Hennessy or Asp pulley on cls55
Has anyone tried the asp or Hennessy Pulley on a cls55 ?. I know this is the wrong forum but it's the busiest.
1 Post
STS,FGT,12C,P85D,M4
Ever read the stories about Hennessy ripping their customers off for thousands of dollars.... even the major magazines reported about it....
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
.............I have the Henessey pulley in my G55 K4. latest dyno is 506HP and 531lbft of torque to the wheels. That adds up t 670HP and 706lbft of torque to the crank using a 25% drive train loss for big 4x4. The advantage of the Henessey pulley is that it is a larger pulley and generates higher boost. The pulley upgrade is not complicated and in my humble opinion no one company has a secret sauce. what is important is that you need a fulley dampened pulley so that your set up remains harmonically balanced.
Ted
Ted
The ASP pulley is a modified MB pulley and therefore has the damper. I read that that you used to be able to send your original pulley for a core credit but I don't know if they still do it.
Originally Posted by M5 RUS
I thought you have ASp pullies yourself...It works good ???
Are ASP pullies harmonically balanced ??? Thinking of getting them...
Just wanted to see if anyone has tried it on a cls 55.
Received 1,071 Likes
E55, GLS450, GL63, GLE350
The pulley is a modified stock pulley so it is harmonically balanced
Originally Posted by BlownV8
Are you sure it's a modified pulley or is it a custom pulley that mounts to the existing harmonic balancer?
It doesn't look as nice as the klee or renntech but it works great.
This is what you get for the ASP kit and the link is for the dyno.
https://mbworld.org/forums/showpost....4&postcount=20
.............The smaller pulley pictured above is a smaller waterpump pulley that is neccessary with the Hennessey and ASP pulleys because the larger diameter of those modified Crank shaft pullies cause them to rub against the stock water pump pulley when installed. It is not usually needed with the Kleemann and Renntech set up.
Ted
456 HP at the wheel sound good with just a pullies...
Ted...
Do you think its SAFE to run 55 with Headers and Pullies and stock ECU ???
Ted...
Ted
The asp pulleys use the existing belt. The smaller water pump pulley offsets the larger crank pulley.
I was going to do the before and after dyno on the same day. Would it be better to wait some after the install to let the car do its adjusting and if so, how long?
Hmm...so I need to get some other belt with ASP pullies or they come with diff S/C belt already![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
So I would definately need this Dayco belt you recccomended....Is it expensive ??? Can I get it form them as well ???
.............nothing special about the belts. At the time of install, you look to see if you need a slightly larger or smaller belt and you purchase that from your local auto parts store. Mine came from Discount auto parts. The pulley upgrade is a really a very simple mod. Not sure why it is shrouded in mystery and wonder.
Ted
Ted
Ted
I would be curious to know what belt size you have on the g wagon?.
OK 515, 525 what measures are those...not sure if our local supplier would have such belt on stock...thats is why I want to prepare....
So I need size 515 ???
