In Manual mode fuel cuts at 6800 in 1st gear.
Old May 16, 2007 | 05:17 AM
Sean03S55's Avatar
07 SL550 / 07 E63 AMG
Hey guys,
I just got an E63 and found that in first gear and only in Manual mode the fuel cut is limited to only 6800 RPM, and the dash turns red and asks for an upshift before between 4500-5000 RPM. If I leave it in S it doesn't hit the fuel cut off in first but still wont shift at redline instead around 6700 RPM.
I don't know for sure if it's a fuel cut but it feels like a very violent hesitation as if the revs just hit a wall. Remember this only happens in 1st gear in Manual mode.
Does anyone else see this? or maybe somethings wrong with mine?
Old May 16, 2007 | 05:44 AM
sdsilverm3's Avatar
In Manual mode you need to hit the paddles to upshift otherwise you will hit rev limiter.
If you are hitting the paddle you need to do it sooner because of the electronic delay. Use S mode instead.
Old May 16, 2007 | 06:23 AM
AMG_55's Avatar
mymbonline
i noticed that on the 63 also, they dont let you get anywhere near 7k in first in s mode, dunno about M, but sounds reasonable considering its behaviour in S
they might be trying to preserve the tranny
Old May 16, 2007 | 11:07 AM
Bluemax's Avatar
15 S550 Daily 96 Dodge Viper GTS
Cool
My 63 does the same thing. Run it in sport and if you want to launch hold the left paddle for a couple seconds and you will be in first gear.
Old May 16, 2007 | 03:43 PM
Sean03S55's Avatar
I just wanted to make sure this was normal before doing any mods to the car. I don't want MB telling me that a simple ECU upgrade is messing things up or something.
Old May 17, 2007 | 01:03 AM
BlkE63AMG's Avatar
2012 SLS AMG
It is unfortunately normal and I don't think there is a way around it. Just had my engine software updated to start in 1st at all times and the issue still persists. Shifts in S and C are definitely better though. If anyone doesn't have it yet, get it from the stealership...
Old May 17, 2007 | 04:57 AM
Sean03S55's Avatar
Would you possibly have the invoice still that lists the Update version?
Old May 17, 2007 | 08:59 AM
xabo's Avatar
'20 S63
My invoice didn't list a version. Take it in and tell them that the car doesn't start out in 1st gear while in "S" mode.
Old May 17, 2007 | 03:54 PM
Sean03S55's Avatar
I'll do that. I just remember trying to get updates I was informed of perfomed to my older Volvos ECM and the dealer usually looked at me like I was crazy until I forced them to hook the car up to the terminal and check the ECM via satellite from Sweden, then they found all the required updates.
Old Jun 23, 2007 | 06:46 PM
amrlotus's Avatar
CL63 AMG
Angry My Cl63 AMG Manual mode fuel cuts at 6500 in 1st gear
I have exactly the same problem, and i think it is affecting perfomance 0-100km figures tried it is S mode actually max is 6500rpm in 1st gear,it is very intresting in manual mode 2nd gear goes to 7000rpm 3rd gear goes 7200 rpm why is this ,i emailed amg did not get any reply im taking the car to my dealer in alexandria - egypt to check what is wrong with it
Old Jun 23, 2007 | 09:47 PM
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
I just had the updated software and it does indeed shift at roughly 6,700rpm in 1st gear in any mode. Other gears though shift at redline.
Old Jun 23, 2007 | 09:58 PM
sack5000's Avatar
2015 AMG C63 S
What is the build dates of your vehicles? I have not experienced the problem and my car starts in 1st gear. I have an 11/06 build. When I punch on it in first gear it goes past 7,000 before the built in lag.
Old Jun 24, 2007 | 07:48 AM
05VENOM's Avatar
Good to know. My build date is 8/06. Had the tranny/ME reflash and car is fine. Seems that MB dealers have the ability to program the tranny at the dealers. Kind of like the aftermarket tuners. Interesting, don't you think?
Even though I am happy with the reflash, it still seems the car is trying to 'find' its perfect rhythm. Wish I could spend a day at the dealer testing and tuning.
Old Jun 24, 2007 | 07:57 AM
Ted Baldwin's Avatar
300ce
..........I wonder if this has to do with the low torque limit of the 7 speedtransmission. Perhaps MB is purposefully trying to protect the transmission. Otherwise it makes no sense since this is supposed to be a high revving V8 monster.
Ted
Old Jun 24, 2007 | 05:47 PM
amrlotus's Avatar
CL63 AMG
Angry
what is a tanny/me reflash please explain,today i took my cl63 to mercedes in egypt and the engineer showed me the software of ECU programming it is locked with a code that he does not know by amg of course .
anyway he told me he can do nothing about it !!!!
dont know wht i can do but im very unhappy with this frm amg !! waiting for their reply but from their website awkward entry fom that takes too long to type i think they will do nothing
Old Jun 24, 2007 | 05:50 PM
amrlotus's Avatar
CL63 AMG
Ted
dont think so as in 2nd and third ... it goes to 7300rm
