Oil change faq or how to?
2005 e55 amg
Can someone point me in the right direction link or something to directions on how to change my own oil?
I have an 05' e55 amg.
2005 e55 amg
I'm a seasoned mechanic who actually works on my own cars. I'm looking for a write up or something i can read before i dive in to it blindly.
2007 E63 w/P30 and Eurotech CF Diffuser
Mercedes sucks it through the dipstick tube.
Although I have not done it, my understanding is this is like any other car. I would take out the drain plug.
I can remember at least one DIY on an AMG, but it did not taech may anything new other than a picture of the oil filter O rings.
This is a little dated, but gives you the idea. http://www.mercedesshop.com/Wikka/OilFilter2
2005 e55 amg
Thanks, that helped a little if it's the same as the amg. I don't understand sucking oil out. The concept just boggles my mind & seems so wrong. I feel draining from a drain plug is the best, that way any sludge or buildup is drained. Also i would like to replace the plug with a magnetic one.
Anyone know the the thread type & pitch for the drain plug?
Also any pics of underneath the amg? Like locations of what has to be removed as well as drain plug or plugs?
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I guess you missed my post, here read this again......
Good luck on the magnetic drain plugS, yes two and the OEM plugs are unique to the 55K and one time use, that is the $53.00 parts kit for an oil change.
https://mbworld.org/forums/w211-amg/209859-oil-change-e55.html
You may be better off to have the dealer do it.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
One of my links leads to this pic **(pic courtesy of Finny)**
![](http://i200.photobucket.com/albums/aa87/FinnysPinnys/55upgrade471.jpg)
and this
![](http://i200.photobucket.com/albums/aa87/FinnysPinnys/55upgrade472.jpg)
If you still see 1 plug take her to the dealer
2005 e55 amg
I have rebuilt many engines & transmissions as well as full classic car restorations. I'm very capable of doing the work. I did click on those pics but i could only make out 1 drain plug, is the other one in the background? I have not been under my e55 amg yet to poke around so i have no idea what i'm looking @ in the pics. I'm trying to research as much as possible before i get my car in the air.
Interesting, so when changing the oil by sucking it out, they would never get the oil in the front portion. That is nuts!
Guess I will do it myself from here on, but then I always intended to.
How was it "designed" to have the oil suck out? I see nothing unique. Is it because the 63 has one sump and the 55 has 2?
Anyway, I still do not like the suck method. Any how the heck do they suck it out from the dip stick in the back when the sump is in the front?
E55 then E63, now back to an E55
OK need some advice - heres the deal w an oil change on E55. Had an independent do the change a few days ago, new filter and drained every drop of oil out, but retained the same drain plugs. I am now hearing that the motor keeps a quart or so of oil in circulation that doesn't get drained. SOO.... originally my electronic oil meter (no dipstick here) said "oil level ok"..... today it says "reduce oil"
What should I do? Thanks......
2005 e55 amg
Check this out : http://catalog.eautopartscatalog.com...8ab3e89dc9b271
Febi looks like a good company: http://www.febi.com/
Also the the specs on the drain plug are m14 x 20 x 1.5 pitch. A magnetic plug is very close i can feel it.
Gasket : http://catalog.eautopartscatalog.com...8ab3e89dc9b271
WRONG WRONG WRONG the 63 is totally, totally different.
https://mbworld.org/forums/showthread.php?t=209859
