RENNtech intercooler kit upgrade installed...
Old Sep 7, 2007 | 04:12 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
My car had lost it punch in the lower gears towards the higher RPM's and after a burst from 0-110 MPH would have the supercharger shut down for 5 minutes or so until things cooled down. Typical symptoms of intercooler pump failure. Instead of taking it to the dealer for the same bum pump replacement I took the car to RENNtech and had them install their upgrade kit which includes a new, much larger pump, and an additional intercooler.
The problem was the pump, we put the old pump on a test bench and tried to power it up and nothing happened. On the test drive the low end grunt is back, and the car pulls hard on the top end. It's nice to be able to repeatedly hammer on the car without losing power, even in 95 degree weather! I attached some pics....
Attached Thumbnails RENNtech intercooler kit upgrade installed...-e55-intercooler-pump-upgrade25.jpg   RENNtech intercooler kit upgrade installed...-e55-intercooler-pump-upgrade27.jpg   RENNtech intercooler kit upgrade installed...-e55-intercooler-pump-upgrade24.jpg   RENNtech intercooler kit upgrade installed...-e55-intercooler-pump-upgrade26.jpg   RENNtech intercooler kit upgrade installed...-e55-intercooler-pump-upgrade28.jpg
Old Sep 7, 2007 | 04:23 PM
ROCKETW19's Avatar
06 EuroElites E55
nice! i bet it feels like a new car.
i think there kit is very clean, alot nicer than the EVO kit but it does cost more also
Old Sep 7, 2007 | 06:05 PM
jangy's Avatar
2015 S212
How was the service?
Old Sep 7, 2007 | 06:50 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Welcome to the low IAT familyyyyyy!!!! Beautiful thing isn't it.
Just wondering if they rigged it to run all the time, or just per ECU. (I noticed a HUGE difference when I ran mine off acc power)
Trip finally seeing the inside of Renntech. After all you hear about them, you think it's gonna look like the SLR factory inside....
Would love a nice set of those "white boxers" above his head though.
Old Sep 7, 2007 | 07:01 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
RennTech Cooling Upgrade For E55
Does this replace their SLR style inter-cooler upgrade? Or do they offer two different cooling upgrades?
Old Sep 7, 2007 | 07:10 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
they have two type. this one mentioned here and the slr type ones.
hmm is the rentch pump better then the johnson pump or the same?
also the cooling kite shown here, what does it differ in respect to the evo sport one?
thanks
p.s grats on the install and fixing your car AIT problem, looks nice
Old Sep 7, 2007 | 07:13 PM
areuv's Avatar
2005 E55 drowned/ 2011 CTS-v coupe gone/ 2012 E63 PP,LSD finally here
this is just an additional heat exchanger up front and upgraded pump, the SLR intercooler upgrade is just that, the intercooler at the S/C is upgraded, side by side intercoolers, this upgrade is seperate from the SLR intercooler upgrade
Old Sep 7, 2007 | 08:24 PM
jangy's Avatar
2015 S212
SAME
Fit of the added intercooler. The RennTech one is not as big, so it doesn't protrude into the mesh at all.
thanks
Hope that helps
Old Sep 7, 2007 | 08:26 PM
MBzHeezie's Avatar
w211
oh wow nice, looks awesome man!
Old Sep 7, 2007 | 10:05 PM
Jrocket's Avatar
E55
How much was the kit and labor for install?
Old Sep 7, 2007 | 10:11 PM
GoDav AMG's Avatar
E 211
Thumbs up
Old Sep 7, 2007 | 11:55 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
service was great, I had an appointment for 9am, when I arrived they were working on the car within 10 minutes and had it done in a couple hours....
Old Sep 7, 2007 | 11:59 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
yea, I meant additional heat exchanger..... the renntech pump is not the same as the johnson pump....
I haven't seen the evo kit, so I'm not sure of the differences....
thanks
Old Sep 8, 2007 | 12:07 AM
BrianS's Avatar
2004 E55 AMG
What's more efficient, a single-pass heat exchanger like Renntech or double-pass like the Evo unit? Assuming both are fabricated using the same tube design.
Old Sep 8, 2007 | 12:10 AM
Fikse's Avatar
STS,FGT,12C,P85D,M4
They programmed my ECU to turn on the pump earlier than normal, but it's not on all the time....
There was an SLR in the next bay over and an S65 on the dyno.... You should see their other areas, they have quite a setup in the other rooms where they do their machine work and production....
Old Sep 8, 2007 | 02:14 AM
dmhW211E55's Avatar
2005 Mercedes-Benz E55 AMG
I so need one of these. What made you go with renntech over evosport?
Old Sep 8, 2007 | 12:36 PM
jangy's Avatar
2015 S212
Why RT over EVO? I would guess because he got RennTech to install it. I wouldn't buy ANY RennTech on the west coast until you find someone that you really trust to do the install. I'm not sure exactly what criteria, if any, RennTech puts on its distributors with respect to using qualified technicians.
Old Sep 8, 2007 | 12:41 PM
Vadim @ FD's Avatar
S600TT, R350
Have you seen evosport cooling kit?
Old Sep 8, 2007 | 12:45 PM
ROCKETW19's Avatar
06 EuroElites E55
yes i have you post a big picture of one of the parts i hate most. thebig fake steel braided lines. renn has a nice solid tube very clean lookin. also do like the way the exchanger looks. renns looks better here also.
no of coarse you or most people will never look there but i still have!
Old Sep 8, 2007 | 12:58 PM
Vadim @ FD's Avatar
S600TT, R350
Sorry, but they are real. They are made by Goodrich for use on race cars.
RT heat exchanger is half the thickness and only a single pass vs double on evosport's.
I sell both evosport and renntech.
Whatever rings your bell.
Old Sep 8, 2007 | 02:17 PM
areuv's Avatar
they are real stainless steel braided lines aren't they? aren't those AN fittings on the ends, another point double pass heat exchanger is like twice as good, double pass think about that, in my opinion the Renntech one is not as good as the EVO probably is, you can get single pass heat exchangers from places like AFCO racing for $200-$300, I prefab my own kit on my old SRT10, it probably cost me $600-$700 and it keep my IAT really down over the stock Paxton heat exchanger, one could get a johnson pump and make their own kit for under $1000, here are pics of my old setup
Attached Thumbnails RENNtech intercooler kit upgrade installed...-srtpics-045-small-.jpg   RENNtech intercooler kit upgrade installed...-avva-working-srt-099-small-.jpg   RENNtech intercooler kit upgrade installed...-cimg0895-small-.jpg   RENNtech intercooler kit upgrade installed...-srtpics-008-small-.jpg
Old Sep 8, 2007 | 02:19 PM
areuv's Avatar
that big double pass heat exchanger was under $400 from AFCO racing, just a thought
Old Sep 8, 2007 | 03:46 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
lol, heat exchanger cores aren't that expensive...it's the time to fab and weld the end tanks, brackets, and connections, and then get it all to fit your application that costs money.
since we're all posting pics of our custom heat exchangers...here are both of mine!
Old Sep 8, 2007 | 04:03 PM
E55 RUSS's Avatar
E55K
Soon is going to be mine also...
Sorry for offtopic...but I fixed my ECU and beat Evotech e55 and did 12.3
I have nice vids...going racing now, will post them later
Old Sep 8, 2007 | 06:17 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
looks like the evo flows down half the cores and comes back the in other half, is that what you mean by double pass?
