*** VRP Extreme Belt Wrap Kit ***
#176
I don't have any pics right now as the car is still with my tech and hopefully getting dyno'd this evening.
The issue with the tensioner was due to the fact that the belt was nearly too short to work with my ASP pulley, but he DID get it on. The tensioner is nearly bottomed out (completely "back") and, as such, there was not enough room for the secondary tensioner to be installed as the "arm" on the secondary tensioner could not be adjusted "short" enough to fit into the provided space. The belt has already appeared to stretch a bit (judging by the positioning of the stock tensioner) so after a few miles are put on the car, we will reinvestigate the installation on the secondary tensioner.
As far as the engine cover being notched, the upper tensioner pulley on the passenger side of the motor was extremely close to the cover, necessitating a small notch in the plastic to provide satisfactory clearance between the tensioner pulley and the engine cover.
I'll post some pics as soon as I get some.
#177
2003 E55 AMG
OK.. Now it all makes sense... he tried to squeeze on the 54" belt which we discovered is a problem..
We tested everything with a 175mm pulley but for some reason the ASP is setup differently.. Can you get the tech to order a GATES Part #K080560HD
belt.. This is a 56" belt which will take care of all your problems. I will reimburse you for the belt.. just ship me back the one I sent you.
Good luck Don! Let us all know how it goes on the dyno.
#178
It's not a problem, Victor. The belt you supplied DID fit, it's just very tight. There is a very minor amount of play in the tensioner, which we expect to increase slightly as the belt stretches with use. As of right now, I am fine with that belt.
#179
2003 E55 AMG
This brings up a very interesting question....
Everyone that had trouble with the belt length of the 54" supplied belt... When you went to install the belt, did you release the nut on the tensioner bolt and unscrewed it all the way so the tensioner would release and the pulley could move all the way back/up??? This would be required in order for the belt to have enough slack to get around the snout of the S/C...
Is this the procedure you guys used to fit that 54" belt?
#180
2003 E55 & 2014 GL550
This is a pic with no tensioner bracket installed and me pulling pretty hard on er. Wish my engine was a clean as Vadims!! Wow, do I need some degreaser.
Edit...maybe the 2nd pic shows it better how far I still needed to go.
#183
When the belt is installed the idler position should be "Mid" way or slightly further to help promote wrap and accommodate stretch.
This point is between Lock position and Stop position.
#186
06 EuroElites E55
#188
#189
06 EuroElites E55
im 2 hours away from it so i dont know.lol. my butt dyno is way off anyways i couldnt even tell after the pully and ECU. i will goto the track where i felt the power drop at 80-90mphs also my time slip will show me what it did.
come on guys do this already dont be scared. if there is a problem you wont know right away so why wait for the next guy to go first! belive me if oliver was here today my car would be at the dyno right now, and at the track tonight.
#190
S600TT, R350
Got Venom-AMG kit installed. Very nice kit!!!
The install is fairly starightforward, it was with ASP pulley so we had to use 560 belt.
Using NOLOGY PDA, boost is nice and even at 15 psi.
It will go on the dyno next week, so we will get a better look.
#191
Just got my car back from Vadim and man is she more fun to drive now. I hit 150mph on the way home without breaking a sweat. I cannot comment on the Wrap kit because I had the asp pulley installed at the same time. I do think the kit works because I definitely feel alot more low end power. The power feels constant throughout the power band, there's no drop off point from what I can tell. But I have to say the kit looks great. Great job Vic. I'll have her dynoed next week
#192
2003 E55 AMG
Glad everything went well...
15psi constant huh... Hmmm... Do you know what that means Vadim??? It means kit price goes up $200 right after your dyno sheet gets posted... LOL... j/k
Looking forward to the dyno feedback. That will end all the speculation.
I will pass along your big thanks to Finny also.. he worked his butt off to make this happen.. In the end, we just want to make sure it is working for you guys and it does what it is supposed to.
Enjoy the new found power!
Originally Posted by Venom-AMG
Just got my car back from Vadim and man is she more fun to drive now. I hit 150mph on the way home without breaking a sweat. I cannot comment on the Wrap kit because I had the asp pulley installed at the same time. I do think the kit works because I definitely fell alot more power low end. The power feels constant throughout the power band, there's no drop off point from what I can feel. But I have to say the kit looks great. Great job Vic. I'll have her dynoed next week
#193
Thank you Vadim for helping me with everything and answering all my questions. If anyone is looking for a shop I would like to highly recommend Vadim. The shop is beautiful and so professional. Man when I was in the shop it made me want to pick up a porsche. Once anyone walks in there you will know what I mean.
#194
S600TT, R350
Looking forward to working on future projects with you.
#196
Viper/Z06/E55/GT500
So whats the deal with this mod?
My dyno sheet shows what Victor thought was belt slip. Im waiting for someone with a dyno-sheet like mine to do this mod to see if it works. Anyone finished and dyno yet?
Jason
Jason
#197
06 EuroElites E55
no offence, but you want us to do something your to scared to do?
#198
Viper/Z06/E55/GT500
None taken
What I want is to know if I have a belt slip issue. I did not think I had one. I thought the a/f dropping was due to heat issue and computer dumping fuel.
So before I start throwing money at a problem that I don't know even exist, and since Victor sold out of his first run of pulleys, I thought someone would have some answers.
I don't remember ASKING for anyone to buy these parts, I was just asking for all the people that DID, if it has solved any issues for them.
Ok with you Mr. ROCKETW19
