Transmission Thud Question
Old Nov 16, 2006 | 07:35 AM
Vetluver's Avatar
SL 65 AMG and E63s AMG
I've noticed a few times in the last mos that when I accelerate vigorously and get to high RPM in first or second gear then abruptly shut it down that something makes the car feel like it's being hit in the rear.
This also happens sometimes when getting back on to the gas after braking hard.
It's seem to me that I remember something about the type a Trans that MB uses, lockup type? Is this normal? Please clue me in. Thanx
Old Nov 16, 2006 | 09:46 AM
Dogshine's Avatar
CLS55
if youre getting agressive with the gas, sometimes the tranny will do that. you will find its a rare thing for the most part in my experience.
Old Nov 16, 2006 | 03:17 PM
BMWEATR's Avatar
211 E55(sold) & 80cc shifter kart
just do what i do----- turn the radio up so you can't hear it!! lolololololol
then you don't have to worry about it.
Old Nov 16, 2006 | 05:46 PM
Vetluver's Avatar
I do that too! But bump in the back that's not the sub is bothersome. BTW I thought that the sub floppin around the trunk might be the thud at first.
Old Nov 17, 2006 | 02:06 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
How many miles you have? My CL55 has 51K, the behaviour you mention seems similar to the early issues I was having with the lockup on my torque convertor.
If you can duplicate the situation consistently, see if the technician can disable the torque convertor lockup why you drive the car to see if there is an improvement.
If you are higher miles like me, the first simple step is to change the tranny filter and fluid. I'm going to go out on a limb and let everyone know that that "lifetime fluid" stuff is bunk, change the fluid and filter at least at the 50K mile mark.
Old Nov 17, 2006 | 03:13 PM
newton22's Avatar
BMW E39
That seems to be a problem with many Mercedes models.
I get that too. I also get that when I'm driving very slowly in bumper to bumper traffic. And it only happens shifting from 1st to 2nd.
Old Dec 7, 2006 | 06:58 PM
Vetluver's Avatar
I have a follow up. The thud still is not fixed but has changed completely. The dealer upgraded the software for the transmission software and it now thuds much less but does it with lighter acceleration/deceleration than before.
One added bonus is that it changes gears much quicker and with more aggressive shifts. It acts like my old Ford C4 with a "shift kit". I've noticed that it grabs (yellow triangle flash) when shifting into 3rd and 4th on cold pavement.
I think that this is an area that aftermarket guys need to explore, I like the feel much better even though the slack in the tranny/differential still seems to be there.
Old Dec 7, 2006 | 10:09 PM
PerisanGodFatha's Avatar
is Sick as Fu*k
happens to me too...I think it happens when your in (S)mode...try doing that in (C)mode...the tranny is being jumpy in (S) so i think thats why it jumps like that when you stop punching it
