*** VRP Headers ***
Rating: Thread Rating: 2 votes, 3.00 average.
Old Jan 24, 2008 | 01:31 PM
  #176
phatmitzu's Avatar
2005 E55
Originally Posted by vrus
As far as I know it doesnt.. the rear O2 harness has to be cut and lenghened...
How do we do that? What wires do we use to extend it?
Old Jan 25, 2008 | 12:53 AM
  #177
vrus's Avatar
2003 E55 AMG
Good luck Evan!!
Originally Posted by Roseylv
This Friday I will Finally be going to hit the track ever since installing my log headers, filters, pulley and 030 pump.
Conditions will be similar to my stock runs
Also have better rear tires (toyo t1'rs)
That was the plan with the S550.. We just need more hours in the day to work on all the things we want to accomplish. its not a huge demand so its not really high on the priority list.
Originally Posted by joeybenz106
any chance of making them for the 550 motor???
Its easy.. just get 3 wires of the same gauge.. Cut and extend each wire.. use electrical tape and put a wire loom around the wires..
Old Jan 25, 2008 | 04:02 AM
  #178
phatmitzu's Avatar
2005 E55
Are they 14-16 gauge wires?
Old Jan 25, 2008 | 11:30 AM
  #179
vrus's Avatar
2003 E55 AMG
I dont remember the rating to be honest.. I will ask the shop.
Old Feb 9, 2008 | 07:10 PM
  #180
rwmotorsports's Avatar
Any dyno on the long tubes yet?
Old Feb 10, 2008 | 12:35 AM
  #181
MatzeMB's Avatar
E 55 AMG ´04
I must have it !!!
Old Feb 10, 2008 | 12:56 AM
  #182
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Originally Posted by MatzeMB
I must have it !!!
I Agree!
I'm getting mine!
Old Feb 13, 2008 | 09:28 PM
  #183
jason3977's Avatar
04 E500 20in brabus monoblocks 1 serious 500E & 91 300CE 2JZ 2005 CL65
This Might Be A Stupid Question But Will They Work On A E500? If So Would There Be Any Gains?
Old Feb 14, 2008 | 03:28 AM
  #184
Dr. C36's Avatar
1996 C36 AMG
Hello,
What is the exact thickness of the flanges on the headers? I want to know so they won't warp. Are they 1/4 inch, 3/8ths inch, half inch? Also if they are too thick won't they not allow the nut to go on properly.
sorry for the noob question.
Old Feb 14, 2008 | 10:18 AM
  #185
vrus's Avatar
2003 E55 AMG
They will work as far as I know.. It should make good power but we've never tried it... Wanna be #1 ?
I will find out for you.
Originally Posted by Dr. C36
Hello,
Old Feb 14, 2008 | 04:07 PM
  #186
E55 RUSS's Avatar
E55K
How much POWER does this exhaust set up makes ???
Old Feb 14, 2008 | 05:36 PM
  #187
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
Yes please give us some HP numbers!!!
Old Mar 4, 2008 | 01:13 PM
  #188
vrus's Avatar
2003 E55 AMG
We have 2 more sets of Longtube headers + midsection exhaust coming out of the coating shop...
If anyone needs a set, now is a good time...
Old Mar 4, 2008 | 01:14 PM
  #189
vrus's Avatar
2003 E55 AMG
I dont have dynos on a bone stock car, but if anyone wants to be the first, let me know and I'll cut you a deal!
Old Mar 9, 2008 | 11:35 PM
  #190
bfnnrgn's Avatar
SL65
Well shoot. Mine's not stock, I have the VR550. I'd be interested though, what's the cost? Also do you have any of the shorties for an SL55 in stock? I keep going back and forth between the longs and shorties. Without a dyno for the longs it's hard to make a decision.
Old Mar 19, 2008 | 01:25 PM
  #191
vrus's Avatar
2003 E55 AMG
We are going to put a set on Havoc's car.. I'll let you know how it goes..
Old Mar 19, 2008 | 01:30 PM
  #192
vrus's Avatar
2003 E55 AMG
We are now making another variation of the longtube header which will be aimed at the high horsepower cars..
We saw through tuning JakPro's car with heads & cams that the engine is just starving for air...
We are now making a longtube stepped design.. They will be 1 3/4" coming off the exhaust ports, stepped up to 1 7/8" into a 3" or 3.5" collector (we will be testing to see which is better). We will then tack on a 3" midsection all the way back to the rear mufflers.
This design is the best compromise for low end torque and high end horsepower. It will be going on our VR700 car that is being built in Houston..
I will post some progress shots of the custom fabrication work once it begins.. (it is scheduled for next week)
Old Mar 19, 2008 | 03:03 PM
  #193
BenzoBoi's Avatar
Super Moderator
W221
Hey Victor,
Would you recommend running your current set of Long tube headers if one were only going to do the ecu/pulley and MAYBE the TB upgrade later on or would you recommend waiting for the new Long tube headers to come out?
I personally don't see myself doing anything more then the ecu/pulley, long tube headers, and the 80MM TB. The TB is a MAYBE too later down the line...after I get the ecu/pulley and headers in the summer time -ish...HOPEFULLY...
Old Mar 19, 2008 | 03:19 PM
  #194
Havoc's Avatar
Like JakPro has said in the past..."Thank You V I C T O R"
Old Mar 19, 2008 | 09:29 PM
  #195
vrus's Avatar
2003 E55 AMG
The current longtubes, if used with the midsection exhaust, is sufficient for what you want to use them for... Chiromikey's car is basically this setup and he is making some great power and has run low 11.4's with that combo.
The new stepped header + 3" exhaust will be just for heads & cams setup..
Originally Posted by BenzoBoi
Hey Victor,
Old Mar 19, 2008 | 09:30 PM
  #196
vrus's Avatar
2003 E55 AMG
Oh yeah.. Did I mention.. you are being upgraded to this new set also..
Old Mar 20, 2008 | 02:45 AM
  #197
BenzoBoi's Avatar
Super Moderator
W221
So I shall stick with the current Long tube headers....thanks Vic...
Old Mar 20, 2008 | 06:50 AM
  #198
Havoc's Avatar
Well, not really, but I'm not complaining. LOL!!
Thanks Boss!
Old Mar 20, 2008 | 01:35 PM
  #199
bfnnrgn's Avatar
SL65
Awesome. Don't forget to get some video so we can hear what it sounds like!
Old Mar 29, 2008 | 03:55 PM
  #200
supre55's Avatar
E55
Vic/Vadim - Are the shorty's still around? Maybe an old set sitting in the corner collecting dust that I could take off your hands?
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
