
4)b) follow the instructions and get to eng AND also get to second level
then enable your options yourself.
5) For video you just need the Euro version (no choice here) and also you must enable the in motion ability by going in the menu's.
Now I'm not sure but this pattern seems to fit all the issues people have had - like not getting the screen at all, or having the mp3 from factory, or getting only one menu not both.
Hope this helps for those not getting the responses assumed to be possible (I was confused myself getting eng menu but no further)
Good luck!
Old Nov 11, 2007 | 11:14 AM
  #85
LOB's Avatar
LOB
CLK 270CDi
read my post above it's NOT 357 etc. its mute - end call - SERV.
Hi for everyone!
I have a clk 209 2004 ("made" in france) and i tried do access eng menu but i didn't have success... (with sequence mute - end call - service)
Somebody can help me activate mp3 and video ate my comand?
My comand didn't read dvd even't stoped...
Best regards and sory my bad english.
Old Nov 11, 2007 | 11:02 PM
  #86
redd3vilz's Avatar
2004 E55 AMG
i got the dvd mp3 to work .. but i can't get the video to work.. so sad.. i got 04 e55.. any help.. i want to watch dvd.. plese help me
Old Nov 11, 2007 | 11:03 PM
  #87
redd3vilz's Avatar
2004 E55 AMG
just to add i got into all the command screens no problem. but dvd keep saying CD error
Old Nov 11, 2007 | 11:25 PM
  #88
DirtyVegasMB's Avatar
'21 GLC63, '19 M5
My audio on DVD works, but I get no video... any help on getting the video. I know this thread seems like it's been beat to death... but any input will be appreciated.
Old Nov 12, 2007 | 06:51 AM
  #89
way2evil's Avatar
1989 Toyota Tercel Coupé
You cant get video on a US Comand. There is no DVD player. You need a Euro Comand (or at least thats what I've been told)
Old Nov 12, 2007 | 06:55 AM
  #90
OzE55's Avatar
2003 E55
Does you COMAND look like the jpg picture in post 58? Specifically does it have a 'video' button on the side? If not, I think your out of luck.
Old Nov 12, 2007 | 12:26 PM
  #91
'21 GLC63, '19 M5
No VIDEO button, I have a SAT button instead. I confused it with my 05 S600. It has DVD label when it opens up, and plays DVD and I can hear audio, just not Video.
Old Nov 13, 2007 | 12:18 AM
  #92
OzE55's Avatar
2003 E55
I think if there's no video button and you don't have TV then your COMAND is not video enabled. That's likely to be a hardware problem - ie change the COMAND, not a software upgrade issue. Sorry.
Old Nov 14, 2007 | 07:43 PM
  #93
LOB's Avatar
LOB
CLK 270CDi
My comand had video button...
somebody help!
Old Nov 15, 2007 | 07:09 AM
  #94
OzE55's Avatar
2003 E55
what happens if you put a DVD movie in the slot? what about a CD?
Old Nov 15, 2007 | 09:34 AM
  #95
andy_cyp's Avatar
Obsidian E55
GUYS LISTEN........
IF YOU HAVE EURO COMMAND AS IN POST 58 BUT AT ANY TIME DEALER HAS UPGRADED THE SOFTWARE TO IT THEN YOU ARE SCREWED, THERE IS NO WAY OF GETTING IN TO THE ENGINEERING MENU AS THEY CLOCKED ON AND DISABLED THAT FUNCTION COMPLETLY.
How do i know this ???? I learnt the hard way, i unlocked it as per steves same instructions 2 months ago, then car went in for a service and the mfers upgraded my firmware whilst in.
Another way to find out if your euro command has the latest software is simple, whilst in navi mode if your command displays ETA on it then its been upgraded and the sequences will not work.
hth
Old Nov 15, 2007 | 01:26 PM
  #96
LOB's Avatar
LOB
CLK 270CDi
Originally Posted by andy_cyp
GUYS LISTEN........
hth
I think my was upgrad. On nav presents ETA. There are no way to do a downgrad??
When i put a dvd and press video button appears, no video found...
Old Nov 15, 2007 | 02:14 PM
  #97
bgee55's Avatar
20’ G63,18' GT3, 17' NSX, 16' Cayenne, 09' GTR, 05' E55
mbdoctor.com was able to help me with that issue as mines was locked out.
Old Nov 15, 2007 | 03:02 PM
  #98
OzE55's Avatar
2003 E55
But do you get sound?
what about a CD? If that works burn a FEW mp3s to a CD and try - AUDIO, MP3.
Old Nov 15, 2007 | 03:53 PM
  #99
andy_cyp's Avatar
Obsidian E55
No way possible to downgrade
only way possible now is to unlock it via obd port.
Old Nov 16, 2007 | 03:51 AM
  #100
stevebez's Avatar
cr*p I am due for service now ... ferking stealers ...
I am tempted to get a court order not allowing them to touch any of the cars software!!!!!!!!!!!!!
