Anyone want to race a M6 in Gainesville tonight?
Old Oct 4, 2006 | 03:16 PM
DerekFSU's Avatar
I'm taking the new M6 to Gville tonight to run. We'll get there around 6. Late notice but wanted to offer it up.
Old Oct 4, 2006 | 03:32 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Good luck Derek... I'm predicting 12.4x's @ 117
BTW -- I heard through the grapevine that a guy in Maryland running 100-wetshot on his K3 ran 10.48 @ 136. Look like you no longer hold the crown.
Old Oct 4, 2006 | 03:38 PM
DerekFSU's Avatar
Never had a crown, only goal was to be the first.
Old Oct 4, 2006 | 03:40 PM
dragonAMG's Avatar
my friend, you definitely had a crown!!!
and... the first you were.... just like I'm sure you'll be the first to take the M6 into the 10's.
Old Oct 4, 2006 | 03:57 PM
BIG LUV's Avatar
'06 E55 Black/Charcoal
That's Gator Territory!
Old Oct 4, 2006 | 03:58 PM
BIG LUV's Avatar
Old Oct 4, 2006 | 03:59 PM
Rudyrono's Avatar
2006 E55 AMG
How the heck did he get it to hook up? He must be running ET streets with a ton of VHT on the track.
Old Oct 4, 2006 | 06:37 PM
7 speed SMG's Avatar
06 E60 M5
Gook luck... How many miles? This car gets significantly faster the more miles you put on it... I'm predicting around 12.6 116 if the car has less than 2000 miles and 12.2 119 if the car has more than 5000 miles.
Old Oct 4, 2006 | 06:47 PM
Torquey55's Avatar
2006 E55
Dang, I just found out. Too late... I could have made the trip if I knew this AM.
Old Oct 4, 2006 | 06:59 PM
merc655's Avatar
a few...
Even though you are at the track currently, I wish you luck Derek.
If you have good runs with that ///M of yours, I might just have to visit some friends of mine up there with my vette someday.
Old Oct 4, 2006 | 07:05 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Who the heck is this guy??!! He is always smoking fast and we never know who he is.
Wonder if this is the same guy that's dropping the car in drive from the line at like 3500rpm. If so, this guy is a madman!!!
Old Oct 4, 2006 | 07:12 PM
V12Godspeed's Avatar
Your worst nightmare...
Like I always say, make sure this is recorded!
Old Oct 4, 2006 | 07:32 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
12.91 @ 113.6
Old Oct 4, 2006 | 07:33 PM
BoBcanada's Avatar
AMG
Derek post up some pix of your m6!!!
Old Oct 4, 2006 | 07:34 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
yea, how so? the car will pick up 30HP after 3000 more miles? not a chance....
Old Oct 4, 2006 | 08:19 PM
06 E60 M5
Are these your predictions? No. ///M engines come in very very tight, so this is in what my estimatives are based... And also in other 1/4mile M6 runs... Remember that during the first 3000 miles this engine is still during its break in period, and the more miles you put on it, the faster it gets... and that's a rule for high powered engines in case you don't know
I just noticed that Derek lives in USA, so he doesn't have the EURO LC, this definately means SLOWER times...
Old Oct 4, 2006 | 08:28 PM
rflow306's Avatar
2005 E 55
The increase comes from the ecu not the mechanical break in.
Old Oct 4, 2006 | 08:45 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
nope... I never heard about that rule for high powered engines.... let's see some examples....
Old Oct 4, 2006 | 09:02 PM
2K6E55's Avatar
AMGs
Good luck and we want PICS.
Old Oct 4, 2006 | 09:08 PM
06 E60 M5
Please show me proof that the M5/6 engine has an ECU that increases the output of the engine after XX miles
Old Oct 4, 2006 | 09:20 PM
rflow306's Avatar
2005 E 55
Very simple take your car with under 2000 miles and read the factory ecu. Then re-read the same ecu after 2500+ miles. Do your on research newbie.
Old Oct 4, 2006 | 09:31 PM
Jrocket's Avatar
E55
Really..LOL So at 3k the internals of the motor just up and add 30hp or so? How does it know how many hp's to "free" up,and when to start and stop the "freeing up" process?
06 E60 M5
I'll ask you to show me proof that my car has power limiting ECU for the first XX miles.
As for your other comment about the power gain not being mechanical, i guess you also got that one WRONG. The piston ring seal is really what the break in process is all about. As new rings are far from perfect and
they must be worn in quite a bit in order to completely seal all the way around the bore. With the gas pressure during the engine's first miles of operation, the entire ring will wear into the cylinder surface, sealing the
combustion pressure. Once the combustion chamber is absolutely sealed, the engine will produce more power.
Old Oct 4, 2006 | 09:36 PM
Jrocket's Avatar
E55
Gas pressure? You think these motors come that tight from the factory?
Old Oct 4, 2006 | 09:42 PM
OUTLAW///M3 SMG's Avatar
M3
derek- Even though you dont have the aewsome euro lc. If its the same as smgII. Use the burnout mode. (dsc off p500 sport I think it is. and floor it quickly) If you can do that. I get great launches using that with some ps2's. us lc sucks majorly. But its better then nothing. Have fun at the track!!
