Airmatic problem with LM
Airmatic 'visit workshop' warning light on
Car is stuck in high position and wont go up or down
Compressor running non-stop when the car is running
So i've taken it back to the workshop and they look a little perplexed!
Any clues as to what the problem may be?I've done a search and still havn't found the answer.....
First question - did they install a version 1 or a version 2 ELM? Next question, does your car have three wire ride height sensors, or four wire ride height sensors?
Either way, it's obvious they screwed up the installation and need to go back and double check each and every single wire connection using the instructions for the type of sensors on your car.
Having personally installed one myself (see DIY sticky post), my best advice would be to have your installer print out the wiring schematics available at the RennTech website and then trace each connection and match it up to the correct pin number on the connector while confirming the wire color code.
I'm not 100% on the cut-off date for the 4 sensor install but I think it's either end of model year 04 or mid model year 05. Call RENNtech and give them your build date. That's what we did and they were able to tell us which install method to do.
Good luck.
P.S. - This was for a version 1 install.
Good luck.
Thx Benz-O-Rama for the info it's perfect timing as I'm having "Visit Workshop" as well. I can raise and lower the car just fine and it stays in the ride height I choose. Paid Euroelites for the RT ELM and install so I guess I will have to figure things out on my own.
I think you're gonna need to do the 4 sensor. It's very strange, I know...but it solved my problem and that advice came straight from RENNtech. I wish I could remember the cutoff date for those that need to do the 3 or 4 sensor install, but alas....too many drugs.
WAIT! I just re-read your post. You say that other than the "visit workshop" yours is working as intended?
If so, that's a different story. I currently have that. My ELM works exactly as it should and all airmatic functions work as expected. I had a tech diagnose my particular issue and it's my left front sensor is at zero voltage for one of the connections. The 4 sensor install actually has 2 leads going to each front sensor and one of them, the voltage is flatlined. I think I have a bad connection for that wire or the sensor is flaky.
