K&n Filter Part# For 05 Model
Old May 3, 2006 | 05:53 PM
JAY55's Avatar
///E63V10 ///F80CS ///Can-Am X3 XRS
I just ordered a pair of K&N filter #33-2181. For some reason 05 model has a different part # at K&N's web site.
33-2181 Product Specifications (2005 E55)
Product Style: Panel Air Filter
Height: 1.188 in (30 mm)
Outside Length: 13.75 in (349 mm)
Outside Width: 5.188 in (132 mm)
Filter Re-Oiling Amount: 1.14 oz (34 ml)
Weight: 0.9 lb (0.4 kg)
Product Box Length: 17.25 in (438 mm)
Product Box Width: 8.25 in (210 mm)
Product Box Height: 1.88 in (48 mm)
___________________________________
33-2859 Product Specifications (2003-04 & 06 E55)
Outside Length: 13.938 in (354 mm)
Outside Width: 5.25 in (133 mm)
Filter Re-Oiling Amount: 1.21 oz (36 ml)
Weight: 0.8 lb (0.4 kg)
Old May 3, 2006 | 06:02 PM
MNG's Avatar
MNG
Audi's, a whole bunch of them
they are the same, if i remember correctly
the newer ones have rounded corners and the older ones have straight edges, no difference if you ask me
Old May 3, 2006 | 06:03 PM
Rock's Avatar
Administrator
Drives Slowly
Summit Racing list the 05 and 06 as follows:
KNN-33-2181 $38.69
Estimated Ship Date: 5/12/06
Application Warranty Show All
Brand: K&N Engineering
Product Line: K&N Filtercharger Air Filters
Universal: No
Shape: Rectangular
Length (in): 13.750 in.
Width (in): 5.188 in.
Thickness (in): 1.188 in.
Filter Color: Red
Filter Material: Cotton gauze
Quantity: Sold individually.
Old May 3, 2006 | 06:48 PM
jangy's Avatar
2015 S212
REPLACEMENT AIR FILTER # 33-2859
You are right. Mine and the '04s are the same??
Old May 3, 2006 | 08:20 PM
JAY55's Avatar
Thanks, I was worried for a minute. My first internal mod snorkle and filter, hope it will give me a little HP gain.
Old May 3, 2006 | 09:34 PM
jangy's Avatar
2015 S212
snorkel? what snorkel?
Old May 3, 2006 | 11:11 PM
MNG's Avatar
MNG
i believe the snorkle mod is switching the stock plastic pipes that connect to the airbox from the grill area with the larger one from the S or SL class
Old May 3, 2006 | 11:20 PM
PerisanGodFatha's Avatar
is Sick as Fu*k
where can i Get these filters from for the 2006 E55...where can I ordere them...any1 know a part number....i need 2 filters right?
Old May 3, 2006 | 11:31 PM
JAY55's Avatar
I assume you have an 06 model then the part # is 33-2859. Dean62 had a good advice, he bought the exact passenger side one and replaced the driver side with that. I went with the same route instead of getting the SL snorkle, I heard the SL one doesn't fit very well.
Dean62's Avatar
2024 911 ST, 2025 G63, 2023 Bentley Flying Spur Speed, 2024 Porsche Taycan Turbo S, 2025 SL63S E
Yes you need 2. I ordered them direct from K&N. Here is their web address....http://www.knfilters.com/. Check them out.
Old May 4, 2006 | 09:33 AM
metalica_23's Avatar
'06 SL600
As a secondary place, I just ordered them yesterday off www.autoanything.com. They were in stock, about $4 cheaper and free shipping...Yep, I bought a 90k car and I'm worried about $4.
Old May 4, 2006 | 12:53 PM
regor60's Avatar
06 E55 Black
Be careful with the part numbers. 04s don't fit properly in the 05. Check with K&N on exact number before ordering from another supplier. From experience
Old May 5, 2006 | 01:04 PM
davidhung78's Avatar
2003 E55
Is this the 'green filters' you guys are talking about? is there any gain(im assuming very very minimal) from doing this if i currently have no performance mods? i know i will eventually want to change the filter anyways when i pull the trigger on the performance mods but is there any reason to do it now? any idea on what the part number is for an '03? and how easy is it to swap out myself? thanks guys.
