Dash Dyno - OBDII Gauge/Data Logging Tools
I came across this when searching for ScanGauge II alternative...
http://www.auterraweb.com/
It's more expensive than SGII (twice more expensive) but less expensive than AutoEnguinity... It has data logging, dyno charts and a lot more parameters than ScanGauge II... and still relatively compact.
Anyone has any experience? Any other alternatives?
If experience/review is good, I am thinking of proposing the mods to do group buys... I also found that Mini Cooper forum could get 10% discount w/ only 3 people.
Any interest?
The only thing I don't like Autoenginuity is it requires either a laptop or handheld PC. I don't want to use a laptop.... too troublesome. Handheld PC may be good... but unfortunately, I don't have one
Dash Dyno seems to be able to mix between portability & feature.... for around $320 ($400 if you want suction cup & some GPS cables), I could get close to Autoenguinity features (analyze data logs on a PC) and SGII portability.
Other comments are welcome....
starscan is the scanning software mb's use to communicate info on every single parameter or feature that's going on with the entire car's electronics. to be able to read everything will be invaluable and for that alone i wouldn't bother with any other data logger.
just mho.
Chiro:
Yeah... I think AutoEnginuity is cool.... do you know if I buy the pocket pc based, can I install the software also to review the datalog on a laptop/desktop PC?
BTW, do you find that all the features in AutoEnginuity measurable somewhere else, like A/F ratio, hp, tq, mpg, etc., quite accurate/consistent?
just mho.
Even with just a few parameters open, I was seeing samples roughly once every 2-3 secs. You guys know that in a modded E55, that's like 5 samples and you are up to 150. I was lucky to even get that sometimes.
Just horrible. Went round and round with them at Autotap and just gave up.
Hopefully the Autoeng will give me some more samples. Keeping fingers crossed.
Actually can't wait. I gotta go out and see what it does now. Hang on .
May be we could do this as a group buy.... LOL. Saving some bucks here and there doesn't hurt, right?
Anyone else is interested? If I could get some consensus, I could give them a call and see.... they may not give any discount, but doesn't hurt to try.
Yeah, sampling rate is another thing that I concerned.... I know SGII has 1 or 2-second interval.... not sure about this Dash Dyno.... how about AE (just short it.... too long
)?I wouldn't worry for monitoring temp (I won't go up like crazy in 2 seconds)... but something like ignition timing, A/F, etc. even 1 second is already too long.... (1 second is like at least 1000-1500RPM elapsed, right?).
MUCH better than Autotap hands down. Very easy to use and software is just light years ahead.
With one parameter selected, I was getting around 2-3 samples per sec. Then as I added others it got slower. Had 4 going on a running graph (One O2 Sensor, RPM,Timing and IAT ) and don't quote me on this, but it seemed to be sampling around once per sec or just a tick less. Perhaps .8 sec or so.
That sound about right Chiro??
I gotta do some street logging and see what I come up with.
So far I give it thumbs up. Guy at Autoeng said that with Palm, it is even slower so I might skip the Palm setup if you want as many samples as possible. I am using standard mid range laptop going USB.
Otherwise compared to the Autotap it's a no brainer.
just mho.
The starscan is read only, right? or would you be able to change things like the 10 degree fan setting, ride hight?
BTW, what else did you talk w/ AE? How about pocket PC version (I won't buy Palm anyway... long story
)? Is it also slow? I don't think CPU speed plays a big role.... OBDII transfers at most a few hundred bytes per second... should be no problem for recent laptop/pocket pc/palm.Did you ask whether I could still analyze the datalog off line using my desktop PC if I buy pocket pc version? If so, that'll be perfect.
I'll give them a call tomorrow and see whether a small group buy could give us some discount. If they could, I'll PM the mods to approve the group buy.
Neveo: http://www.autoenginuity.com/
You mean regular, as in non-AMG? LOL!!! I dunno who was mean to you, but that ain't how it works. There are plenty of memebers in here without E55s or even AMGs and they contribute all the time.
We just go over the smallest details over and over that sometimes some get grumpy when someone comes along after we've already beat that dead horse up. Clayton (Benzorama) comes in here all the time and he has a "normal" E, but is one of the brighter members.
Just keep posting and try not to take much of it personally. VIC taught me a few years back that you can not convey the true communication of a face to face in a post and that is true. What you may assume to be rude may just be oversight.
And for the record I already know which cats are cool and which ones ain't.
Sorry for the
