Hand Built AMG.... by myself. A little OT.
Old Aug 17, 2008 | 05:28 PM
OLDSCHOOLRICE's Avatar
07' E350, 71' DATSUN 510
So I'm kinda proud of myself, and wanted to share a little. I figured that this would probably be most appreciated by this forum. Mods feel free to move if you so choose.
The actual build itself wasn't highly difficult but the circumstances surrounding the build weren't favorable. I recieved a pile of parts and a rolling chassis and was told to turn it into an S63.
Background- another technician found the engine leaking oil due to a porous block. AMG wanted the engine block, pistons, and rods only to be replaced. The parts were ordered after the engine was completely dissasembled. It took 5 months for all the parts to arrive (go figure), during which time the car was bought back and the technician, who originally diagnosed and took the engine apart, quit. After the last parts finally showed up (the main bearings) I was told to turn it into an S63.
The piles of parts that I started with, which have been moved back and forth over the last 5 months.
Old upper crankcase with rotating assembly still installed on the left. New upper and lower crankcase empty on the right.
New parts including gaskets, pistons, rods, bearings, etc...
Perfectly good upper crankcase after being stripped. What a shame.
Sorry for the lack of pictures in between, as my goal was to finish asap.
Will post pictures of me "breaking in" the new engine later!
Hope you enjoy.
Old Aug 17, 2008 | 05:35 PM
Max.H's Avatar
E55
I love it when a plan comes together.
Old Aug 17, 2008 | 05:39 PM
EUROTEK//AMG's Avatar
German
wow...a MB owner that actually works on his own car ?!?!?
....i kid....i kid....
Old Aug 17, 2008 | 05:43 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice job! I see you have one of those rare Starbucks tools.. Save at least 20% of the build time with that ..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 17, 2008 | 07:17 PM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Well done.
Congrats on a nice build.
Old Aug 17, 2008 | 08:03 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
YOU sir, are incredible.
WOW!!
How hard would you rate it compared to other engines you have assembled. My tech told me setting up timing a bee-otch. ;
Old Aug 17, 2008 | 08:41 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Looks like newschoolkraut to me. Well done!
W.I.S is fortunate.
W211 BEAST's Avatar
2006 E55 BEAST
VERY NICE!!!!!! I dont even know you and I'm proud of you. Lol.
Old Aug 17, 2008 | 09:09 PM
Thanks for all of the positive responses.
The starbucks tool was implemented by myself, surprisingly enough they don't list it in W.I.S. as a special tool.
As far as assembly diffuculty, it's a fairly easy engine to assemble as in nothing out of the ordinary. The hardest part was knowing what went where and in what order, because I didn't take it apart and this was my first time deep inside a 156 engine. Along with finding/ordering all of the bolts and tidbits that were misplaced during the 5 month wait. Timing was almost too easy as I went into the process expecting to have to do some thinking, but this was by far the easiest engine I have ever set cam timing on.
Old Aug 17, 2008 | 09:20 PM
DFW01E55's Avatar
'14 ML BT
You need a name plaque for the top of the engine!
Good work.
Old Aug 17, 2008 | 09:29 PM
Harsany's Avatar
2006 E55 Black on Black
wow
Old Aug 18, 2008 | 02:51 AM
gonzjed's Avatar
germans
nice job btw, what tech manual are you using?
Old Aug 18, 2008 | 03:00 AM
c32used's Avatar
LET C32 2002
Great job...now since you built it then maybe put on the factory AMG plaque your name.
Old Aug 18, 2008 | 09:37 AM
Scraz51's Avatar
2003 E240
Such an effort but so worth it. Good job.
Old Aug 18, 2008 | 09:44 AM
higginsbeach's Avatar
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Amazing man!!!!!!!!!!!
You should take that talent on the road!!!!!
Old Aug 18, 2008 | 10:56 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Where did you get the workshop information for a 63 engine? There is no way you can guess on the torque specifications and torqing sequences.
Old Aug 18, 2008 | 04:49 PM
Yeah, if I heard correctly, I can get a blank plaque and engrave my own name on it.
I'm a mercedes tech so I have W.I.S. (workshop information system) available at the touch of a button. It was really only needed for torque specs like you mentioned and telling me that cam timing was easier than I thought.
I fired it up today. Sounded good, just some valve train noise from some of the lifters not being filled up yet. I couldn't run it too long as I am waiting for the clips that connect the tranny cooler lines to the radiator.
"Break in" run tomorrow!
Old Aug 18, 2008 | 05:23 PM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Sorry if I missed something, what car will be receiving the engine?
Old Aug 18, 2008 | 08:25 PM
bartdude's Avatar
2006 E55 2003 ML55 2007 VW V10TDI
Nice JOB!
Old Aug 19, 2008 | 10:11 AM
andy_cyp's Avatar
Obsidian E55
S class
Old Aug 20, 2008 | 10:48 PM
I would say that the job turned out well.
Old Aug 20, 2008 | 11:27 PM
Max.H's Avatar
E55
Niiice!
