License plate light
Old Nov 23, 2007 | 05:11 PM
dkallencat1's Avatar
License plate light
Has anyone change their license plate light? Like the ones on the new Lexus LS 460, they are so white it almost gives a blue tint, pretty cool looking, i'm going to check in to that.
Old Nov 23, 2007 | 05:40 PM
III II I I AMG's Avatar
2003 e55
oh yea, let me know how it goes.. i saw it on my friend's 07 es350, theyre sooo much nicer, always wanted to do it
Old Nov 25, 2007 | 02:38 PM
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
Please post with results, as I am interested also!
Thanks1
Old Nov 25, 2007 | 02:40 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Thanks1
+1
me too..........
Old Nov 25, 2007 | 02:58 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Thanks1
And how about those BMWs with the LED puddle lights in the door latch. Thats creative.
Old Nov 25, 2007 | 07:25 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
They look unreal
My plate is white and blue (sailfish), and with 2 X 9 led bulbs it makes my plate look like it is an LCD screen, it truly glows against the black car.
The largest selection of leds is found at http://spectrumled.com/festoon.htm
They have the resistors you will need to prevent "bulb out warning"
Here is a link to pics of install in a W210 almost the same procedure
You must be a member of Benzworld and log on to see pics.
http://www.benzworld.org/forums/test...9-99e430s.html
Old Nov 25, 2007 | 08:27 PM
ENDSMTG's Avatar
Originally Posted by Yacht Master
My plate is white and blue (sailfish), and with 2 X 11 led bulbs it makes my plate look like it is an LCD screen, it truly glows against the black car.
Attachment 118830
So what bulbs did U use?
Old Nov 25, 2007 | 10:18 PM
RJF's Avatar
RJF
2006 Black Opel 350 4matic
I just got my 08 e550 4matic.. and have been researching the leds.. but cannot find the correct size as well.. I would greatly appreciate if if you can point my in the direction to replace these amber looking lights with a bright white led! Thanks in advance.
Old Nov 26, 2007 | 02:34 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
http://www.superbrightleds.com/festoon.html
I beileve our bulbs are 36MM..Not sure though. I remember awhile back when i wanted to do this, the problem was the dash light would come on saying a bulb was out... any of you guys running upgraded license plate bulbs have this problem?
-Walter
Old Nov 26, 2007 | 03:08 PM
blackcls63's Avatar
07 CLS63 | 06 SLK350
-Walter
I think that might be related to the fact that the LED's pull less power than the stock bulbs, which makes the ecu think the bulb is out... a resistor might solve the problem...
Old Nov 26, 2007 | 03:31 PM
wouldnt a resistor get way too hot inside the light housing?
Old Nov 26, 2007 | 03:44 PM
W211 Ryda's Avatar
2004 E320
LED bulbs will work (with resistors) for awhile, but eventually...they'll burn out throwing off an error msg.
https://mbworld.org/forums/showthrea...t=license+bulb
Hoen recently came out with 5 watts halogen festoon bulbs that would fit our application. It may not be as bluish as the Lexus lights, but still much whiter than stock.
http://www.hoen-usa.com/licenseplate2.htm
JLeviSW also came out with these LED license plate lights. I'm not sure what the specs are but I'll be contacting them shortly.
http://jlevistreetwerks.com/p681/Jle...669d8843fb8d7d
Old Nov 26, 2007 | 04:56 PM
blueknight's Avatar
07 BMW X5
Thx for the info, called JleviSW myself and they said it shouldn't throw any fault codes but they have not yet tested them out yet on the E class. BTW they have them in stock and are available for local pick up on Tues. & Thurs. only. Might head down and pick up a pair myself.
Old Nov 26, 2007 | 05:04 PM
NO_WUR_E's Avatar
'06 E350 Iridium Silver with pano
I have these on my W203. They are non led. Other members have them on on for months and with no problems.
Here is a pic with old and new bulb:
Old Nov 26, 2007 | 05:44 PM
They have no idea, LEDs alone will throw a "bulb out" warning.
$24.00 is
Old Nov 26, 2007 | 06:53 PM
Yacht Master, which do u have?
Old Nov 26, 2007 | 07:14 PM
The info is back in my first post.
https://mbworld.org/forums/showpost....71&postcount=6
The bulbs have lasted over a year, no problems. I have forgotten the size/length of the bulb, so measure one of yours before you order.
Old Nov 26, 2007 | 07:21 PM
User110's Avatar
2003 Cl 500
i haven't installed it yet, but i bought the L.E.D.'s already, correct size festoon bulbs. but i need to buy a resister for it. if you search you can find it talked about in this thread- https://mbworld.org/forums/c-class-w203/132626-hyper-white-led-license-plate-lights-thread.html
but don't comment in it, or they'll flip out on you for not driving a c class lol
ALi
Old Nov 27, 2007 | 09:46 AM
Ok, just ordered them.. Our stock bulbs are #6418 which tranfer over to there 39mm 9LED Festoon bulbs...
Old Nov 27, 2007 | 10:37 AM
Thats it 39 they will fit tight, here is a pic of the resistors I used.
2 X 100 ohm ceramic resistors hard mounted to circuit board, I tested it for 1.5 hours and the resistors never got too hot to touch. I just mounted the circuit board so that it would not touch any thing any way, I also insulated the soldered electrical connections on the board with a generous amount of epoxy.
Old Nov 27, 2007 | 11:15 AM
JDM_SXE-10's Avatar
2003 E500
Those look really bright. Will I need a resistor to run these?
Old Nov 27, 2007 | 11:34 AM
Nice! So 1 resistor per bulb, 1 wire to positive, other to ground? Fairly easy...
Thanks!
Walter
Old Nov 27, 2007 | 03:53 PM
phatmitzu's Avatar
2005 E55
Thanks!
Walter
I did the same thing. It worked for couple of weeks then the LEDs would burn out. 3 sets of LEDs later I went back to stock bulbs. Maybe I'll try the new 5w halogen festoon bulbs...
Old Dec 4, 2007 | 09:10 PM
Ok, so installed the LED's. Without the resistor they would strobe, wouldnt stay on constantly. I than installed a 100 Ohm resis on each bulb. The lights work now, but im still getting the plate light out message...Any thoughts? Looks incredible at night, exactly like the lexus, a little brighter due to the 9leds in each bulb.. I also have tried the Hoen bulbs, barely a difference, not worth it...
-Walter
Old Dec 4, 2007 | 09:23 PM
User110's Avatar
2003 Cl 500
maybe its the path you put the resister on? i read some where that you have to keep it in one direction polarity wise or something like that?
or was that for the bulbs?
can you snap some pic's of where you guys put the resistors? i think i might need to take of my lid lining for my trunk to hide it back their.
ALi
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
