Excess RPM = computer saves the day!
Old Jan 6, 2008 | 12:19 PM
KrisKeeney's Avatar
2013 C63 W204, 2016 E63S W212 Matte Gray
Guys: for some reason, while on "S" transmission mode, when punching hard out of the gate, the car did not shift out of 2nd gear and reached 6,500 RPM. Instantly, I felt the RPM drop out (almost with a silent but felt "click"), and I regained composure. Apparently no damage, as I tested and ran for another hour, in all different levels of transmission configuration, assertiveness, speed, etc.
The Owners Manual doesn't appear to discuss this, but would you agree that my experience was the computer automatically disallowing the Animal to go beyond the redline RPM?
Thank you in advance for your thoughts.
Kris
Old Jan 6, 2008 | 04:29 PM
Timeless's Avatar
2005 E55 ///AMG
The owner's manual does indeed discuss that the computer will not allow you to go beyond the redline in S mode. However, in M mode it does give you a warning to not let your car go beyond the redline which would make me think you can do it in M mode.
Old Jan 6, 2008 | 05:06 PM
rarfinancial's Avatar
CLS63
Put your car in m mode, 1st gear and your car will not let you go past the rev limiter. It will just cut out. In s mode it should shift it's self into the next gear without hitting the rev limiter.
Old Jan 6, 2008 | 05:07 PM
KrisKeeney's Avatar
Cool; thnx for info. I always struggle to find information in the owners manual; index system seems illogical to me.
Thanks again
Kris
Old Jan 6, 2008 | 05:30 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
The rev limiter is VERY aggressive. I have never hit it in S, which is the fastest way off the line. I have hit it in M a number of times. When it engages it feels like a brick wall. You can never time a 1st to 2nd shift in M and beat what the car can do in S.
Old Jan 6, 2008 | 05:34 PM
CLS63
It takes alot of practice to beat the rev limiter in m mode but with ESP off and m mode on, the car will scream like a .. lol
Old Jan 6, 2008 | 05:38 PM
KrisKeeney's Avatar
The rev limiter is VERY aggressive. ...... When it engages it feels like a brick wall.
Thanks for saying this: this is exactly how it felt, and my first thought was "oh, crap, I just destroyed the transmission...." But then I thought, "wait, this car is too smart to let something obvious like that kill the car...."
Thanks again
Old Jan 7, 2008 | 12:24 AM
jangy's Avatar
2015 S212
Dead on.
Old Jan 7, 2008 | 12:32 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
Not only will the car not reach the rev limiter in S mode, during your first 3 to 4 WOT runs, the car may actually shift a little bit early because it was adapted to "everyday-driving" mode. But after your 3 to 4 aggressive full throttle runs, the transmission will optomize shift points to be right at redline for maximum power
Old Jun 8, 2008 | 12:30 PM
E55Houston's Avatar
2004 E55
Hello, total newbe here. Read owner's manual and found slightly contradictory info, so joined MBWorld this a.m. and did some searching. So far, this is the closest thread pertaining to my question I have found.
I was gunning up the on ramp to freeway the other day in what I thought was S mode, but I was actually in M mode. The engine revved very high then felt like it lost power (felt like the rev limiter) then I think it self-shifted to the next gear. The owner's manual says that the transmission will not self-shift in M mode and that over-revving damage to the engine will result if gears not changed in time.
The question is: did the rev limiter protect my engine and did the transmission self-shift to the next higher gear? Or could I have damaged my engine?
It might be my imagination, but it feels like the car is not as fast as before the incident. I am under a 3 year CPO warranty, but if I did damage the engine, how could I tell without taking it to the dealer?
Thank you for any replies.
Old Jun 8, 2008 | 01:35 PM
Centurion's Avatar
a car that gets very poor gas mileage.
This is interesting. Are you positive you were in Manual shifting mode?
Old Jun 8, 2008 | 06:42 PM
supre55's Avatar
E55
In M mode it just bounces off the limiter, it doesn't shift (at least mine did not). When I hit it in first gear, it really felt like I hit the wall.
Old Jun 8, 2008 | 07:49 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
my car will ALWAYS self shift, even in "m" mode if i'm not fast enough. i didn't like this at first but after consideration i realized that it's better than missing (being late for) the shift and hitting the rev limiter.
Old Jun 8, 2008 | 10:05 PM
6MTUA5's Avatar
99 Acura 3.2TL-P 6MT
Such a smart car
Old Jun 9, 2008 | 10:01 AM
Centurion's Avatar
Originally Posted by 6MTUA5
Such a smart car
One of the many things I love about this car and engine is that it can be driven in a comfortable/leisurely way or driven in an extreme/sporty way. If you like to drive in Automatic, "C" mode takes care of the former while "S" mode should take care of the latter. But it doesn't. At least, not the way I would like it to.
The way I drive, I like to hold the RPM's at about 3,600 - 3,800 when cruising. C mode will not do this. I've discovered that S mode also will not do this...because of stop-n-go traffic, my speed will vary and shift points will need to vary as well. Hence, I drive in "M" mode 99% of the time.
Personally, I hate this "adaptive" TCU system.
Sorry to go off topic...we now return to the feature presentation. There will be no further interruptions.
Old Jun 9, 2008 | 08:01 PM
tigerlam92's Avatar
E55
Same here. Autoshift in M mode.
Old Jun 9, 2008 | 09:13 PM
supre55's Avatar
E55
If I am in "S" mode I can shift manually with the paddles. The tranny will auto shift at redline, but I can hold any gear at any point shy of redline.
I I switch to "M" mode (via the button on the center console) then there is no shift unless I do so via the paddles or shifter...just the redline bounce. I wonder if this changed from 03 to 05?
Old Jun 9, 2008 | 10:17 PM
chiromikey's Avatar
maybe they did change. '03's also don't allow you to shift via paddles while in "s" mode.
Old Jun 10, 2008 | 07:49 AM
supre55's Avatar
E55
Therein lies the difference...
In the 05, "M" mode is truly just that: manual shifting, or more correctly sequential manual shifting without the clutch of course
Old Jun 10, 2008 | 11:15 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I've on a couple of occasions managed to beat the tranny to redline/limiter in S mode. Not sure how but mbe tranny was asleep or needed a sneaky reset.
Manual will have u bumping limiter... that does not do the car any good at all...
