Aftermarket Sway Bar interest?
Has larger bars and the addition of a rear bar
The wheels are .5 inches larger up front
The front lower control arms have stiffer bushings to improve steering
The steering rack has stiffer bushings holding it in place to improve steering feel
Steering rack is faster (not 100% sure as this changed in late 2004 as well)
The car sits about 1/3 an inch lower stock
Thats some things I have found. But mind each control arm is over 800 bucks and each shocks is 1.8k at retail and about 1200 at cost. Making an E55 turn will cost you a bucket of cash.
If you want that go buy an E63 or M5.
Thats my 2 cent.
Of course it CAN be improved BUT the demand for such parts would be so low that the cost per unit would be far to high to justify anything. About 10 people might want parts across the globe and I bet most would say sorry to a 10k bill for a set of new air springs and hydro shocks.
Its the market for these cars. That is why it was made soft and that is why no one makes parts. The customers really dont demand it.
Last thing, I agree on having to "muscle" the E55 to handle, but I'll take the active suspension over the coil over option simply because that weight shift helps handling WAY more than the other would. Yes, it is a bit sloppy, but it does not lean nearly as bad in transition as a coil over system would.
I really do giggle every time someone tells me their W211 handles well.
my clk actually handled reasonably well and the grip was very good after i put 235 and 275 ps2's on it.
brabus makes a conversion/coilover kit for the airbagged 211's
that would be the 1st thing id do if it was my car
btw,
i agree w/ canyoncrv about night runnin and very small groups (4 cars at most)
we gotta do this sometime
btw,
LOL!!!! Dude, if he was dissing the E, the CLK is not exactly what he is guaging against. We do need to get together. All this theory is too much for me. I also agree that anything more than 4 gets too crowded. I'll post a map of the area I am talking about and maybe a few LA folks will finally show and ride instead of just preaching.......maybe?
It's safer
Takes more skill
you can push HARDER, and go FASTER
plus you become a better driver, you ge to see every bump on the road, feel every bump..etc...hmm man i wanna goo ! show you guys what the North Cal pp have to offer !
Id be bad *** if a 500SE killed a few AMG's ne ?
carry on!
my clk is gone back to mb, the lease finally ran out.
i would have to bring my moms e55 (bone stock) or maybe ill get a car by then
(thinkimg of a 997s, m5, z06, in that order)
Hmm my first time with the 350z i ran a 17:23 in the dry....hmm i predict i can get it under 15 mins with the 350z...ill be getting itagain the 11th...soo ill get it all on camera... and ill try to hit under 16mins with the benz..
New road...with the 350z it was my 2nd time with the benz was my 3rd time...so times are dropping... i have 53 other 'courses' back homw where i practice... u guys should live in that yay area! so i can show u all the great mtn roads!
And coilovers leaning in transition??? MADNESS. I've had four cars with coilover suspensions and they're probably the best thing since the microwave. You can't possibly try and argue that an airbag suspension handles better in a transition than a coilover setup, its just silly. Swaybars help, but your shock/spring setup is the backbone of any setup and airbags are the absolute worst thing you can slap on.
The C32 I use at the track had all the above done and then we added some H & R bars and the car finally came into its own. We gained some real exit speed and actually reduced front tire wear on a track where you will kill a drivers front tire in 3-4 sessions of driving.
As for the Airmatic vs Coil over argument. I will take a flat E55 over one that is leaning ANYDAY. Active suspension on the Airmatic doe at least sddress weight balance. What exactly is the advantage of the springs?
off the top of my head
Again, more talk. I'll counter that with Airmatic's ability to counter sdjust vs the coil overs just "giving"
Weight. hmmm, you'd be amazed at how close the two setups are. I'll give you the added manifold and compressor as weight.
Feel. I'll take an active over a reactive for feel any day. Far less lean.
Tuning Ability. What is the difference. The airmatic is simply air springs, not shocks. The shock component is the same and can even be tuned. I am working with Bilstein right now to replace mine. I have also had the stock ones re-valved for rebound for much better transition response.
Anything else on the top of your head?
Jangy, if airbags were a good application for handling, you'd see them in some sort of competition use. You don't. Hell, if they were the better choice, don't you think BMW would be onto it?
Also, check your references. Most competitive arenas WILL NOT ALLOW active suspensions. The reason is an attempt to keep the field competitive. Your exact argument was made when some people liked automatic transmissions. If automatic was better than manual, then they would be in competition. Hmmm, now years go by and what do you know?
if you want a sedan to kick butt dont get a mb
youre 1 hard headed ****
to think it is.
Brabus removed it from the CLS V12TT vehicle because they needed to increase the SPRING RATE and the air spring did not allow such changes without serious changes. They also felt the AirMatic system was not controled enough for a car capable of doing 220mph+. So between the fact that it could not deal with the downforce created at speed and the fact that it was not all that sporting means that I think a coil-over kit is a real upgade. It should be noted that I think brabus did not remove the airmatic system but instead ordered a base CLS350 that has regular coil springs and shocks and not AirMatic.
With coil-over's you have the ability to call the spring company and get 12 sets of springs and fine tune the chassis. You can have 3 way adjustable external resevor shocks made for a car like that and a set-up like that will be so much better than an Air spring car.
An E55 cam and should be capable to chasing down an M5. But BMW put some real effort into the chassis and AMG just kind of went oh thats good enough and slapped ESP on there to keep it in check. The BMW is made for hard driving not just baun blasts.
Finally my E55 has the max camber allowed in stock form and it is fairly nice . Trouble is that I have a serious tire wear issue. NO car should require so much camber to make a corner that the inside fronts are gone after a few months of non-monkey canyon or track use. I now need to think about what to do and what this car is really for. I dont know how long I will get out of a set of tires but if its 5k miles forget it I am setting it back to stock and just using the car for trips to Santa Barbara on weekends etc.
Thoughts on how long a set of PS'2 will last with 2.5+ degrees of neg camber?
to think it is.I am not saying that Airmatic as it stands is the be all and end all. It is just that I like the concept of an active system. No matter what you do to coilovers, they are a reactive system. You throw the car into a curve and the outside will compress, not "push".
Don't get your undies so tight. I am plenty humble, and have all the respect for BMW that they deserve. I am just thinking a bit outside the box.
Maybe it is my fat butt in the car or that foot made of lead, but it has been that way ever since I've been in the E55s. I barely got 10K out of a set on my E500 before that.
