Tuner Customer Service reality check
My other half read your original post the day your issue happened and based on your statement that Greg's was loose but not as much as yours, he said that it sounds like the installer did not have the right tool/installation for the bolt and depending on how it came off there could be crank damage. It may be worth having a second set of eyes other than Creative look at your car regarding crank damage and then Greg's car or one of the others for proper installation. This is not laying blame on Creative but letting you cover all basis.
Did you do both pulley and ecu? I got confused with all the madness on the thread. I hope it gets worked out. If just pulley how did it perform before the issue? And if both pulley/ecu how was it?
Good luck!
Of course, the flip side is that for the price Renntech charges for their $125 in materials and labor pulley, you'd think they would include a new crank bolt with the pulley. It's not like it would undermine their net profit margin on the product or anything.
From what I hear the fastest cars are broken in carefully not those beat on from day one. That is what I was told by a MB and software tuner who will go unnamed =). He builds cars for these ultra rich oil vendors and said that they just race the living daylights out of their cars and he always breaks the cars in himself (slow for 1200 miles) before delivering them to the customer and that his cars are always the quickest. Just what I was told.
I agree fully. I have always broken mine in very religiously and I do have a freak!!
Generally the pulley mod should not lead to such issues.
Understand that this is just my opinion but I do believe that the problem Jangy has had is due to inproper install,not the pulley itself.On the good side of theis ordeal is that the installer is not turning his back on it,he seems to be right there trying to take care if this problem.That speaks alot too me.Hopefully the crank is ok and he doesnt get stuck with an enormous repair bill in the end.
435 at the wheels is perfectly believable, 545 at the wheels - not so believable.
Unfortunately, I won't be able to provide my own experience/data because I'm too cheap to take the depreciation hit that AMG's suffer in the early years.
I had an issue with them last year regarding a SEVERELY mishandled suspension installation that damaged components on my M3. I will not go through the intimate details publically, but they did "fix" the problem (fix being a loose term) but it was not to my (or any of yours, I guarantee) satisfaction. I deemed it a lost cause to pursue any legal action, considered it a failed experiment and swallowed the cost of the repair of the damaged components on my car by a honest to God BMW tech.
You want good faith work from RENNtech but there is NOTHING they can do. They dont have an obligation to resolove a mistake buy your installer. If they had installed the pulley on your car they would be responsible for the installation process. The buck stops there.
As for the dyno specs, you need to let these cars be driven before you get real power figures for the ecu and pulley upgrades. Throwing the car on the dyno to quickly is not the ideal course of action. You went out on a test run with your buddies before your ecu was done and your ecu was trying to learn how to deal with more boost and maybe was not running an ideal fuel map and the same goes for the cars with the ecu upgrade.
Get all the cars working correctly, and then do a dyno run two weeks from now and I bet all cars will be where they should be on power. You need to look at the delta value from stock to modded not car to car.
..........it is probably more accurate to say that some MB dealers are Renntech installers. Unlike the impression that frquently gets pushed in this forum, this is not unique to Renntech. Some MB dealers such as Atlanta Classic Cars are authorized Kleemann installers.
........Further, the above does NOT in any shape or form mean that Mercedes Warranties Renntech parts and products. Your Warranty is with the manufacturer of your car, not your dealer. Having a friendly dealer does help, but in the event of a major failure Mercedes sends a regional rep to come and inspect your car. Don't count on that regional rep joining your local Renntech or Kleemann fan club.
Ted
North area Benz dealer takes a swing at cha when mention mods. South side (my guys) try to talk you into doing the heads. Love those big lugs.
Ted
I had as good a relationship with my dealer as anyone here. They knew the car was modded, and at one time there was a reg. tech who had to look at my car for the stalling issue. Thank God, this problem was documented before the car was modded. I brought the car in with around 10,000 miles and both front rotors were cracked. They told me they would not warranty them because of the "chip" in my car, which contributed to the pre-mature wear. I'm still stunned to this day by that comment. I tried to reason that if you take two E55's, one stock, the other with a "chip" and run them from 0-150 the only difference is that the chipped car will get there a bit faster. Both, however still have to stop from 150. They didn't get it. I also told them the car was never tracked and the brake warning light never came on - obvious to me that the car was not abused, but that the brakes could stand up to how the car is marketed.
In my case I felt it was easier to just pay for the brake job.
And do u accept paypal?
