*** VRP Headers ***
Rating: Thread Rating: 2 votes, 3.00 average.
Old Dec 16, 2007 | 09:59 AM
  #151
vrus's Avatar
2003 E55 AMG
Evan,
STD and SAE are just 2 standards for measuring power and torque.. they use different calculation methods.. Both offer corrected and uncorrected readings; that has nothing to do with it.. The STD calculations always read higher than the SAE ones..
SAE seems to be the industry standard so I try to stick with those now.
Originally Posted by Roseylv
thanks for dyno graph!
Now, were you ever able to get a baseline dyno with a functional pump and stock motor? Your ASP numbers seem about right, I'm just wondering how your car did stock?
Victor mentioned that my dyno graph showed a STD reading not SAE corrected. What are the differneces with these two reading and how is the math done?
Old Dec 16, 2007 | 10:28 AM
  #152
LTHL VPR's Avatar
The STD correction factor was an algorithm used back in 1990 and before. SAE is a newer correction factor. STD does tend to how slightly higher numbers, but as long as the car was consistent throughout the testing (comparing STD to STD numbers and not STD to SAE), then the gains you are seeing will likely be very similar. You can contact your dyno shop and they can change it to SAE in about 10 seconds. However, I wouldn't expect to see a big difference in the change in hp between before and after (ie if you saw 42hp w/STD you will probably see just about the same in SAE), just the actual numbers will likely shift down.
Again, if you search this forum and others, it is very common for an ASP pulley to add 35-45rwhp with no other mods on a stock car. Yes, it looks like your car could benefit from tuning, but keep in mind that a car like yours with pulley and a tune should be putting down closer to 55-65rwhp. Anything gains above that would likely be do to the headers.
Good luck!
Old Dec 16, 2007 | 10:48 AM
  #153
DFW01E55's Avatar
'14 ML BT
I wonder too, the pump was replaced after the pulley was installed, so no true baseline.
Old Dec 16, 2007 | 01:01 PM
  #154
ROCKETW19's Avatar
06 EuroElites E55
Money back guarantee huh>>>>LOL!
Rocket, you have a stake in this scanguage company?
I think I'm better off finding someone locally who has a data logger who is willing to load it to me for an hour vs. spending that money for probably a few uses.
But, IF i choose to get one, Scanguage it is
Thanks for the info
LOL no nothing to do with the company actually any datta logger will do scangauge was just very easy and cheap to use. but if someone will lend you theirs that is even better. if you plan to keep modding your gonna need one anyways.
Old Dec 16, 2007 | 07:26 PM
  #155
Roseylv's Avatar
w212 E63 / 996tt
Originally Posted by vrus
Evan,
my numbers are appearing worse and worse by the day>>>>
I'm looking into this belt everyone is talking about and will get a bigger HE the beginning of next year.....we shall see then
Old Dec 17, 2007 | 01:31 AM
  #156
vrus's Avatar
2003 E55 AMG
Evan.. It's ok bud... Dont worry about it.. its something simple that can be fixed without too much hassle.
Old Dec 17, 2007 | 01:26 PM
  #157
psk145's Avatar
2006 E55
Im at the point where I no longer care what the dyno says. There's always too many variables. As long as it runs well on the street, thats all Im concerned with.
my car dynoed at 455 HP and 510 TQ with renntech pulley and software, so Id say you're in very good shape!!!
Old Dec 17, 2007 | 07:09 PM
  #158
vrus's Avatar
2003 E55 AMG
Yeah.. I myself have run into situations where because of fans or lack of cooling or whatever that the car just doesnt show the numbers on the dyno... but if you put it on the street it tells a completely different story.
That's why I want a dyno that is capable of simulating load (real road conditions) for our shop.
Old Dec 17, 2007 | 09:57 PM
  #159
psk145's Avatar
2006 E55
yes please!!!!
Old Dec 26, 2007 | 09:33 PM
  #160
vrus's Avatar
2003 E55 AMG
The first set of Long tubes + center section exhaust just came back from the coating shop.
There are 2 different coatings applied to it.. there is both an internal and external coating applied to make the exhaust as efficient as possible.
Notice that both the collectors on the longtubes and the catalytic converters are made in such a way that they can be easily replaced.. The collector can be taken out and we can experiment with different sizes based on the customer's configuration of engine and other ancillary components.
The catalytic converters can also be completely removed and replaced with a straight pipe section for those days when you just want to set off all the neighbouring car alarms... LOL..
Here are a few pics to wet the appetite...
Old Dec 26, 2007 | 09:54 PM
  #161
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
if i didn't already own a set i'd buy them!!!
Old Dec 26, 2007 | 11:00 PM
  #162
Eurocharged Rick's Avatar
SPONSOR
what kind of cats are you using Victor?
these look very nice!
Old Dec 27, 2007 | 08:33 AM
  #163
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Nice! ... I assume the different header layout is to overcome fitting restrictions, but will these fit RHD cars?
Old Jan 3, 2008 | 12:57 PM
  #164
vrus's Avatar
2003 E55 AMG
lol.. Everytime I look at the install pics of your car I drool..
Why they are VRP cats of course!
Steve.. I dont think they will fit because of the location of the steering rack..
Old Jan 20, 2008 | 10:24 PM
  #165
bfnnrgn's Avatar
SL65
Any dynos to show for the long tubes yet?
Old Jan 20, 2008 | 10:28 PM
  #166
vrus's Avatar
2003 E55 AMG
Not yet.. There are a couple of sets going on complete cars.. Havoc's SL55 is getting them along with heads & cams and just about everything else.
There is also an E55 up here that I am building up which is getting the long tubes & midsection exhaust + pulley, ecu, TB, cams and airbox.
I have 1 stock E55 up here that will be getting the long tubes also.. I will get a chance to put them on the stock car and see what it can do, then slowly add pulley, TB, and everything else, 1 at a time.
I'll have some dynos to share of different build levels very soon.
Old Jan 21, 2008 | 02:03 AM
  #167
MafiosoCLS55's Avatar
CLS 55 AMG, 2002 Chevy Avalanche (w/ NOS) :D
VIC, Please tell me that set up will fit my CLS..
Old Jan 21, 2008 | 10:39 AM
  #168
vrus's Avatar
2003 E55 AMG
Yup, it will..
Old Jan 21, 2008 | 04:10 PM
  #169
Will this set up throw a CEL light? Or is there a way around it?
Old Jan 21, 2008 | 04:48 PM
  #170
vrus's Avatar
2003 E55 AMG
As far as I know it doesnt.. the rear O2 harness has to be cut and lenghened.. Worst case, we can address the CEL with the ECU tuning.. We can turn it off so it doesnt throw a code.
Do the ECU last and if it becomes an issue I will take care of it in the programming.
Old Jan 21, 2008 | 07:56 PM
  #171
chiromikey's Avatar
it does throw a cel so it will need to be turned off via the ecu.
Old Jan 24, 2008 | 12:45 AM
  #172
Roseylv's Avatar
w212 E63 / 996tt
Hitting the track
This Friday I will Finally be going to hit the track ever since installing my log headers, filters, pulley and 030 pump.
Conditions will be similar to my stock runs
Also have better rear tires (toyo t1'rs)
Old Jan 24, 2008 | 12:54 AM
  #173
juicee63's Avatar
2011 twin turboed prius
No rain??
Old Jan 24, 2008 | 10:13 AM
  #174
joeybenz106's Avatar
2007 cls 550
Here is a pic of the completed long tube setup + high flow cats + complete mid-section exhaust..
1 of these is going on my car along with the new motor.. another set is going on a customer car that we are doing up here.. its quite the build up and I will post lots of progress pics as we go through it...
Here are the uncoated beauties... more pics to follow once they get our coating put on.
Now those are sexy!!!
Old Jan 24, 2008 | 10:41 AM
  #175
2007 cls 550
any chance of making them for the 550 motor???
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
