AMG63 R&D #1 (Free 18 RWHP)
I've tried your solution, disconnected battery and plugged it back in 15 min or so. CEL right from the start. Drove a little bit but it didn't go away.
Returned all to stock and going to a dealer tomorrow.
Another thing - i've installed LED's in my lids just about 2 days ago. They are also known for throwing a CEL sometimes.
Really wonder what diagnostics will show tomorrow.
I didn't touched the MAF. I've been doing filter swap for a while now to make this simple error, but who knows.
I am guilty of breaking a rule - never install different updates all at the same time (unless you have a diagnostic tool that is
)The Best of Mercedes & AMG
https://mbworld.org/forums/w211-amg/...ine-light.html
I don't remember exact code, but it was something "running lean" in both sides. There were no codes about LED's.
SO. I now can officially confirm that my CEL was caused by combination of removing charcoal filter and installing K&N at the same time.
I am not going to try and remove charcoal alone until I receive my ODB 2 diagnostic tool.
It too bad cause with the K&N's and no charcoal filters does give some extra nice power.
if u bring it to mb service u think they will make a stink about charcoals removed ????????????????????????
To establish the baseline, I used trezai's CLS63.
At 1000 miles he dynoed his car at another shop and, if I am not mistaken, ended up with 414RWHP on Dynojet 248.
After 3500 miles the car put down 424RWHP which is exactly what I was expecting it to do. Unfortunately, due to the lack of time, we could not find a way to pick-up rpms, so there are no TQ readings - only wheel HP.
While the car was cooling down, I took the airboxes off to examine them. The box size is a bit on a small side. Bigger design would be worth some power. More importantly I found an easy 18RWHP in them.
When you take them apart, besides stock air filter, there is another kind of filter - Charcoal (Please see first picture) - it's function is to keep vapor emissions from escaping through intake manifold and air boxes.
On E60 M5, which has the same filters, removing them was worth 12-17RWHP. So, out they go. Using a flat screw driver simply push the edge of the filter out from behind the tab and 10 seconds later it is out.
On the dyno, car went from 424 to 442RWHP an 18 HP gain, with a nice bump accross the whole curve.
So get your tools and get at it -
Thank you for listening.
I want to make sure the ecu will reset it self if I take out the charcoal filters and only run the K&N's!!! Can someone please help me
Have your dealer check and see if your 63 is under recall for intake manifold vacuum leak. Some cars needed new gaskets. That could explain the lean codes.
Good Luck!
