Supercharger for AMG 63s (M156)
#176
You can already make a rediculous amounts of power with a Kenne Bell charger, why make things more complicated by adding a turbo? Look at all the cobras with kenne bell chargers. You can't just make more and more power without making major changes (engine internals, fueling, stand alone engine management, reinforced axles, built trans/diff, etc etc). There is a reason why Vadim plans on running low boost.
#177
#180
a car that gets very poor gas mileage.
I know you guys (VRP) have several projects progressing together simultaneously, but it's been a month now without a word.
Has there been any new developments here?
#181
S600TT, R350
As soon as I have something new I will post it.
#184
S600TT, R350
Just set up a 24 hr web cam of your shop so we all can get our daily fix of VRP madness.
#186
S600TT, R350
That would be awesome! A reality show based on your shop, filled w/day to day minutia, throw a couple tirades like Pual Senior (O.C Choppers) & you got hit my man
#187
Could the 7-spd tranny handle that kind of hp/torque?
Because with 6psi of boost we can probably make a nice 600 - 650hp car on stock internals and boltons.
Stage 2 of same setup will be with a BUILT bottom end with hopes of reaching 800hp++... The CLK63 BS Cabriolet that we are building will end up with this configuration when we are done.
On the 55, changing the blower for a bigger one is about as challenging as pulling the blower and replacing it with a TT kit.
You have to get around the electronics for the bypass valve, the supercharger clutch, the programming in the TCU, etc, etc.
If the ECU sees boost during shifts it will go into limp mode. On a normal 55 car, the ECU disengages the clutch, shifts gears, and then re-engages from what I was told. All of this leads to big programming challenges..
It's not to say that SOMEONE isn't already working on a blower replacement though.
#191
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
#193
S600TT, R350
I truly think that the greatest russians of mankind history are
-Fedor Emelianenko
-Vadim federovsky
-Fedor Emelianenko
-Vadim federovsky
Vadim - Any updates on your progress ?
Also, have you considered doing a twin turbo setup for the 63 motor ?
I will post updates ASAP.
My oh my!!! (Praying) Please be reliable and affordable!!
#195
Former Vendor
Any AMG Thats Around..
I'd Be down with that... lol.. Send him my info... it better be on cable tho, or there will be alot of bleeping out stuff....
#197
CLS63
