Intercooler upgrade kit is ready to go...
Individual Kit pricing: $1399USD
3 People for Group Buy: $1299USD
5 People for Group Buy: $1199USD
10 People for Group Buy: $1099USD
Finally!
More info on it please.
Size? Hoses Size? Volume over stock? Split circuit? Direct bolt on?
Thanks,
Thanks,
Quote:
not trying to step on victors toes but yes.Originally Posted by blueknight
Yes, will this fit 03-06?
Quote:
also a yes, which is the reason his kit includes the custom reservoir.Originally Posted by jason427
Does it separate the cooling circuit?
Quote:
i wonderd what the hell that was! is that reservior big enough or does it just look small?Originally Posted by chiromikey
Quote:
unless you're using a reservoir large enough to add ice to, size is unimportant. the only reason you need a reservoir is to fill and burp the system.Originally Posted by ROCKETW19
...sorry, the short answer is yes...it's big enough.
ExploreMBWorld Fanatic!
no need to be sorry at least now i know why also!Originally Posted by chiromikey
unless you're using a reservoir large enough to add ice to, size is unimportant. the only reason you need a reservoir is to fill and burp the system....sorry, the short answer is yes...it's big enough.
before you added you ice box did you notice a big increase in coolin this way? im easly hittin 160
I'm slow here... so tell me how this integrates with a setup like mine who has the larger Kleeman pump installed...?
Quote:
You use eveything in the kit but the little Cm30 pump.Should be easy to integrate to your pump.Would be a nice addition for you kid!Originally Posted by FlyByNight
with the stock system (including newer oem pump) i would reach high 160's within two wot bursts. now i can go wot as much as i want and it typically stays in the 120-130's (without ice).Originally Posted by ROCKETW19
no need to be sorry at least now i know why also!before you added you ice box did you notice a big increase in coolin this way? im easly hittin 160
Quote:
thanks bro, that what i wanted to hear.Originally Posted by chiromikey
Count me in for the group buy.
Quick question...Do I really need this if my stock IC pump(supposedly an upgraded one) was just replaced by MB earlier this yr? Well I guess it should be better because of more volume. Maybe a pulley is in the near future
. When will you be done with your pulley vrus?
. When will you be done with your pulley vrus?MBWorld Fanatic!
get a pully first, your car will run fine stock. unless you live in AZ or something with extream heat. but i would get this second. so if groupe buy makes it worth your cash get it now.Originally Posted by rberga1
Count me in for the group buy.Quick question...Do I really need this if my stock IC pump(supposedly an upgraded one) was just replaced by MB earlier this yr? Well I guess it should be better because of more volume. Maybe a pulley is in the near future
are the prices including shipping as well? Or is that additional?
So far we are at 3 person pricing..
Fits all E/CLS with or without aux oil cooler.. We havent test fit on a SL or S yet but the S should be no problem because its got a huge bumper area.. The SL is the only one I am not sure of.
The CM90 was designed to run with a 1.5" inlet tube.. The CM30 is designed for a 0.75" inlet which is what our cars use. The CM30 has a much smaller footprint and is a direct plugin to our hoses not requiring a reducer like the CM90 does.
Quote:
Hey Loren.. It will integrate with your current setup no problem. You can keep your CM90 pump if you want and when it fails install the CM30.. Originally Posted by blueknight
Quote:
Mikey, you are never stepping on my toes... I appreciate all your input and your help.. If it wasnt for you, half these projects wouldnt exist. Originally Posted by FlyByNight
Quote:
Charles: Shipping is extra, but they will ship from the USA so it wont be as bad as coming from Canada.Originally Posted by chiromikey
Quote:
congrats on the nice final product... great price too
FMIC should be a must if you add a bigger pulley..
We have a few new tuners such as VRP,LET, Code3 that will give the E55 tuning crowd a much deserved cost savings.
what is the capicity of your HE? Stock is around 28 oz. if I recall.
Any pix of it installed? Wanna see how it sits in the bumper..
Quote:
not just cost savings, but a wider choice as well. Keep up the good work guys.Originally Posted by TopGun32
Now all we need is a lowering module like renntech...but without the price
Quote:
Good point...I'll give just the pulley a try and see how that works...It is pretty cold in Chicago nowadays.Originally Posted by ROCKETW19
Quote:
I have this kit and I love it!Originally Posted by chiromikey
Quote:
I thought it looked familiar.Originally Posted by deaguero
me too!!!
Quote:
