Anyone rigged the Intercooler pump to run constantly??
Old May 19, 2007 | 11:22 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Still having trouble with those IAT's at higher R's.
Cory had me running all the time with my old pump, but the installer went by the book on the EVO system and the pump is back to running by ECU.
Any idea how to rig the relay to run constantly. Just hoping someone out there has done it and can talk me through it.
Thanks in advance.
Jim
Old May 19, 2007 | 11:23 AM
jangy's Avatar
2015 S212
A write up would be much appreciated for those of us that have NOT gone to the IC kit yet.
Old May 19, 2007 | 11:53 AM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
+55
Old May 19, 2007 | 02:41 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Thanks in advance.
Jim
What heat exchanger are you using?
Old May 19, 2007 | 04:16 PM
BMWEATR's Avatar
211 E55(sold) & 80cc shifter kart
i THINK THERES A THREAD ON HOW TO WIRE IF YOU DO A SEARCH(i'm to lazy too)
Old May 19, 2007 | 04:56 PM
Jakpro1's Avatar
Cool!! Searching now.
It's an EVO cooling mod. Pretty sure after talking to VRUS that I need to burp the system and get that pump working constantly.
Old May 19, 2007 | 09:24 PM
Vadim @ FD's Avatar
S600TT, R350
I have my pump wired up to run whenever the ignition is turned on. This way the pump is always on when engine is running and I can also cool down the the intercooler at the track by simply turning the key.
So far no negative effects on the pump. It has been around 3 years and 60,000 miles so far.
Old May 19, 2007 | 10:27 PM
dsc's Avatar
dsc
2004 E55
Could you share how you did it, PLEASE?
Old May 19, 2007 | 10:48 PM
ChicagoX's Avatar
W211 E55
I have my pump wired up to run whenever the ignition is turned on...
Sweet!
Stock pump or Johnson ?
Old May 20, 2007 | 01:22 AM
Vadim @ FD's Avatar
S600TT, R350
I have Johnson pump. I simply ran a 30 amp relay that goes to a one of the fuses that is powered when ignition key is on.
Simply open up fuse box and find any fuse that is on when key is on and off when the key is off. Since you are just turning on and off a relay, current draw on that circuit is minimal.
Old May 20, 2007 | 02:00 PM
Jakpro1's Avatar
BAM!! Success!!
Think I have found out one of my major problems. Not sure why my guy did this, but the Johnson was hooked back up to the ECU and the relay was totally removed. (for those without the EVO cooling kit, a relay is added to the system for the Johnson Pump).
Relay is back in line with and rigged to open upon accessory turn on so she should be on continuous now.
Just need to tidy things back up and mount it.
FINALLY, we get to see what the EVO cooling kit can REALLY do with my IAT's.
Thanks as usual to VRUS for his knowledge that saves my life on a weekly basis and again thanks to Rudyrono for real time analysis.
Old May 20, 2007 | 02:20 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
ahh, so your relay is not just to find an alternative power source but to find a continuous power source. it makes much more sense to me now (should have read this thread before you called!).
if it does in fact lower you iat's, i wonder how well the oem (replacement) unit could hold up to a continuous switch?
Old May 20, 2007 | 04:03 PM
Jrocket's Avatar
E55
Originally Posted by rflow306
There is a large relay next to the actual fan which when grounded turns the fan on at max speed. Activated by grounding green wire below, ignition on.
The relays in the engine compartment are not marked so you have to figure everything out on your own. For the ic pump i have a three way switch, off, on and ecu controlled. Below is were the 12v ignition source is located. I ran a separate relay and power supply for the johnson pump. Hope this helps.
Heres some info.
Old May 20, 2007 | 05:48 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Awe cannot view those pics ... ?
And cannot find the original thread either...
Any pics guys?
Old May 20, 2007 | 05:50 PM
Jrocket's Avatar
E55
Try here Steve.
https://mbworld.org/forums/w211-amg/153570-stock-rwhp-numbers.html
Old May 20, 2007 | 08:34 PM
Jakpro1's Avatar
Sorry bout that Mike! I got off the phone with you and said, "I think I just totally confused this guy." Meaning I just don't know my terms on electrical.
Thanks for being patient with me.
Old May 20, 2007 | 09:26 PM
chiromikey's Avatar
lol, no problem! call me anytime and i'll do my best to confuse you even more.
i'm looking forward to see your next datalogging with the relay fixed.
Old May 21, 2007 | 04:55 AM
E55 RUSS's Avatar
E55K
BAM!! Success!!
Do WE need to do this with stock pumps as well ???
Old May 21, 2007 | 11:40 AM
vrus's Avatar
2003 E55 AMG
Hey Jim.. Awesome!! Glad you got it all worked out.
You will notice the car will run much better with the pump rigged to be on all the time.
BAM!! Success!!
Old May 21, 2007 | 12:02 PM
E55 RUSS's Avatar
E55K
Is my pump working all the time ???
Do I need to do it as well ???
If yes...please post full details of how can I do this by myself and what parts do I need ???
THANK YOU !!!
Old May 21, 2007 | 12:03 PM
dsc's Avatar
dsc
2004 E55
THANK YOU !!!
+1
Old May 21, 2007 | 12:09 PM
vrus's Avatar
2003 E55 AMG
If you are running a stock pump and want it rigged to run all the time its fairly simple procedure.
There are 2 wires coming off the pump. I believe they are brown and black.. BLACK is ground. The BROWN is the power trigger...
Disconnect the harness from the stock pump.. This will allow you to keep the factory connector intact.
Connect a new wire to the BROWN pump wire and run it up to the fuse panel that is shown in the pics above. Put an inline 15AMP fuse on it and splice it into the RED wire you see from Albert's pics.
Connect up a new wire to the BLACK pump wire and connect it to a suitable ground point.
That RED wire will have power when the car is in accessory or start mode. The great thing with this is if you are in the dyno room or staging for a 1/4mile blast, you can put the car into Accessory position and the pump will circulate fluid for you.
THANK YOU !!!
Old May 21, 2007 | 04:07 PM
phatmitzu's Avatar
2005 E55
Thank you!
Old May 21, 2007 | 04:48 PM
dsc's Avatar
dsc
2004 E55
Thanks Victor, maximus appreciatious!
Old May 22, 2007 | 03:45 AM
stevebez's Avatar
Vrus why splice into the red wire - when it seems that connector bolt at the back right seems to be an ACC point - may as well connect directly to this - or is this the +ve battery point?
To be clear we dont need an additional relay?
I think to make the mod completely reversable where can we get the harness plug for the pump? Is it a universal fitting or MB specific? ... may as well run all new leads from the fuse box and when the pump dies remove and go to MB for a warranty pump ...
Also is there any feedback from ECU that pump is actually drawing current when ecu switches it on?
