SERVICE RESET
Old Aug 14, 2008 | 09:45 AM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
SERVICE RESET
OK. I've searched every forum for as many posts as I can find on the subject but still don't have the answer. So I apologize in advance bring this up again.
I changed my own oil on my 2006 E55 this weekend because I was a couple of hundred past the recomended service. Now, I would like to reset the indicator and can't.
My owners manual indicates only a dealer or authorized service facility can do this and there are no instructions in the manual to perform this. I've tried every method I could find on the various forums and none work on my 2006.
Any advice? I would really like NOT to go to the dealer for this.
Old Aug 14, 2008 | 11:20 AM
racetested's Avatar
08 MB
You can go to an independent shop and have them reset the code or buy a tool like this if money is not a main concern but convenience is.
http://www.otctools.com/products/detail.php?id=1338
Cost of tool is around $250-300.
Old Aug 14, 2008 | 12:13 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
I did the following on my Wife's E55 and it worked. I also used this on my SL55 and it likewise worked.
Re-setting Service Indicator
________________________________________
If you change your own oil and do other maintenance items, the "Service_ Exceeded by....." comes on each time you turn the ignition on. If you look it up in your maintenance book, it tells you that you can get rid of it, only temporarily until the next engine start, by using the reset button. When you read further, it tells you to take it to a MB or other service center to reset.
Here's the procedure from the WIS from my 211.026:
1. Switch on ignition. Use the scroll page to get to the temp,mph page.
2. Press the scroll forward and backward button( down arrow) repeatedly until the service date is displayed.( or if it says," Service exceeded.."
3. Keep the trip odometer reset button pressed for approx 5 seconds until the Service Menu appears in the display.
4. Using the + and - buttons, select Confirmation of Service
5. Press the system selection button ( lower of page buttons at 6 O'clock position) to confirm.
6. Press again to confirm.
7. Service Confirmed appears in Multifunction Display
8. Press the same button to get to the standard display
9. Turn ignition off. The next time you turn it on, the reminder should not appear.
Old Aug 14, 2008 | 12:31 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
SpeedPed, can you let us know if this works for you and I will ask admins to include it in DIY sticky.
Old Aug 14, 2008 | 12:58 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Buried within
Old Aug 14, 2008 | 01:18 PM
Thank you Lou.
I will give this a try and report back.
Bill E.
Old Aug 15, 2008 | 07:55 AM
E55_GT3wheels's Avatar
2010 E63, 2008 Range Rover Sport, 2010 GLK350
I had the oild changed only as the other items were basiclaly checks at the stealership. I reset the light myself and its pretty easy. I have a 2005 E55.
here is what i did:
-Key in ON position (one click after accessories but not all the way which starts the engine)
-from the temp display screen go up or down to get to the "service exceeded by..." or whatever message you have regarding service
-hold down the reset button for 5 seconds
-you get a screen with service options.
-go to the last option which is "service confirmation" and hit yes and then it says "service confirmed"
Thats basicaly it! took 5 minutes. No it says next service in 10K miles if I check and dont get the service exceeded light either.
Old Aug 15, 2008 | 07:57 AM
basically the same method stated above in more detail i guess.
one thing i noticed, if you hold down the reset button when it says service exceeded and it doesnt bring up the service menu, you are probably in Accessories key position or have the engine fully started. You need to be in the ON position which is inbetween the two.
cheers
Old Aug 15, 2008 | 11:50 AM
Sorry fellas, didn't work for me on my 2006.
I tried this in every key position, door open, door closed, pointed West, on a Friday while on my knees praying it would work. The AMG God's are not listening.
I'm just speculating here, but I have a feeling they changed the method for 2006 and it may not be possible to do this without some special tool?
Still hoping so any feedback is welcome.
Bill E.
Old Aug 15, 2008 | 11:52 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Did you click the link in post #5 above and read through it?
Old Aug 15, 2008 | 01:25 PM
That's exactly what I was trying to avoid and hoping there was another way like there is on most cars. Doesn't surprise me though. The dealers are making it harder and harder to get service anywhere but them.
Still think there's a way. Just haven't found it yet.
Old Jan 12, 2011 | 01:42 PM
tradin1's Avatar
e55 LET Parts/Tune & 02 clk 55
i have an 06 too and can not get this to work either! is there a trick for the later cars?
Old Jan 12, 2011 | 01:44 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Daum....three years.....bringing it back!
Old Jan 12, 2011 | 02:00 PM
KLR CLS's Avatar
CLS63 PP
Works fine for 06's. you are not doing it right...try again, slowly. There is a video on youtube somewhere too.
Old Jan 12, 2011 | 02:08 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
FSS Reset instruction
Speedpeddler,
Don't worry, I got your back. I just sent you a PM, I have the instruction in PDF version that your looking for. I've given these instructions to many other members in this forum as well as the AMG Private Lounge forum. Anybody else looking for this, just PM me with your email address.
Old Jan 12, 2011 | 02:22 PM
Yuille36's Avatar
Speedpeddler,
So have you received it yet?
Old Jan 12, 2011 | 04:36 PM
ShyGuy's Avatar
W211 E55
I'm able to reset the service reminder on my car but whenever i start the car it has a message saying "Main Inspection performed on time?" how do i clear this
Old Jan 12, 2011 | 11:52 PM
emoving's Avatar
Originally Posted by Yuille36
Speedpeddler,
Dude, read the thread, speedpeddler last posted in 2008!
Old Jan 13, 2011 | 02:06 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
here is what i did:
+1 I did the same thing and it worked no problems.
Old Jan 13, 2011 | 05:08 AM
Yuille36's Avatar
He PM me with his email, so that I could send him the PDF file. I was just checking, if he got it. But thank you for the observation, because I didn't realize it was that old.
Old Jan 13, 2011 | 08:24 AM
emoving's Avatar
He PM me with his email, so that I could send him the PDF file. I was just checking, if he got it. But thank you for the observation, because I didn;t realize it was that old.
I was thinking....hell, the guy might own a Ford Tarus by now!
Old Jan 13, 2011 | 08:26 AM
Yuille36's Avatar
man, that was funny. I'm still chuckling...
Old Jan 13, 2011 | 06:01 PM
archangel100's Avatar
E55 AMG, C32 AMG
If I remember right, I reseted it by going inside the dynamometer mode (pressing the reset button 3 times when in accessory mode and the SRS light is on). Scroll around there, and the reset option is present there too.
