Aftermarket Sway Bar interest?
I too was looking into this a while ago. When I had my audi I was the test car for a certain company's new set of sways....it was awesome...I was thinking about asking him to take a look at our cars to see if he could work something...anyways keep me posted as I would be greatly interested...
There must be some anti roll stabilizing method for the rear than can be beefed up? Either way, I guess I'll start on the front, since that is where I have been adding lateral traction.
In short, there is a pretty beefy front sway bar (If I am not mistaken - 33 mm), there is no rear bar.
I was going to make bracketry to mount a bar in the back along with thicker bar for the front. Along with camber adjustable ball joints as a complete handling package.
If there is still interest I can resurrect the project.
I am having the mounting plate on the ball joints reproduced with modified holes. We played with slotting the OEM holes to prove the concept and it was NICE. The next move is to make the modified ones and see what stress it adds to other components. Hopefully, updated bushings will be enough.
Here is the deal on the project. A car is needed in the LA area for an initial inspection and possible fitting. As with all reputable places, this place also has the CNC bending machine, so i may plan a visit to LA to let them check my ride out. The benefit is a set of free Sway Bars when the project goes. In this case, the manufacturer would have the interest and I would OWN nothing, so it is different than what i had planned. But, in the end I get a set of bars and get to learn a little AMG R&D as we go. No promises yet, but it may be possible to have a local (LA) car go in for the fitting and then use my car for the final tweaking. In this way, the car that volunteered would also get a free set. Lastly, as always, MBWorld members will get the daddy initial price and then the manufacturer will be off charging whatever he wants.
Let me know if anyone is down and we can go from there. I am doing this. the new ride height is awesome and only shows how much mre can be pulled from these cars.
https://mbworld.org/forums/attachmen...2&d=1144597359
https://mbworld.org/forums/attachmen...3&d=1144597359
https://mbworld.org/forums/attachmen...4&d=1144597359
Hi PTE, never fear the will be ANTI sways. LOL. Can you give any description on the effects of bushings alone. The rear bar is FAAR too thin for my taste, so I didn't want to work on bushings alone, but I am curious as to your impressions. By the way, the final pic looks VERY nice.
Thaks for taking the point on this project. I believe it to be a worthwhile one for the community.
I am very interested, as I would like to track this car. I do have a couple of questions:
1) What material would the bar be made of?
2) Is it to be cold-formed w/ forged ends (weaker) or hot formed (stronger)?
3) Will this bar have mulitple attachment points for adjustability?
4) Will the bushings be poly (stiff but noisy) or rubber (quiet but softer) ?
5) Do you plan on making a matched set or just the rear bar?
I ask #5 because stiffening up the rear with no change to the front could lead to an oversteer condition. These cars already have no problem with throttle-oversteer.
Thanks for your input.
A custom manufacture of the item was going to be necessary.
I talked to the owner of "Sky Jacker" who lives in the neighborhood and he said if there was enough interest he might be able to do the engineering of the parts. They normally make lift kits for monster trucks but could do any parts I want.
If you all get to a dead end let me know and I'll follow up on this lead.
2- Full blown hot formed (CNC). This is what they do.
3- no. what adjustment you looking for ? Stiffness or ride height? (just so I am clear). If adjustment is a MAJOR advantage, we can incorporate it, since we are in the planning phases now, so please let me know WHY we should do it.
4- poly, performance first, convenience /sound second.
5- Full set front and rears.
