*** VRP's Ported S/C ***
This S/C will be reassembled and is being installed on one of our project cars for some testing.
Here are some sneak peeks at some of the areas that were improved.. There are some things I wont go into detail on because it is proprietary information.
We will be doing some thermal testing as well as power output testing. We will measure thermal loads at different points on the engine before and after so we can measure the level of efficiency increase. As well, a good old dyno pull before and after to see how many more ponies we can unleash on a Heads & Cams car..
Stay tuned!!!
If it is not to early to ask; How will this service be offered to the customer? Will we pull our SC off and send it in for porting? If so, Any estimates on turn around time? Any plans to have a larger VRP throttle body (90mm plus) to go with heads/cam and SC porting?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
