E55 Differences from 2003 to 2006
Old May 9, 2007 | 12:43 PM
Flight Test's Avatar
Buick T-Type, 70 cuda, S65 and a very FAST Truck!
Howdy, I am new to the E55 world and am looking at purchasing one soon. I read about how the options changed over the years but what else mechanically changed through out the production run. I did several searches and found little bits and pieces but no complete list. Were the options the same every year except 2003 with the NAV?
If anyone has a list of changes through out the years I would appreciate it.
I have taken a couple E55's out on test drives and now just need to find the color I want, with the right options. But before I buy I want to know what to look out for and what is available with all the years.
Thank you!
Old May 9, 2007 | 12:54 PM
MiamiAMG's Avatar
C63
No changes in the mechanics of the car. There are changes in the cosmetics, though. Not sure what they are exactly, but i think that the older models were missing the aluminum Pedals & steering wheel shift buttons, i could be wrong though. Maybe someone else here will be able to give you some better info.
Old May 9, 2007 | 01:09 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
E55 2003 to 2006 Model Differences
2005 and 2006 models had the following changes:
  • Upgraded Navigation with BIGGER screens
  • 200 mph speed gauge as opposed to 160 mph
  • Better suspension parts, mostly from CLS
  • Better steering rack, also from CLS
  • Slightly different supercharger clutch for smoother engagement.
  • Slightly different IC pump (this one I'm not sure about? )
  • Aluminum Paddles
  • Sliding Center Console
  • 2004+ E55s equipped with 'always ready' transmission buttons at the steering wheel. On the 03s, you have to press the transmission M/S/C button before the steering wheel buttons work ???? not sure about this one
Old May 9, 2007 | 01:12 PM
MiamiAMG's Avatar
C63
Interesting, other than the speedo, i had no idea about the other changes.
Old May 9, 2007 | 02:16 PM
Thank you so much. That is the type of information I am looking for. I have heard mention the 2005+ had an oil cooler, is that also true? Were the computers the same for all years?
Thank you very much for your time.
Old May 9, 2007 | 02:32 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
  • Aluminum Paddles
Couple more info:
  • Aluminum paddles are not standard for early part of '05 (build date 11/04 or 10/04 or before).
  • I think same case also for center console. Very early part of '05 (build date before 8/04???) still has clam shell ('03-'04) center console.
  • If equipped w/ pano roof, no solar panel for '05-'06.
  • All '03 don't have NAV (no option), except for Presidential series.
Old May 9, 2007 | 02:38 PM
jangy's Avatar
2015 S212
The "Rest" feature left after the '04 - '05 transition.
Old May 9, 2007 | 04:54 PM
zxlr88's Avatar
What is the rest feature?
Old May 9, 2007 | 05:08 PM
zoink's Avatar
REST is RESidual ... (not sure about the "T")
It basically allows the blower to pass the engine heat to the cabin for - I think - 30 minutes after you turn off the engine. It is only useful during the winter.... I almost never used it when I still had my W210.
Old May 9, 2007 | 05:26 PM
deaded's Avatar
2003 E55
  • Aluminum Paddles
I have a 2003 Presidential Edition. One to add is the 2003 e55 does not have a spare tire. It comes with a can of goo and an electric air pump. If you have a blowout you're just screwed and have to call for a flatbed tow.
I wonder about the bigger screen. I got in a 2007 e63 yesterday and the screen and NAV were exactly the same as mine. I did not measure but I was looking for any difference and did not see it.
Personally I like the clamshell armrest much better as it's really an armrest. The sliding center console does provide more room though.
The 'always ready' paddle shifters would be cool, but if they were always on I would have up or down shifted by accident a few times.
Old May 9, 2007 | 07:30 PM
jangy's Avatar
2015 S212
It also circulates cool air.
Old May 9, 2007 | 07:31 PM
jangy's Avatar
2015 S212
I've had an '04E500, '05E55, and an '06E55 and all three had the same size screen.
I like the clamshell as well and miss it.
Old May 9, 2007 | 08:06 PM
MB_Forever's Avatar
2003 to 2006 E55 Model Differences
Thanks for everybody's replies, this is a good thread for reference between the model year differences. I updated the list based on your responses, so it'll be easily summarized in one post....
2003 and 2004 E55 Models:
  • All 2003 models have NO NAVIGATION except for Presidential Series.
  • All 2003 models have NO Spare Tire.
  • The AC "Rest" feature left after the 2004 - 2005 transition.
2005 and 2006 E55 Models have the following changes:
  • If equipped with pano roof option, 2005 and 2006 have no solar panel.
  • 200 mph speed gauge as opposed to 160 mph.
  • Better suspension parts, mostly from CLS.
  • Better steering rack, also from CLS.
  • Slightly different IC pump (this one I'm not sure about? ) .
  • Aluminum Paddles.
  • Sliding Center Console.
Keep'em coming...
Old May 9, 2007 | 08:17 PM
aintME's Avatar
Mercedes-Benz
I forget...What year did they discontinue the puddle lights in the mirrors?
Old May 9, 2007 | 09:09 PM
BO55's Avatar
05 E55
I had an 03 E500 and it had a hepa filter in addition to the rest function. My 05 E55 doesn't have either one.
Old May 10, 2007 | 08:06 PM
Benz-O-Rama's Avatar
RESidual Temperature, maybe? Makes sense.
Old May 10, 2007 | 08:23 PM
DarkStar's Avatar
03 E55
Guys some of the '03 did come with nav. Many of the earlier ones came with the non-nav ready COMAND, that's what he means by smaller screen. All of the NAV-COMAND systems in the 211's are the same. Also, 03s come with puddle lights in the mirrors, the TPMS changed in 06? and there was mild decontenting each successive model year.
Old May 10, 2007 | 08:36 PM
dkallencat1's Avatar
This is not a option but the 03 and 04 have FREE services.
Old May 14, 2007 | 03:00 PM
What year did the Satellite radio option (SIRIUS) start? If it has satellite radio is it easy to see the antenna on the trunk, or is it integrated with the other antenna?
Old May 15, 2007 | 06:27 PM
crhait's Avatar
see sig
had TPMS in my 2003. could not order on 2006. miss it.
Old May 15, 2007 | 06:31 PM
zoink's Avatar
Are you saying that TPMS is not available for '06 or you just didn't get it?
I love my TPMS....
Old May 15, 2007 | 06:36 PM
crhait's Avatar
see sig
was not on the option list. dealer said all 2006 cars had to have it as standard equip. it is not on the car.
Old May 15, 2007 | 07:02 PM
dsc's Avatar
dsc
2004 E55
I believe in 2004. The antenna should be on the truck or on a long shot in the truck. It is not integrated with another antenna.
Old May 15, 2007 | 07:18 PM
DarkStar's Avatar
03 E55
Any model year with the COMAND that has a SAT button (all U.S. COMANDS) can have the factory SIRIUS setup. In some cases there is wiring necessary, I think in the 2006 w/pano.
Old May 15, 2007 | 10:47 PM
bfnnrgn's Avatar
SL65
No TPMS on the '06 model.
Also the front armrest/storage area on the '06 is different.
