Improve you gas mileage by 20% plus
Old Jul 17, 2008 | 08:22 PM
Vadim @ FD's Avatar
S600TT, R350
I know, it sounds like a spam commercial.
Just wanted to share some info.
Being in the business of making more power and thus using more fuel, this is exactly opposite of what I do, but with 91 gas getting up into $5 a gallon territory, I had 20 calls/emails/PMs asking me for how to save on gas.
I can tell you how to gain 20% plus in MPG, BUT at expense of 250HP.
If you are ready for sacrifice and do not mind driving a Corolla....................
It is really very simple - unplug your kompressor.
I know it sounds like her heresy, but you will get about 3-4 mpg at the expense of boost.
Ideally, one could make a switch to turn the kompressor off during cruise and turn on when it is needed.
You will get a a very slow car and a 'Check Engine Light", so beware.
Old Jul 17, 2008 | 08:24 PM
RENNSTAGE's Avatar
someone made a funny
Old Jul 17, 2008 | 08:51 PM
phatmitzu's Avatar
2005 E55
Thats an idea!
Or get a proper tune and get more power and MPG at the same time. (Not for the heavy footed).
Old Jul 17, 2008 | 08:54 PM
psuball1's Avatar
04 E55, 12 GL 450(wife)
walk...
Old Jul 17, 2008 | 09:01 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Vadim, what about the 63 guys?
Can we shut down a few cylinders or something
Old Jul 17, 2008 | 11:16 PM
E55 PWR's Avatar
e55
Or you could get a lightweight stock diameter crank pulley and get the same 3mpg+ without sacrificing any boost at all . Sounds much better than losing 50% HP haha.
Royal Purple will help a bit too but not nearly as much as CP.
Old Jul 17, 2008 | 11:30 PM
C280Sportster's Avatar
C280
Mad Max had the same switch!
Old Jul 17, 2008 | 11:34 PM
Vadim @ FD's Avatar
S600TT, R350
No.
Kompressor take anywhere from 25 to 70HP to spin, plus fuel enrichment from the boost are responsible for MPG gain.
Royal Purple is no better than Mobil 1.
Old Jul 17, 2008 | 11:51 PM
NXtremeJeep's Avatar
GT-R
I wish these damn cars had a boost gauge. Doesn't the kompressor only kick in under certain loads and not under "regular" driving?
Old Jul 18, 2008 | 01:59 AM
III II I I AMG's Avatar
2003 e55
so if i unplug it and drive.. check engine light comes out.. would the computer of the car go nuts and break down on me? or wouldnt it still dump the same amount of fuel even if the supercharger is unplugged?
Old Jul 18, 2008 | 02:28 AM
Vadim @ FD's Avatar
S600TT, R350
Boost can be seen through diagnostic port. Kompressor is pretty much on 99% of regular driving.
Old Jul 18, 2008 | 02:30 AM
Vadim @ FD's Avatar
S600TT, R350
No, you get a CEL which will read MAP sensor malfunction.
Fuel is added through map values that corresopnd to boost level, if there is no boost - there is no extra fuel.
Old Jul 18, 2008 | 03:59 AM
psk145's Avatar
2006 E55
I think someone should make a valet switch so you can turn off the blower when you valet it or when the wife takes it!
Old Jul 18, 2008 | 06:37 AM
por997s's Avatar
E55 AMG
Would removing the Sprint Booster help much? This business about WOT just pisses away fuel. $2.80 a litre inthe UK.
Old Jul 19, 2008 | 01:38 AM
str8ridin's Avatar
05 E55
What if you just take off your s/c belt? No CEL? But that would be a pita.
I'd love to have that valet switch...
Old Jul 19, 2008 | 04:19 AM
2003 e55
so last question... how do i unplug the kompressor? what do i do manually
Old Jul 19, 2008 | 06:32 PM
Vadim @ FD's Avatar
S600TT, R350
The only concern about a switch - what happens if it the kompressor gets turned on at 80 mph?
At that speed a 40HP load from kompressor either will throw the belt off or fry the clutch.
Will DME not allow this to happen?
Until I try it I will not know.
CEL will happen due to missing boost vs. throttle pedal postion vs. load.
I will keep digging.
Old Jul 21, 2008 | 03:52 PM
TopGun32's Avatar
I have done this to my C32 to trouble shoot a bad IC pump...
from a stop.. it not that bad.. but making a pass is takes for ever.
On my E, I have thought about this... but not tried it.
BTW: on my C32 no CEL's.
Old Jul 21, 2008 | 04:35 PM
psk145's Avatar
2006 E55
dont you have jangy's car you can try it on??
Never thought about the switch being used at driving speed. How about a switch that can only be switched when the car is off?
Old Jul 21, 2008 | 05:30 PM
Murtaza's Avatar
C63S coupe, X5M
Would love to have this switch for valet and the day I have to let a girl drive it.
How do you manually turn off the supercharger?
And shut off jangys SC
Old Jul 21, 2008 | 09:00 PM
jangy's Avatar
2015 S212
Nope, the baby is home. If you guys want to turn off the SC, why not just take off the belt?
Old Jul 21, 2008 | 09:03 PM
psk145's Avatar
2006 E55
no, I want to have a switch, and I think Vadim should test your car to see what happens when its turned on while the car is traveling 60mph +.
Old Jul 21, 2008 | 09:32 PM
Vic55's Avatar
Administrator
Beer is cheaper than Gas- Drink dont Drive!!
Old Jul 22, 2008 | 01:40 AM
2003 e55
no. 8 bucks barely get me a gallon of coronas.. at the clubs they're actually 4 bucks each.. so yea, id rather drive
Old Jul 22, 2008 | 01:45 AM
tbone's Avatar
E500 Sport
Save gas
