Crank pulley bolt part number?
Subscribe
Oct 2, 2007 | 11:00 PM
Does anyone know the part number for the Crank pulley bolt? Need to put my Asp pulley back on after a trip to the dealer.
Reply 0
Oct 2, 2007 | 11:04 PM
Shaun,
Crank bolt: A 000 990 02 00
Reply 0
Oct 2, 2007 | 11:06 PM
4 minutes flat.....That might even be a record here?
Reply 0
Oct 2, 2007 | 11:11 PM
Quote: 4 minutes flat.....That might even be a record here?
I memorize the part numbers.....
Hey, did you get my email?
cheers
Adam
Reply 0
Oct 2, 2007 | 11:18 PM
cheers
Adam
Yes,I thought I replied? No,but can have one ready in 4-5 days.
Reply 0
Oct 3, 2007 | 12:24 AM
i'm going to be messing around down there also. am i recalling correctly...147lbs + 90* for proper torque? are there any special tools needed to hold the crank if i don't remove the pulley and just replace the bolt?
Reply 0
Oct 3, 2007 | 04:32 AM
You need the special tool to hold the pulley to loosen the bolt ... unfortunately ... you really have to tighten that bolt up plenty.
Reply 0
Oct 3, 2007 | 10:57 AM
Thank adam. Quick reply as usual.
Reply 0
Explore
Oct 3, 2007 | 09:44 PM
Quote: i'm going to be messing around down there also. am i recalling correctly...147lbs + 90* for proper torque? are there any special tools needed to hold the crank if i don't remove the pulley and just replace the bolt?
Better eat your Wheaties that day,those bolts are on tight my friend! Some use the torque convertor housing to stop the crank from turning,some have the mb tool that holds the crank pulley itself.
You can get a mb crank pulley holder off ebay for 40 bucks.Compared to 300 at the dealer.Theres a link here on the forum where to get one on ebay.Our local DIY thread guy(whats his name?)has the link.
Reply 0
Oct 3, 2007 | 10:47 PM
Quote: Better eat your Wheaties that day,those bolts are on tight my friend! Some use the torque convertor housing to stop the crank from turning,some have the mb tool that holds the crank pulley itself.
lol, i'll get that b*tch if i have to eat wheaties for breakfast and a can of spinach for lunch.
i'll search for that link...thanks.
btw, do i have the torque specs correct?
Reply 0
Oct 3, 2007 | 11:03 PM
The Mercedes Tool is just INCREDIBLE to watch in action.
Tech literally shootin the gab with me and just popped it right off.
I was like, "That's it??!!!"
One of Ebay...not sure how good this one will work
**edit, keep in mind, he did have a 3 foot breaker bar attached to this pup, plus a torque wrench that was about 2 foot+ on the crank bolt. Still looked pretty easy though.
Reply 0
Oct 3, 2007 | 11:17 PM
Quote: lol, i'll get that b*tch if i have to eat wheaties for breakfast and a can of spinach for lunch.
LMAO...sorry,forgot about the specs question.Yes 147-148 plus 90deg.Torque the bolt down then mark the bolt face and pulley,then give it a good 90deg twist.The few that I have done were harder to get the stock bolt off than the actual tightening of the new bolt.
You should get the pulley holder for sure.
Reply 0
Oct 15, 2007 | 03:43 PM
How about the Crank Key? Does it need to be replaced also?
Reply 0
Oct 15, 2007 | 03:52 PM
Quote: How about the Crank Key? Does it need to be replaced also?
No,only if it looks bad....which it shouldnt.
Reply 0
Oct 15, 2007 | 03:54 PM
Quote: No,only if it looks bad....which it shouldnt.
Thank you.
Reply 0
Subscribe
Currently Active Users (1)
