I Cannot Stand Driving My E55 Anymore!
Old Aug 3, 2007 | 03:20 PM
DoctorXylophone's Avatar
Bently Continental GT
deleted
Old Aug 3, 2007 | 03:25 PM
X55's Avatar
X55
2001 E55
How about a run on a dyno to see what power the engine is putting out then going from there?
Old Aug 3, 2007 | 03:32 PM
AMGcrazy's Avatar
2008 E63
If you give the guys on this board some detail about what the car is doing, we can certainly steer you in the right direction. The most common problem among our cars is the IC pump failure. It is typically intermittent, so usually no codes will be thrown. Do a search on IC pump and you'll have more than enough information to take to your dealer and demand they change it. If that is not it, trust me your car needed it anyway! Dyno results would also help!
Old Aug 3, 2007 | 04:21 PM
Fantasm's Avatar
Car Whore
IC PUMP!!!! WARRANTY AND GET YOUR SPEED BACK!
Woohoo... be happy because its an easy, fast fix and you will have your POWER back!
The IC Pump, WILL NOT throw codes, so the dealership will miss it, especially if the guys there are clueless about typical 55k problems -- like the ever popular intercooler pump failure.
Fully covered by warranty, call the dealership now and get that bad boy fixed up today!
Old Aug 3, 2007 | 04:40 PM
StevesAMG's Avatar
03' E55, 06' Kawasaki ZX-10R
i think a lot of forum members are misdiagnosing these power loss issues as IC pump failures.....
The issue with the IC pump failing is that the air intake temperature will rise....once the air intake temperature exceeds ~225 degrees, the computer will disengage the supercharger. However, the intake air temperature must first reach 225 degrees. Until this happens, the supercharger should be engaged and the car should be at full power. It should take several minutes from a cold start for the temperature to rreach 225, and when this happens, there will be a dramatic and immediate decline in power.
That is not what he is describing. I have had my SC shut off before and when it happens the car is dog slow......
His car is still fast, it's just clearly not where it should be.
there must be another issue haunting these cars and i wish we could diagnose it, as several people have been reporting this problem to the board and the overwhelming answer is always "check the IC pump"....However, i think it is something else.
Old Aug 3, 2007 | 05:01 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Rudyrono claimed an incredible difference in power with just new supercharger belt. Slipping belt will make her run pig rich right guys?
Worth a shot. See if the stealer will put one on for you. Takes about 60 seconds tops with a tech.
Betcha it perks up nice.
Old Aug 3, 2007 | 05:05 PM
NGS_E55's Avatar
2013 CLS63 2004 S55
My wife's 350z seems to have lost some uummph so I just ordered some new plugs(ngk Iridium) and will be checking that the K&N air filter is not obstructed.
Old Aug 3, 2007 | 05:16 PM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
It's simple:
FIND ANOTHER DEALER. Either these guys are idiots or they don't care, or both.
Old Aug 3, 2007 | 05:19 PM
Jrocket's Avatar
E55
Originally Posted by DoctorXylophone
That day I ran a best of 13.5 @ 103 and there was a Kleeman S2 E55 there that ran 12.1 @ i forget as a reference, there's no way my car should be running a WHOLE second slower.
Your car is stock,correct?
This is my take.Your IC pump is failing and the weather at the track that day was terrible.12.1 for a K2 car is a perfect example.
Another thing,dont even judge your car against another car on the street.Unless you know the person and the car.You will never know what the other guy might have done to his car.Some of my cars look and sound completely stock,but are far from it.
Old Aug 3, 2007 | 05:59 PM
StevesAMG's Avatar
Is it possible that you may have a slipping belt without any signs of wear? From what i understand from other members, when a belt is slipping the belt will appear frayed and there will be residue accumulating from the belt wearing down. Any thoughts?
Old Aug 3, 2007 | 06:15 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
The infamous ECU flash?
What about comparing your recent time slips (13.x) w/ your old ones (12.x)?
There is a thread in which a member asked why he got worse time after some mods... and looking at his 60' time, after the mods, his car puts more power and he seems to have traction issue that caused ugly 60' time and worse 1/4.
It's all just a guess...
Old Aug 3, 2007 | 06:23 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
sounds like the IC pump..... you're probably getting full power through gears 1 and 2, then it gets hot and shuts down the supercharger..... replace the pump and you'll love the car again....
Old Aug 3, 2007 | 07:18 PM
jmf003's Avatar
'03 SL55
What can i possibly do?
Buy or borrow an auto logger such as this one: http://www.autoenginuity.com/
You'll be able to check the IAT (intake air temperature) yourself. If it's high, you'll be able to show the log file to MB.
My car was running a little slow and inconsistent (12.5 - 12.9) relative to the mods I have installed. I suspected the intercooler pump was failing and took it to the dealer. No error codes, though, so no pump replacement. The SA suggested the problem might be supercharger belt slip.
On my most recent trip to the track my times got quite a bit worse: back-to-back 13.2s. But this time I had the data logger attached and was tracking the IATs. They were 205 F at the start of the second run and reached 266 F at the end. Way too high.
I provided that info to my dealer yesterday and am hoping and expecting them to replace the pump.
Good luck to you! Don't give up yet!
Old Aug 3, 2007 | 08:24 PM
EUROTEK//AMG's Avatar
German
wana trade ? ....trade it in for 65 and call it a day.
Old Aug 3, 2007 | 08:37 PM
jangy's Avatar
2015 S212
Get a dyno run done with A/F ratio. That will lead you in the right path. If you are running rich and having fuel dumped, then slip is a thought. I agree with a previous poster that the IC pump has been the wrong diagnosis on many. When that happens it is an instant night and day.
Old Aug 3, 2007 | 11:31 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
E55 Slugish Performance ???
I would chase after the IC Pump diagnosis first since it is so very common problem with these cars, and fortunately, a very easy fix.
If that does not solve the problem, then invest in a data logger and start logging data, which (believe me) will become very important in pin pointing the problem if the issue is bigger than an IC pump or a transmission software flash.
Also, try another dealer for a second opinion.
Good luck, and keep us updated...
Old Aug 4, 2007 | 02:53 AM
deleted
Old Aug 4, 2007 | 03:00 AM
deleted
Old Aug 4, 2007 | 08:04 AM
WayneE's Avatar
'72 Suburban
Don't give up, Doc.
For a dyno, I don't know how far from you but these guys know their **** - http://www.eastcoastsupercharging.com/contact.htm
Good luck.
PS - beautiful color and tint
Old Aug 4, 2007 | 09:11 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
I know your gonna find the problem.
There are a bunch of good guys here who can steer you in the right direction.
Most experience the IC pump failure.
An upgrade I noticed several doing is switching to the 2k6 S/C clutch pack and new Supercharger belt if you have not done so or if your car is an earlier yr.
By all means chg your S/C belt regardless.
Old Aug 4, 2007 | 10:22 AM
Can Drive 55's Avatar
2005 E55
Doctor, good luck with my twin , what ever you do.
Old Aug 5, 2007 | 11:45 PM
Marcus Frost's Avatar
Real Cars
Steve,
I was one of the first guys to diagnose this problem with my previous '03. The tricky issue with the IC pump is that it is not a complete failure. I haven't been able to see a failed pump but what I can tell you from my '03 is that it was a gradual failure over thousands of miles with symptoms much like the Doctor here is having. After a while the supercharger started disengaging altogether and that's when I was sure something was up. Sure enough my tech took a look and found the problem right away - got the car back and she was flying again.
Doctor - I'm almost certain you have an IC pump problem and an incompetent dealer. I'd contact DSMed on the forum - he's my tech and can give you a bit more insight into what you should tell your tech to do to find the IC pump codes through STAR. If you need any help contact me via email I'd be more than happy to help you.
-m
Old Sep 15, 2014 | 06:17 PM
KleemannE55's Avatar
E55
Was this ever solved ??? I'm having the same issue & it is 100% not the ic pump
Old Sep 15, 2014 | 11:32 PM
fastlanetl's Avatar
2007 E350
Talk about reviving an old thread! 7 years! Good Luck with your issues though!
Old Oct 4, 2014 | 02:33 AM
E55
Anyone ??
