MHI Bluetooth adapter works with the Treo 700p
Old Jun 13, 2006 | 04:27 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
I bought the MHI bluetooth adapter from aws and took a chance that it might work with my Treo 700p and it does. I replaced my V60x cradle with the MHI adapter, paired the Treo to the car and can make and receive calls with the Treo.... the phone book does not transfer automatically, not sure if there is a way to program your own phone book in command.... would be nice if I could but I'm happy with the way it works now.... one less phone on my plan...
Old Jun 14, 2006 | 08:13 AM
Hook's Avatar
Have you tried downloading the phone book using the "Send Contact" option?
Hook
Old Jun 14, 2006 | 09:01 AM
Fikse's Avatar
STS,FGT,12C,P85D,M4
yea, when trying to send, I choose send via bluetooth, and the car isn't listed as a send to option...
Old Jun 14, 2006 | 09:09 AM
Hook's Avatar
Did you try disconnecting the phone from the Bluetooth device before attempting to send? I know this sounds strange, but this is the only way I could send the phone book to my Parrot BT car-kit.
Hook
Old Jun 14, 2006 | 10:54 AM
Fikse's Avatar
STS,FGT,12C,P85D,M4
how do I disconnect? as soon as the phone and the car see eachother, they pair up, I get the headset icon on the treo, and the signal stregnth on the comand display...
Old Jun 14, 2006 | 11:46 AM
Hook's Avatar
Good question. On the Parrot kit, there was a menu that allowed one to disconnect the phone while keeping Bluetooth active.
I did a little searching & found something that might help. Try this: press and hold the TEL key on the COMAND until the display shows that the phone is disconnected.
Does that do anything?
Hook
Old Jun 14, 2006 | 04:43 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
holding down the TEL button disconnected the phone, but the car is still not visible when trying to send.... the only way the car is visible in bluetooth is if the unit is in pairing mode, I tried putting it in pairing mode, then sending over a contact and it just said unable to send to device.... running low on thigns to try...
Old Jun 16, 2006 | 09:05 AM
Hook's Avatar
Strange. Does the car show up on the Treo as a Bluetooth device when you're not in the car/connected?
Hook
Old Sep 7, 2006 | 02:15 PM
STKLAW's Avatar
2010 E550
[QUOTE=Fikse;1636389]I bought the MHI bluetooth adapter from aws and took a chance that it might work with my Treo 700p and it does. I replaced my V60x cradle with the MHI adapter, paired the Treo to the car and can make and receive calls with the Treo.... the phone book does not transfer automatically, not sure if there is a way to program your own phone book in command.... would be nice if I could but I'm happy with the way it works now.... one less phone on my pla
Does voice command work?
Old Sep 7, 2006 | 02:53 PM
Fly Low's Avatar
w211 E55
I was thinking about installing the MHI adapter as well, but am still waiting for the Argos system to finally be released. The Argos supposedly downloads your contacts automatically. Anyone heard an updated release date?
Old Nov 23, 2006 | 08:10 AM
jdr1000's Avatar
Does your 700P ring at the same time as the car? How do you keep this from happening?
J
Old Nov 23, 2006 | 08:22 AM
Fikse's Avatar
STS,FGT,12C,P85D,M4
not sure if you can... you can hit the switch at the top to put the treo in silent mode.... :\
J
Old Nov 24, 2006 | 12:09 PM
the yellow man's Avatar
06 Merc E55, 996TT
Quick question guys... I have an 06 and was wondering how hard is it to add a phone kit??? I think my car is pre wired?
Old Aug 10, 2007 | 07:59 AM
SteveGoldman's Avatar
I have a Treo 700w paired to the Bluetooth "Dongle" and it works fine. It sees my speed dial list as a phone book too. This is installed in a 2005 E320.
