My car jumped off the dyno-SCARY!!!
I put my car in DYNO MODE, we strapped the rear suspension to the dyno machine, no blocks under the front wheels (front rollers).
First run: in 4th we exceeded the DYNO's pre set maximum speed of 200kph/125mph. Tech did not know how to increase the speed limiter on the dyno!
Second run: in 3rd, my car accelerated with so much torque that it jumped out of the rollers! The tech jumped on the brakes instantly and the strapping gave him the extra split second to react. Otherwise, he would have gone straight through the fan and into a Subaru parked against the opposite wall!
Needless to say, he wasn't game to try again...
Has this sort of thing happenned to anyone else?
On a positive note, even though I did not get the maximum power reading,
due to 4400RPM/125mph dyno cut-out, my maximum torque at the wheels came in at a decent 600Nm/443ft-lbs or 723Nm/533ft-lbs at the crank,
which is not too shaby for a stock car with Green Filters.
I did have the tires break loose one time and I had the feeling it was coming off,but I just rolled back the throttle and took a deep breath of air.
How do you guys get maximum power reading in 4th at 6100RPM, when the speed of the car in 4th at those revs would be 177 mph? The car is limited to 155mph!
In 3rd it will hit the rev limiter before it hits the speed limiter at 132mph/6500RPM.
Or maybe the DYNO mode removes the speed limiter?
It they needs 4 stronger CAMS which cost around 4k each for the machine to be able to run faster then 125...
Rafal glad to hear no damage was caused.
In regards to your first question, yes it has happened to me before and was very scary. To make a long story short, I usually strap my own car and forgot to lock one of the ratchet straps at the rear of the car. On the third pull the strap pulled out and the car jumped of the rollers enough to hit the fan in front and almost made a complete left turn into the wall. Thank God nothing else happened and the small marks on the bumper buffed out. Moral of the story for me was don't become complacent, always double check your straps and chuck the front wheels. The chucking of the front wheels is actually the most important thing to do imho (ie 2wd dyno), with the chucks in place the car will not come of the rollers even if all the rear straps came off.
As far as the speed limiter it can only be removed by ecu flash. Dyno mode will not remove the speed limiter.
I still don't know how everybody runs in 4th gear to maximum power at 6100RPM? This car hits the 155mph limiter in 4th at 5500RPM which is not its peak power!
