Had my re-flash done and.....
Service manager called me and said "we need to reflash your ECU and I need to know if you have any upgraded software because it will overwrite" I told him no since I don't but felt like he was fishing to tag my car as modified in their computer
Results
A little ruff idle and a few quirky engine RPM changes at first but overall car actually feels as good or better than before. Seems to have a bit more TQ off idle???maybe?
It probably has the same performance but doesn't have the rambunctiousness that it used to have. With traction control on, I notice that it doesn't shut the motor down like it used to. It's way more soft and less jerky than before. I liked it better the old way.
I have noticed no difference in any performance characteristics or MPG. If anything the car is running excellent considering the heat here in Savannah.
Temps have been 95 plus here for weeks.
I have followed threads about this and it does seem that the older,03 and 04 cars, are being effected much worse than the newer cars.
It also seems that the earlier reflash recipients seem to be having more issues. Do you think MB has changed the flash again due to issues with early adopters?
i could care less about mpg for now, i just want a real e55.
An E55 not smoking the tires from a stop is not a good sign at all.
I'm not sure why you're still talking about this and haven't seemed to address the issue because if you've done any research obviously there's a problem. I suggest a dyno otherwise MB may not believe you. But, at the risk of offending you, you have been flooring it in S mode and not in C, correct ? Since C starts in 2nd and much harder to spin.
My car will smoke the tires in C/S/M no problem. What are you talking about? I have a hard time getting my tires NOT to spin, and you wonder if it is the shifter setting? This ain't a bimmer. Put it in C and comfort on the suspension and see if it still doesn't haul nuts!! this is an E55!!
My car also will not smoke the tires after the recall.... ITs really strange... I figured an E55 will have no problems tearing up rubber..... i will have to do something about this...
i have an 06cls55 and when i took it in they said no software updates were needed, so mine probably has the updates in it already. it can smoke the tires quite easily i might add.... but i'm wondering of any 05s have this prob.... or even 06's that needed the recall. i would be at the dealership if i lost that much power....
My car makes smoke post re-flash. BUT, I had an ECU update before the re-flash, and then overnighted it to RennTech AFTER the MB re-flash for RennTech to overwrite their upgrades back on to the chip. Either way, you should be able to spin your tires no matter what with these cars - there is something definitely awry with your beast!
Reading some of the posts on the forums, some cars are affected and some aren't. I am wondering of those who were and those who weren't what year are there cars? Mine is an 04. This possibly could be an issue with the year of the vehicle. Just a thought.
To think of an E55 that can't make the rears break loose at all? Something's wrong!
To think of an E55 that can't make the rears brake loose at all? Something's wrong!
Yeah,like your supercharger not engaging at all
BTW, I do think there is some evidence for a correlation between model yr and issues with this flash. It seems most effected are the 03 and 04's.
Lets get a poll together or something. Try to collect as much info as we can and some how try to come to some kind of conclusion....
there is definitely something wrong with these cars and i would bank on it being ecu related instead of mechanical. mb idiots won't admit to anything and only say that it must be a new safety feature!?!?!?
.........Chiromikey has summarized the problem accurately. It is actually possible with a DAS machine to read the individual strings of codes in the ECU. This has alread been done and the load limit issue discovered.
Ted
If you are familiar with this procedure and can explain it to me, I can check it out on a couple of E's up here that had the recall done. What do I have to do in DAS in order to check if the load limit is active?
I would like to definitively know if my car has the load limit on it or not.
[QUOTE=Ted BaldwinIt is actually possible with a DAS machine to read the individual strings of codes in the ECU. This has alread been done and the load limit issue discovered.
Ted[/QUOTE]
