AMG63 R&D #1 (Free 18 RWHP)
Old Mar 28, 2007 | 06:06 PM
Thericker's Avatar
V12-Biturbo
Originally Posted by Vadim - SoCal
Well Ladies and Gentlemen, the time has come to unlock the secrets of this new, wondefull engine.
To establish the baseline, I used trezai's CLS63.
At 1000 miles he dynoed his car at another shop and, if I am not mistaken, ended up with 414RWHP on Dynojet 248.
After 3500 miles the car put down 424RWHP which is exactly what I was expecting it to do. Unfortunately, due to the lack of time, we could not find a way to pick-up rpms, so there are no TQ readings - only wheel HP.
While the car was cooling down, I took the airboxes off to examine them. The box size is a bit on a small side. Bigger design would be worth some power. More importantly I found an easy 18RWHP in them.
When you take them apart, besides stock air filter, there is another kind of filter - Charcoal (Please see first picture) - it's function is to keep vapor emissions from escaping through intake manifold and air boxes.
On E60 M5, which has the same filters, removing them was worth 12-17RWHP. So, out they go. Using a flat screw driver simply push the edge of the filter out from behind the tab and 10 seconds later it is out.
On the dyno, car went from 424 to 442RWHP an 18 HP gain, with a nice bump accross the whole curve.
So get your tools and get at it -
Thank you for listening.
Man that is soo kool! luv EZ free hp! they found nearly the same results w/C6 Z06 stock air filter change! gained 20 or so rwhp!
Old Mar 28, 2007 | 06:29 PM
Vic55's Avatar
Administrator
Originally Posted by Thericker
that's great! but you do realize 18rwhp = about 20 crank & every 100lbs knocks off a tenth .10 your 0-60 gains seem a bit unrealistic , but G-timers aren't perect, we need to meet up bro! gotta run
Meet this weekend? Saturday LA? Jangy, & Vic might be there 2
Lets just meet up so we can all say we had suds with the Ricker!!! Ill bring the 65-- wonder what the G tech will do for that?? I agree with you about G tech and in general 0-60 times dont mean much to me- trap speed is where its at.
Oh great gains!!
Old Mar 28, 2007 | 06:30 PM
Cops_h8_me!'s Avatar
C63 AMG (stock right now), Beach Cruiser (debadged), Piper Cherokee 280 (too much to mention)
risks?
Yeehaaaaa!!!
dumb question Vadim?? why do they put it there if it doesn't do anything other than restrict power?
am I 'risking' anything by removing this part? will dealer notice or be mad with me????
Just want to be certain...
thanks
Old Mar 28, 2007 | 06:37 PM
Thericker's Avatar
V12-Biturbo
Originally Posted by Cops_h8_me!
Yeehaaaaa!!!
thanks
No way is there any risk, original filter still there? and if worried about dealer, pop it back in b4 visiting stealership
Old Mar 28, 2007 | 06:38 PM
Thericker's Avatar
V12-Biturbo
Oh great gains!!
Yup! Yup!
Old Mar 28, 2007 | 06:45 PM
newton22's Avatar
BMW E39
Originally Posted by JLP
Probably not, you could lose 3-4 hp. Stick with paper and don't buy into the K@N BS hype.
I don't see how you can lose power with aftermarket filters?
Old Mar 28, 2007 | 06:46 PM
  #32
Kev04C320's Avatar
'09 911 C4S
It's for emissions control in Cali and the Northeast states.
Old Mar 28, 2007 | 07:31 PM
  #33
JLP's Avatar
JLP
06 E-55-95-F355S- 99 Porsche 911 C2 w mods
I know more than a few guys who have done before and after dyno tests with stock vs K@Scam and actually lost power. Don't believe everything you read.
There are many Porsche guys on Rennlist who can attest to a HP loss with K@N filters. Numbers don't lie.
Old Mar 28, 2007 | 07:42 PM
  #34
bocacls63's Avatar
07 CLS63 W/Maya 20"s - 07 Cadillac Escalade ESV
Very nice, free HP. Can't wait till I get my car back to try it.
Old Mar 28, 2007 | 07:46 PM
  #35
bocacls63's Avatar
Originally Posted by trezaei
Key in on position (but do not start car)
push throttle all the way down and hold for 5 seconds
turn car off (I also open and close the door)
Wait two minutes, start.
trezaei. What exactly does the throttle reset do.
Old Mar 28, 2007 | 07:56 PM
  #36
newton22's Avatar
BMW E39
Thanks for this info. I was just about to give K&N a try since my current filters are very dirty.
You're technically not resetting anything. The whole damn board calls it "throttle reset" because....well, I don't know. Essentially, these cars (all newer Mercedes) can alter and adapt shifting points and throttle response depending on how you drive. Nailing the gas in the turn key on position (the major step in this "throttle reset" procedure) simply fools it to believe you are driving it very aggressively and therefore optimizing shifting points and throttle response for maximum performance.
I'm still against calling it "throttle reset". But that's just me.
Old Mar 28, 2007 | 08:12 PM
  #37
2MANYCARS's Avatar
20+ to list......
Finally, you guys are catching up, I've said something about them many weeks ago in the ML63 section. I wonder how many hp my ML makes....
Here's the thread I posted about them back in January:
https://mbworld.org/forums/ml55-amg-ml63-amg-w163-w164/179301-did-you-know.html
Old Mar 28, 2007 | 08:16 PM
  #38
TopGun32's Avatar
very nice...
448RWHP is probably more than my ASP E55 is putting down... however torques can't be compared.
more and more I like the E63..
who is going to be the first 63 to visit the track without the famous charcoal filters.
Old Mar 28, 2007 | 09:30 PM
  #39
Thericker's Avatar
V12-Biturbo
Originally Posted by TopGun32
very nice...
It was 442 rwhp not 448
Old Mar 28, 2007 | 09:56 PM
  #40
tucsonbroker's Avatar
'15 E63S P30
Step by step instructions
Ok, this is a really easy mod. All you need is a torx screwdriver and some free time.
The first picture shows the air boxes, highlighted with the top two red arrows. There are two. Each air box has 5 torx screws holding it in place. The third picture shows one of the torx screws.
You can access 4 of the torx screws easily, but the fifth is hidden underneath the front plastic piece highlighted by the third arrow in picture one. I popped it up with my fingers. You can see it popped up in the second picture.
Once you have all 5 screws removed, lift up the box so that you expose the underside of the cover. I did not remove the box from the intake assembly, there is enough room to stick your hand in there and remove the charcoal filter. Just stick your hand in there, grab some fabric and tug on it. Comes right out. Put everything back in reverse order (except for the charcoal filter of course) and repeat for the other side.
Thanks to trezaei and Vadim for their pioneering work!
Attached Thumbnails AMG63 R&D #1 (Free 18 RWHP)-dsc00957.jpg   AMG63 R&D #1 (Free 18 RWHP)-dsc00958.jpg   AMG63 R&D #1 (Free 18 RWHP)-dsc00959.jpg
Old Mar 28, 2007 | 10:02 PM
  #41
MB_Forever's Avatar
E63 P30, CL500 Sport
Nice gains!!!!
trezaei and Vadim, these are very nice gains. Congrats!!!!
trezaei, do you have an ECU tune yet? This should get you another 20 rwhp...
Can't wait for my E63...
Old Mar 28, 2007 | 11:09 PM
  #42
Blue_Monster's Avatar
215
I just did this on the ML and also my bros CLS..
I havent driven the cls yet...
The ML sounds a little louder now.. I did a couple of 0-110 runs, and I can feel a difference. The ML churps a little now.. Its never done that before..
The powerchip and now this has made a Vast improvement.
Im just wondering if I should get the ECU retuned now? Since there is, Im assuming more airflow now..Either way.. thanks again for the info..
I remember 2manycars posting this before, just never got around to doing it..
But your dyno up top made me jump on this right away
Thanks again
Old Mar 28, 2007 | 11:46 PM
  #43
SAMSSONZ's Avatar
OO7 CLS63///G55TANK ///S80-T6///R1///R6
I am working on a set of high-flow filters.
HEY, THANX for posting,
and put me down for a couple of filters as well.
Old Mar 29, 2007 | 12:17 AM
  #44
PerisanGodFatha's Avatar
is Sick as Fu*k
do the 55`s have the grey filters? can the 55 guys do this mod to, or is it stricktly for the 63`s
Old Mar 29, 2007 | 12:58 AM
  #45
houston's Avatar
04 E55
It's that's the case, I wonder if these 63's do gain or open up the engine better as the milage grows.
I think this only applies to the 63's... Unless late model 06 55's started adding the new filters.
also, I think the ECU would adjust automatically or retune itself with more airflow
Old Mar 29, 2007 | 02:13 AM
  #46
is Sick as Fu*k
I have a 2006 E55...does anyone know if they have the grey filters for this year?
Old Mar 29, 2007 | 02:48 AM
  #47
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
No I don't have the ECU tune and to be honest not too interested in it. I have a feeling Vadim is gonna talk me into so we'll see. 20 more would be pretty insane. Ideally though this car could really be fun with around 500 on the wheel which won't be done without ECU (+headers +cat mod +bunch more stuff)
Old Mar 29, 2007 | 03:24 AM
  #48
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Curious of this mod would apply for EU / UK cars...
Old Mar 29, 2007 | 07:31 AM
  #49
OzE55's Avatar
2003 E55
Just undo the screws and look - but I doubt it. It will take 5 minutes to find out for sure.
Old Mar 29, 2007 | 08:29 AM
  #50
enzom's Avatar
2005 E55
Good find. The M5 guys on M5board have been doing this for a while. Amazing that the gains are so large. Really crazy.
