*** VRP Extreme Belt Wrap Kit ***
Old 07-17-2007, 08:14 AM
  #126
Finny's Avatar
03 E55 AMG
Originally Posted by stevebez
Finny is the gates belt the Micro-V series belts ? I cannot find the "fleet runner" series?
It is a Micro-V type but it's probably marketed differently in Australia.
Here is the Gates link http://www.gates.com/automotive/dist...s_hd/index.cfm See how you go here.
This is their race type belts which are made the same way: http://www.gates.com/brochure.cfm?br...cation_id=5061 Same construction different color. Not sure if our size is available for this application.
Let us know if you find anything interesting...
Old 07-17-2007, 09:53 AM
  #127
E55 RUSS's Avatar
E55K
So no one installed this kit yet...common guys...I was expecting to some feedbacks by this time...
Victor...Is everything OK...my goods are ready ???
Old 07-18-2007, 02:36 PM
  #128
Jakpro1's Avatar
2003 E55 & 2014 GL550
Finny was spot on, as usual. No way to do it without fan shroud removal, which actually wasn't as bad as I thought (shroud remove)
Everything coming along. Got some errands to run this PM so hopefully have her back together Thursday.
Old 07-18-2007, 08:19 PM
  #129
vrus's Avatar
2003 E55 AMG
LOL.. Your "Goods" are ready.. sent you an email.. Check & reply.
Jim.. Everything go ok? The belt should have K080545HD printed on it..
Old 07-19-2007, 11:12 PM
  #130
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
We finished the installation, everything went to plan. However, the stumbling block was the belt.
Rocket's car has the Evotech 178 mm pulley.
I will keep you guys up to date after we complete our measurements and purchase a new belt.
Old 07-19-2007, 11:21 PM
  #131
Jakpro1's Avatar
I snagged both sizes larger. Their was a 55 and a 56. The 55 still wouldn't fit, but the 56 slipped right on. Gates Part# is K080560HD
Glad to hear everything went smooth!
Old 07-19-2007, 11:26 PM
  #132
Thanks Jim!!!
By the way how did your install go?
Old 07-19-2007, 11:57 PM
  #133
Post install pictures
Old 07-20-2007, 12:05 AM
  #134
ROCKETW19's Avatar
06 EuroElites E55
thanks bro!
adam looking good buddy, when is the new belt comming in? im verry curious of the final dyno.
Old 07-20-2007, 12:18 AM
  #135
Jakpro1's Avatar
Nice and smooth, just the belt issue.
Can't wait to see the dyno #'s. Funny, I am mostly interested in those A/F ratios more than hp.
Old 07-20-2007, 12:22 AM
  #136
Originally Posted by ROCKETW19
thanks bro!
Thanks bro!
We are awaiting some measurements from Finny/Vrus. Will probably get the gates belts tomorrow.
Adam
Old 07-20-2007, 12:38 AM
  #137
Zeppelin's Avatar
C32
Originally Posted by AdamG@EuroElites
Looks like the bottom right pulley is on backwards It probably works the same, just does not look right.
Old 07-20-2007, 12:39 AM
  #138
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
+1
Old 07-20-2007, 12:43 AM
  #139
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
What was the problem with the belt? I'm having mines installed on Monday.
Old 07-20-2007, 07:52 AM
  #140
SleeperX's Avatar
E55
Originally Posted by SleeperX
Can I assume that it will work on pullies bigger than 175mm. Lets say anywhere from 175-180mm.
Originally Posted by vrus
180mm??? Holy hell.. Would you like an external steam engine operated rotator arm to help turn that mother of a crank pulley???
Remember.. ASP pulley is 183mm measured from edge of raised lip to edge of raised lip.. 175mm is the measurement of the ASP at the grooves..
It should have enough slack to operate an extra 5mm.. but.. that is a bit too big of a pulley.
Victor, I thought I wouldnt' have a problem with a pulley that was anywhere from 175-180mm. Do I also need a new belt?
Old 07-20-2007, 08:12 AM
  #141
E55 RUSS's Avatar
E55K
Victor
I sent you an e mail 3 days ago from my other e mail...
Check PM please...
Hope I wont have any BELT ISSUES also cause Russia is no US or Canada....
I was unable to find Dayco belt for ASP pullies...Dayco doesnt supply such belts to European market...
We need to get this 100% right...and I need a spare belt for sure
Old 07-20-2007, 08:32 AM
  #142
Finny's Avatar
03 E55 AMG
Exclamation
For those that had a shorter belt "Sorry!".
I originally set this kit up for a 175mm pulley but didn't take into account the water pulley as it appears that these alter in size as well.
All belts returned to Victor will be exchanged for the next size up.
Again, sorry for the inconvenience!
Old 07-20-2007, 08:49 AM
  #143
E55 RUSS's Avatar
E55K
So which belt would I need for ASP pullies ???
Old 07-20-2007, 09:29 AM
  #144
SleeperX's Avatar
E55
Finny,
Can you tell us which belt size/part number we need. If it is only $20-30, it might make sense for me to just pick up a belt in the US, as opposed to having to deal with the shipping back and forth between US and Canada..
Unless of course Victor wants to put a new belt in the mail for me..
Old 07-20-2007, 09:43 AM
  #145
Finny's Avatar
03 E55 AMG
So which belt would I need for ASP pulleys ???
It appears to fit some but not others due to water pump pulley sizes.
Jakpro seems to have solved it by adding an extra inch.
As I said earlier, mine is a 175mm so it must be the water pump pulleys that vary in size.
Old 07-20-2007, 10:01 AM
  #146
vrus's Avatar
2003 E55 AMG
Frank... It looks like it depends on the water pump pulley.. If it turns out to be too short, you pick up a belt locally, I'll cover the cost and you can just ship back the one you are getting with the kit.
So far we know the following combinations DONT work:
- Kleemann water pump pulley + ASP Crank pulley
- Evotech 175mm pulley + Evotech water pump pulley
Finny,
Mike.. Never received anything in Hotmail.. I sent you back a PM.
I will get you an extra belt with the kit.
Victor
Check PM please...
Old 07-20-2007, 10:21 AM
  #147
SleeperX's Avatar
E55
Thanks Victor!
Old 07-20-2007, 10:28 AM
  #148
vrus's Avatar
2003 E55 AMG
Sooooooooooooooooooo ..... How are the Pythons doing???? I was waiting for an update in the airbox thread.... Someone has been slacking...
Thanks Victor!
Old 07-20-2007, 10:31 AM
  #149
SleeperX's Avatar
E55
Pythons are very nice.. Very well done. Thanks.
I haven't driven my car in weeks though, so I have no data to provide.. I will be putting the belt wrap on my car in the next week.. Then I will have some data to provide..
Old 07-20-2007, 10:54 AM
  #150
higginsbeach's Avatar
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Hey Victor,
Please send me the belt that should go an a COMPLETELY STOCK PULLY set. As you know, I have stock pully's and will not upgrade until later. At the point in time I upgrade, I will consult with you on which size belt to get or others on the board who have already installed. Now everyone get them on and update us ALREADY!!!
Roland
Quick Reply: *** VRP Extreme Belt Wrap Kit ***
