Renntech or Kleeman ECU for my E63?
Old 05-31-2007, 02:23 PM
Sean03S55's Avatar
07 SL550 / 07 E63 AMG
Hey Guys,
I'm trying to decide on the Kleeman or Renntech ECU for my E63. The Kleeman ECU is $1500 USD while the Renntech is a whopping $3500 USD. Renntech does claim a 10 HP and 10 ft/lb more than Kleeman's but I'm told Renntech is a little wild with their power claims. From previous experience with ECU tuning I realize that most of these "off the shelf" upgrades are pretty close and yield similar results. If I go the Kleeman route I can purchase tlhe lowering module and ECU together for less money than the Renntech ECU tune alone.
What do you guys suggest?
Also, does anyone know who offers the better lowering module? Renntech, Kleeman, Carlsson etc.?
SEan.
Old 05-31-2007, 02:41 PM
ROCKETW19's Avatar
06 EuroElites E55
renntech has the better lowering mod. for only 10 hp id wait it out some to see what others have to say. have you removed you charcole(sp?) filters yet? people claim 10hp just by that alone, best part its free.
Old 05-31-2007, 02:52 PM
Sean03S55's Avatar
I removed the charcoal filters on the same day I took delivery of the car. I didn't mean only 10 Hp from the upgrade, just that Renntech claims to make 10 Hp & 10 ft/lb more than the Kleeman tune. Kleeman claims 20 Hp & 20 ft/lb and Renntech 30 Hp & 30 ft/lb .
Thanks for the input... Why do you feel Renntech offers the better lowering mod?
Old 05-31-2007, 03:48 PM
ROCKETW19's Avatar
06 EuroElites E55
renntech has a digital loweing modual that can be adjusted on the fly! each front corner can be tuned the way you want it. its not that much money either. adam at euroelites was having a big sale on them awhile back not sure if he still is but worth a try.
Ted Baldwin's Avatar
300ce
......realize that those HP claims are at the crank. That translates to 16HP fo Kleemann and 24HP for Renntech at the wheels........that is if the tuners are not being robust with their claims. Not sure it is worth the $1500 for Kleemann, but I dont think it is worth the $3500 for Renntech. Getting more Hp out of a high compression Na car is always challenging.
Ted
Old 05-31-2007, 03:52 PM
ROCKETW19's Avatar
06 EuroElites E55
Ted
yes true the tuners always seem to use 93octane and here in cali we only have 91 so HP is not as much either. not sure in canada what octane you guys use.
Old 05-31-2007, 03:54 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Ted
+1, have to agree with you there Ted.
MiamiAMG's Avatar
C63
RENNtech, but then again i'm biased.
Old 05-31-2007, 04:19 PM
Sean03S55's Avatar
Whoever asked about fuel in Canada... We have Sunoco Ultra 94 octane all around here.
Adam,
Is the Sale still going on for those Renntech lowering mods?
Are you a dealer for Kleeman as well?
In your honest opinion, do you feel that Renntech would provide any more power gain over the Kleeman software?
Old 05-31-2007, 04:24 PM
MikeF's Avatar
03 C32 | 72 Porsche 914
pm Sent
Old 05-31-2007, 04:25 PM
jangy's Avatar
2015 S212
I would do some more research on the ECU before you decide. In the end, Kleeman vs Renntech is simply where your alliances lay.
As for the module, I'd like to clarify. The Airmatics (E55 / E63) are only adjustable at three points. The rear is done as a single, since there is only one sensor there. Also, the Renntech is NOT adjustable on the fly from the factory. That is only after a modification to the box or wiring harness (which is simple). However the part about the RennTech unit being the best on the market is very true because of the digital part. it is the only digital ELM for our cars as of now. The analogue ones can be suseptible to heat, etc. and will "float" from their set points at times. The digital one is consistent. Last thing, it retails for $1200, which is cheaper than the less worthy competitors.
Old 05-31-2007, 04:26 PM
jangy's Avatar
2015 S212
Oh yeah, we also have 100 octane gas here in Cali. All you need to do is mix it with your 91 to get what you want.
Old 05-31-2007, 04:27 PM
Adam,
Sean,
No, Renntech has been very strict on distributors lately so my hands are pretty tied up.
No, I am not a Kleemann dealer.
Both companies are reputable companies, with different products to offer. Since I am not a Kleemann dealer, i cannot claim that Renntech would provide a larger power gain over the Kleemann software. Did you get my private message regarding the 63 software?
Old 05-31-2007, 04:46 PM
ROCKETW19's Avatar
06 EuroElites E55
ya there are 2 places that sell 100oct so for me to get a ECU tuned for it would be crazy since i could easly get caught away from these places needing gas.
Old 05-31-2007, 05:16 PM
jangy's Avatar
2015 S212
Damn bro, that sucks up there. There is a load of them down here. That and deleting the speed limiter are the only reasons I wanna tune. I only want about another 6 degrees advanced. Other than that, the acr runs pretty pig rich anyway. I doubt I'll need the ECU tune before the TB install.
Old 05-31-2007, 05:17 PM
Rudyrono's Avatar
2006 E55 AMG
As far as the HP numbers are concerned, my Stage 5 dyno'd within 2 hp of R/T's published numbers and (484 vs. 486) and the torque was actually 5 ft/lbs. higher. I see that now they publish "flywheel hp."
Old 05-31-2007, 05:29 PM
jcjmw's Avatar
2005 E55 Wagon
Hey Guys,
SEan.
In my opinion, you can not go wrong with either. See if there are any Renntech or Kleeman vendors in your city or find a shop that has experience installing Renntech or Kleeman products on your car and visit them before deciding. Whoever you chose, just stick with that tuner. Have fun modding!!!!
Old 05-31-2007, 05:41 PM
Its better if the numbers come short.
Old 05-31-2007, 06:15 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Sean, just go with the sprint booster.... better throttle response is what you need..... save a ton of money... I had the kleeman ECU when i had my E55 and felt a little diffrence... spent 1k on it.... didn't think it was worth it at all... Just my opinion...
Old 06-01-2007, 12:16 AM
Korn55's Avatar
R231 SL
I say go for the Renntech ecu. I have been very happy with my ecu from them. No problems and my 63 feels a lot better than stock. Throttle response is much better and the added H.P. and torque is definatley noticeable. I can not say anything about the Kleeman ecu becuase I don't have it. Good luck.
Old 06-01-2007, 06:31 AM
Sean03S55's Avatar
Thanks for all the replies guys....
For the lowering mod I guess Renntech is my best option.
As far as the ECU goes I think I'll take my time to decide this one....
Someone mentionned the Sprint Booster, How does it feel when driving in slow traffic, does it get jerky and annoying? Also, about how much pedal travel do you think is dead now? Lastly, suppose I did want one how much do they cost and who sells them.
Old 06-01-2007, 11:44 AM
Rudyrono's Avatar
2006 E55 AMG
If you have a heavy foot you're going to notice the Sprint Booster in regular traffic. If you driver semi-normal in regular traffic you won't notice much of a difference. That was a pleasant surprise for me. There were some on the Forum that suggested putting the transmission in "Comfort" to reduce the jerkiness. Not necessary in my opinion.
Old 06-01-2007, 12:20 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Sprint Booster
Initially, it may be a little jerky (in slow traffic), but after a couple of days, your foot will get used to the feel of the sprint booster effect and so you'll be able to control it a lot better. Once you're used to it, it won't matter what kind of traffic you're in, you'll be able to drive as smooth as you want.
Warning: after using the sprint booster, you won't want to drive without it again...
Old 06-01-2007, 01:26 PM
The reason why I mentioned Sprint booster is because I originally wanted the Kleeman ecu to help with throttle response... It didn't help as much but with the S/B it did what i wanted for 1/4 of the price... 250-280 is what they go for.....
Quick Reply: Renntech or Kleeman ECU for my E63?
