AMG63 R&D #1 (Free 18 RWHP)
Old May 26, 2009 | 07:01 PM
  #101
id64's Avatar
AMG C63, Merc C230, Audi A3
Originally Posted by gonzales25
So did the ecu reset it self? I have asked this before in a previous thread and no body replied. I am currently running K&N's with the charcoal filters in place, because I threw a CEL for the same reason "running lean" when I took out the charcoal filters.
I want to make sure the ecu will reset it self if I take out the charcoal filters and only run the K&N's!!! Can someone please help me
I don't think that it can reset itself since those codes were written permanently.
Old May 26, 2009 | 07:04 PM
  #102
gonzales25's Avatar
Slow
Originally Posted by Vadim @ FD
gonzales25:
Have your dealer check and see if your 63 is under recall for intake manifold vacuum leak. Some cars needed new gaskets. That could explain the lean codes.
Good Luck!
Thanks I will!!
Old May 26, 2009 | 07:34 PM
  #103
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Thanks I will!!
some cars just need to be driven for a while IMO . my truck had check engine light on it after long tubes and new exhaust . we tried resetting the cpu and it came back after a day . after driving it for a few months then we reset and never came back .
Old May 26, 2009 | 10:46 PM
  #104
LB63's Avatar
E63, S550
Just did it, no CEL I could feel the difference too, it pulls more in the top end.
Old May 27, 2009 | 12:39 AM
  #105
id64's Avatar
What exactly you did?
DELETE only or
DELETE and K&N?
I am not getting CEL with delete only
Old May 27, 2009 | 08:53 AM
  #106
Autoscope's Avatar
Former Vendor of MBWorld
E350 Sport & Rs6
Nice work guys! Is there still a screen infront of the MAF?
Old May 27, 2009 | 03:12 PM
  #107
gonzales25's Avatar
Slow
I thought the same thing, I was just worried about possible damage to the engine by running it lean. I know these mercedes engines are pretty picky from what I can see.
Old May 27, 2009 | 08:42 PM
  #108
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
from what i have heard running a car too lean has less risk of blowing a motor . This is coming from Ford guys so who knows lol . Also i reset the cpu today and once i got over 120 the light kicked back on . i think its because i have the air baffles opened up and im just getting too much air flow because under normal driving it does not kick the cel on .
codes coming up are fuel trim error bank 1 and bank 2 . meaning both intake boxes
Old May 27, 2009 | 09:08 PM
  #109
GHAZAN's Avatar
MBUSA
I think it's the opposite....leaner means higher pressure/heat generated in the combustion chamber and a greater chance of blowing the motor. Correct me if im wrong
Old Jun 3, 2009 | 04:08 PM
  #110
id64's Avatar
I've got my ODB2 tool yesterday and decided to try it again. First couple of hours - OK. Then as soon as I thought that I may be did something wrong first time - CEL. Same error codes about running lean, I can post full error report later. Cleared error, install stock paper filter with no charcoal - NO CEL.
Old Jun 3, 2009 | 04:52 PM
  #111
id64's Avatar
Exclamation CEL DETAILS
On
Diagnostic Trouble Codes
Generic Powertrain
P0171 System Too Lean (Bank 1)
P0174 System Too Lean (Bank 2)
Freeze Frame for DTC 171
Fuel System Status Bank One
Closed Loop
Fuel System Status Bank Two
Closed Loop
Calculated Load
19
Coolant Temperature
181
F
Short Term Fuel Trim Bank One
9.36
Long Term Fuel Trim Bank One
-11.70
Short Term Fuel Trim Bank Two
8.58
Long Term Fuel Trim Bank Two
-11.70
Fuel Pressure
51.76
psig
Intake Manifold Absolute Pressure
8.9
in.hg
Engine RPM
610
r/min
Vehicle Speed
0
MPH
Ignition Timing Advance for #1
12.0
deg
Intake Air Temperature
104
F
Air Flow Rate From Mass Air Flow Sensor
0.61
lb/min
Absolute Throttle Position
12
Enhanced Powertrain CAN
0745 Self-Adaptation Of Mixture Formation For Right Bank Of Cylinders Is At Liwith Value (At Idle Speed).Self-Adaptation Of Mixture Formation For Enrichment At Idle For The Right Cylinder Bank Is Above The Permissible Limit. (P0171)
2091 SummenError Der Selbstanpassung, Rechte Cylinderreihe
0749 Self-Adaptation Of Mixture Formation For Enrichment At Idle For The Left Cylinder Bank Is Above The Permissible Limit. (P0174)
2095 SummenError Der Selbstanpassung, Linke Cylinderreihe
Old Jul 7, 2009 | 09:54 PM
  #112
GermanCars's Avatar
2020 E450 Wagon
Any luck with your fuel trim faults.
By the look of the freeze frame data, the computer is correcting (taking fuel away) more in the upper ranges than adding at idle. We have found that a fuel trim code set at idle may be caused by a fault at part/full load. The computer can adjust the fuel trim in only one direction. If the computer sees an over rich condition at part load, it will move the fuel curve lean through out the whole range. That can cause the lean condition at idle. The real question is why is the mixture so rich at part-full load. Is the the mass air sensor seeing a large increase in air flow with the carbon filters removed and K&N's installed?
Old Jul 7, 2009 | 11:19 PM
  #113
NCE500's Avatar
2007 E63, 2006 C55
RE: Filter Mods
I removed my charcoal filters, replaced the (dirty) air filters with new OEM Mann units, and did the ECU reset.
My car runs noticably better across the RPM range, and pulls very hard to redline. No CEL or drivability issues at all.
This simple mod really woke up my car, for all of $26 for new air filters and about 15 minutes of time.
While I have not tried them, I think K&N may be overkill; clean stock filters appear to flow more than enough air for a stock engine.
Old Jul 7, 2009 | 11:35 PM
  #114
GermanCars's Avatar
2020 E450 Wagon
I don't care much for K&Ns. I once had one in a 535I. The outer rubber support melted and left the engine unprotected. Thats a bad thing down here. Florida is a big sand pile. I might use one in a race car but not on the street.
Old Jul 8, 2009 | 01:33 AM
  #115
LB63's Avatar
E63, S550
For those with lean A/F, just make sure you closed the airbox correctly. When I changed the stock filters I thought I closed the airbox tight but then I noticed pinging under load when I took it out for a drive.
I opened the hood and saw nothing wrong. The boxes looked fully closed and nothing was being squeezed. However, when I removed the lid on the airbox I saw that the part of the rubber/foam on the edge of the filter was pinched by the air box and the air box cover.
After seating it correctly the pinging went away. However, I never had a CEL with the pinging
Old Jul 8, 2009 | 06:43 AM
  #116
RNS-11Z's Avatar
09 C63
were do i get the tool to remove the covers for the filters? do mercedes sell them?
Old Aug 16, 2009 | 06:50 PM
  #117
Sincity's Avatar
I installed the K&Ns and removed the charcoals when the car was at about 300 miles. So far no CEL.
Old Aug 16, 2009 | 09:02 PM
  #118
id64's Avatar
I think that I've checked everything and I did it couple of times.
Old Dec 23, 2009 | 12:27 PM
  #119
julian14's Avatar
E 63 amg
Hi guys, i did remove the charcoal filter and drove around for 4-5 days with old air filter NO ECL then the K&N filter arrive and replace the old arif ilter and drove for about 50 miles and ECL came on. What do i do now?? replace the K%N with OEm filter or put back charcoal back in???
Old Dec 23, 2009 | 01:52 PM
  #120
LB63's Avatar
E63, S550
The fact that the CEL went on shortly after you put on the K&Ns shows that the K&N is the cause.
Replace the K&N with new stock filters and then reset the ECU. The CEL should go away after this.
Old Dec 23, 2009 | 04:03 PM
  #121
julian14's Avatar
E 63 amg
Thanks LB63, how due I reset the ECU do i have to take it back to mercedes dealer??, thank again
Old Dec 23, 2009 | 09:48 PM
  #122
LB63's Avatar
E63, S550
The instructions are in this thread https://mbworld.org/forums/w211-amg/...set-works.html
The Search button is your friend
Old Dec 24, 2009 | 07:04 AM
  #123
princemarko's Avatar
CL63, 2014 ML63, 2008 ML63, R500, GLK
Originally Posted by id64
Anyone with the Engine Light? I just did my C63 - removed charcoal filter, but I've added also K&N. After about 20 KM - engine light. I am going to put stock back on without charcoal. Will engine light go away in a bit? ( Damn, I miss my VAG-COM cable)
Take the KN's out. Put back your stock filters minus the charcoal ones. The MAF is faulting because of the K&N's. Its happened to me a bunch of times in different cars. Your engine light will go away after a couple of days of driving.
Old Jan 28, 2010 | 10:50 AM
  #124
urquattrogus's Avatar
1984 Audi Ur Quattro
Do we know if the charcoal filter is only fitted to US cars due to emissions regulations?
what about in the UK, this was certainly true with M5's (no charcoal filter in UK and or other markets)
Old Jan 28, 2010 | 11:22 AM
  #125
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
They actually have an entirely different upper airbox in the Euro models. Flows a lot more air and doesn't have the plastic lattice under the charcoal's, but they don't actually have charcoals...
