Some of you asked if my big heat exchanger made a difference...
..........I have had a few Kleemann cars with and without issues. The advantage of the low boost set up for the Kleemann s/c's is of course because of the high compression of the engines. However, it turns out that the low boost set up is the only protection you have for your engine. There is no feed back mechanism to tell the engine when to pull timming, dump fuel etc. You have a boost sensitive fuel pressure regulator, but nothing that responds to your iat's. regardless of how hot your engine is, the s/c delivers the same ammount of boost. you can install a temp sensor yourself post s/c and read it yourself but it is not integrated into the engine's electronics and not useful for engine protection.
Ted
Ted
none
Ted
Ted
I would like see what type of IAT's a non factory supercharged M113 makes for comparison sake.
Ted
Ted
Website:http://www.splitsec.com/index.html
I would also look into the MAF conversion kits so that the N/A cars can be setup like the E55k cars.
there is a guy here on MB world named Gregc who has installed the timing device on his S/C CLK55 with great success!
