Drag Radials vs Street Tires! video
Old Jan 4, 2008 | 08:11 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Does anyone know the drivers of these two beast?
This is a case of one car that has better traction vs a car with more HP.
Which would you rather have?
btw, if this is old and a repost please forgive me
http://www.youtube.com/watch?v=Edr5SDUP_v0&NR=1
Old Jan 4, 2008 | 01:04 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
I am the driver of the black car, ENDSMTG is the driver of the silver monster.
Old Jan 4, 2008 | 01:14 PM
juicee63's Avatar
2011 twin turboed prius
great driving Mr. X!
Reaction time was .34 better for the right side although getting pulled and outmatched in the HP department the car held the lead long enough and got the WIN!! looked like he was out trapped by 8mph and had a .09 advantage in ET.
Wayne was your MOV .27?
In a Heads up race a slower car that trees you can ultimately beat you, give a guy like me hope
Old Jan 4, 2008 | 01:16 PM
Chicago, what brand of DR are you running and how was your launch after installing the DR's (any wheel spin?) off idle or power brake? and what was your tire pressure?
Old Jan 4, 2008 | 01:28 PM
BenzoBoi's Avatar
Super Moderator
W221
sweet vid!!!
Old Jan 4, 2008 | 03:13 PM
ChicagoX's Avatar
W211 E55
I'm running BFG Drag Radials in a 275 width, but the 265s are great as well.
28 PSI, light burnout, off idle launch. Suspension raised and in COMFORT, tranny in SPORT, Traction off.
Old Jan 4, 2008 | 03:15 PM
ChicagoX's Avatar
W211 E55
.2679, close enough.
Thanks for the props.
Old Jan 4, 2008 | 03:20 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Nice video......
I think I would choose the extra hp still
Old Jan 4, 2008 | 06:03 PM
Traction Control Off So I guess with the DR's it just hooks up
Old Feb 17, 2008 | 11:44 PM
ScottCLS55's Avatar
Lexus
I just put 315/30/18's on my CLS, do you think I can stall a little on the launch ?? or should I stick with off idle?
Old Feb 17, 2008 | 11:58 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
test for yourself and find out but (assuming the track is prepped) those of us that have already done it know that launching off idle gives the best results in the 55's. it's my opinion that our ecu's just don't understand what to do with application of brake and throttle at the same time.
the only problem with launching off idle is your reaction times will suffer. there's considerable lag between mashing the pedal and the ecu doing what it's told.
Old Feb 18, 2008 | 12:08 AM
V12Godspeed's Avatar
Your worst nightmare...
Wow, thats some nice trap speed almost 124MPH..
Old Feb 18, 2008 | 12:09 AM
Nice what size are your rear rims? you think we could fit that same set up on a 2005-06 CL??
Old Feb 18, 2008 | 12:37 AM
ScottCLS55's Avatar
Lexus
Im using SL 55(the ugly multispoke rims) they are 9.5 wide. do a search by my name and you will see my pics.
It may work on other cars.. Its 1.4 inches wider that 285's.
Old Feb 18, 2008 | 01:01 AM
blackbenzz's Avatar
haters crazy
Everyone should try drag radials once, its a whole new world!
I actually got my best time when powerbraking. Use tip to put it in 1st gear and build up the revs a little when holding the brake and soon as you see the last yellow light, GO! If you wait to see green you've waited too long. soon as the car is above about 3 or 4k rpm I bump the shifter all the way over to drive and enjoy the ride There you go, you have my secrets.
Oh yea, I also put my rear suspension of full soft and front on full stiff so that the rear squats and just goes! Transfering the weight to the rear tires helps with traction. I still need to play with powerbraking to find what rpm is best. These cars make monster torque down low so powerbraking too much is out of the question. If I remember correctly, a little over 2k rpm and the car starts lurching forward no matter how hard you push the brakes
Old Feb 18, 2008 | 01:35 AM
BallzyS55's Avatar
06 S55 AMG, 03 SL55 AMG, 02 S430(sold), 05 F150, 06 Ranger, My baby 07 HD Rdking
Blackbenzz
ESP on or off? and how do you do that to your suspension?
Old Feb 18, 2008 | 06:45 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
if that was on normal streets results would have ben much worse i think (advantage X)
one thing i do not get is how are you runing such tiny tires and getting such good traction 265 275...is smaller better some how? liike smaller rim?
Old Feb 18, 2008 | 10:52 AM
blackbenzz's Avatar
haters crazy
Originally Posted by BallzyS55
Blackbenzz
ESP off. I have KW v.2 suspension so I can adjust each corner.
Old Feb 18, 2008 | 11:32 AM
ChicagoX's Avatar
W211 E55
4200 lbs + sticky tire = plenty of launch. Don't use more meat than you need.
Blackbenzz is right - everyone should experience the traction of slicks at least once.
Old Feb 18, 2008 | 11:55 AM
chiromikey's Avatar
with good rubber and track prep you don't need the width. my d/r's are only 255's.
Old Feb 18, 2008 | 11:59 AM
enzom's Avatar
2005 E55
What is the improvement in 60' times compared to your street rubber? And what street rubber were you running?
Thanks.
Old Feb 18, 2008 | 12:03 PM
Kwik SC's Avatar
2003 S-600
You do realize DR's have to be in the 16-20 psi range for them to be most effective?? I would love to see what your E55 would do with them at that psi and say a 2000+rpm launch..
Old Feb 18, 2008 | 12:05 PM
ChicagoX's Avatar
W211 E55
Thanks.
It's not so much the improvement as the consistency and mitigation of marginal track prep.
My best on DR's is only a few hundredths from the best on street tires...as will probably be your case. (1.76 - 1.81)
It is much easier to drive the car out of the hole with DR's, but not as buttoned-down on the big end.
My streets are Toyo T1R's in OEM sizes.
Old Feb 18, 2008 | 12:11 PM
ChicagoX's Avatar
W211 E55
With all due respect, this is my fourth set of DR's on various cars, and each responds differently.
I have run as low as 15 PSI and as high as 34 PSI in testing. I am merely sharing what has worked for me in the last hundred passes or so.
FWIW, there must be some sort of buried torque management software that limits power when both gas and brake are applied. Without removing that and possibly adding a converter, there is no point in leaving higher. (especially in a car than makes 90% of its torque just off-idle)
Old Feb 18, 2008 | 12:19 PM
Kwik SC's Avatar
2003 S-600
So I stand humbled.. I thought you were running a little less than standard tire pressure and did not bother testing out anything lower.. And 1/2 a second off your 60ft is nothing to sneeze at!! Generally speaking a .5 second drop in the 60 is worth 1 second up top in ET..
