Expected gains from asp pulley
C32, Cobra, 700hp Vespa
Well it looks to be about the same size as mine, and it clears the oil cooler. I already got an offer on a newer E55 to check out. So I should know pretty soon. Interesting that he made a single pass tube and fin unit. Nice job on the angled end tanks, definitely needed for his design to help maintain flow. I originally did angled tanks on the C32, but there was no difference over the square tank with the size of ours. Most of the fluid is in the passages, not the end tanks, which is where we want it to be.
Any thoughts on the integrated oil cooler? There is plenty of room to move the unit. If it will clear, then I will not bother, unless people are interested.
E55
Actually I was wrong,that HE isnt off Mikeys car.His is similar though.The same shop made them both.
Here: https://mbworld.org/forums/w211-amg/210722-upgraded-floored-fab-i-c-cooler-installed.html
I'd offer up my car for you to use but Im too far away.
Here: https://mbworld.org/forums/showthread.php?t=210722
guys..
I just got home.. (8:30pm)
I'll post pics very soon of the fron grill and the spacing available.
Car is running very nice as mentioned before and I can hear my whine almost all the time now.. before that was not the case.
I'll take some garage pictures later tonight and start a new thread, but at this point as pointed out by a few.. this IC HE is for 03's.
We use a run down shop in Ontario, they have a lift and I just give them some small change for the time and hassle.
#32
E55
#34
Ill get the Autoengenuity on it and check again when I get a chance.
#37
ROFL !!!!!!!!!!!!!! Blimey I thought that was piping / tubing ... ! My my she is a tiny unit...
When I check my CM90 mounting this weekend to see how she is holding up ill post some picks of my monster.
Still can't believe I missed that.
#39
CM090 would be better.. but the core is the biggest problem.
For the 03 E55', this mod is a must even with stock pulley. An for the price, it would be a nice option.
#42
2005 SL55 AMG
#44
2006 E55
thats the oil cooler??? I always thought that was the HE. Which one is the stock HE then??
#45
E55
#48
SL55
[QUOTE=code3smith;2468008]I just wanted to chime in real quick. The unit was developed from scratch. The Cobra unit has nothing to with my unit, other than in spirit. It is all aluminum, dual pass, 10 row bar and plate, lines up with stock hoses perfectly, aluminum brackets welded to the top of the core for strength, and bolts up to the underside of the bumper. The stock unit holds a measly 28oz, and the new unit holds 80oz (187% increase over stock). It looks awesome in the front bumper of the 55! I cant wait for Joe to post pictures
Anyway, I am making some minor bracket adjustments, but otherwise, the unit is developed and will be available very shortly. Here are some teaser pictures. I will start a new thread once my sponsorship starts.
![](http://www.code3performance.com/E55/e55_1.jpg)
Do you know if it will work on the SL?
Thanks,
RoydRage
Thanks,
RoydRage
