What Size of Tires???
Old Dec 2, 2008 | 10:21 AM
doppioexpresso's Avatar
BMW 335d
Hello... I am about to buy a 2005 E55-T.
So far I like 2 Wheels a lot:
1. The AMG Style IV in Grey (like Budharvolsten)
2:The original Wheels from the CLS55 (from Fiksen)
Do the original CLS55 & SL65 wheels have the right dimension & rimm offset for my E55 or do I have to order those wheels specially for my E55?
The CLS Style III wheels I found in the following dimension:
2x 8,5 J x 19 Offset 25
Original Part nr.: B66031230 / B66031209 / A2194011502
2x 9,5 J x 19 Offset 28
Original Part nr: B66031231 / B66031210 / A2194011602
What tiresize do I need to put on those wheels?
Thank you very much for your Help and best regards from Zürich, Switzerland...
Old Dec 2, 2008 | 10:27 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
On cls wheels you can go for 275/35 rear
245/40 front
I love how cls wheels look on the e class
Old Dec 2, 2008 | 10:40 AM
BMW 335d
245/40 front
So That means, I can just buy them from a CLS owner and put them on my E55? Yipppeeeeee
Yep, like them too. And I found a set of nice ones for less than $ 1'200.-...
Still can't decide if I like the SL65 wheels better, or If I should go for the CLS Wheels...
PS: Really like your "lieber Nürburgring als Ehering" ;-)... It's my second Home....
Old Dec 2, 2008 | 12:08 PM
shardul's Avatar
one day i would like to drive on the nordschleife circuit.
yes the rims will fit, but stock tire size of cls will be too big for e55 so will have to change the tires to the size i recommended. the cls rims will stick out 3mm more that the stock the e55 rims due to different offset
Old Dec 2, 2008 | 01:41 PM
BMW 335d
Nordschleife? All you need is a Flight to Germany... let me know when you are going... Will take you in my E55T (should have it by then...)
Old Dec 3, 2008 | 01:29 AM
BMW 335d
Can somebody please post some more pics of an E55 with cls Wheels? PLEASE!!!!!
Old Dec 3, 2008 | 09:55 AM
BMW 335d
245/40 front
And what about the SL65 Wheels? Please... Somebody Help
Old Dec 3, 2008 | 01:06 PM
komp55's Avatar
ML550
Actually, both the CLS five-spoke style wheels and the SL65 two-piece double spoke wheels are available with specific fitments for the W211 chassis, and both measure 8.5x19 front and 9.5x19 rear. The standard CLS wheel offsets (et25 and et28) will sit further outboard on an E. Not a huge issue, but not exactly what the factory has specified for the W211 chassis, either.
So long as you find either set of the above noted AMG wheels with a front offset of et30 and a rear offset of et31, and install 245/35/19 and 275/30/19 tires on them, you will know you have the fitment for the E55 that was the approved fitment specified by the TUV. The TUV approval letter to Mercedes is buried within the WIS if you'd like to confirm.
Old Dec 3, 2008 | 03:55 PM
BMW 335d
Thank you... Looks like I've just made a bargain... E55 T with only 36K, fresh Tires, and 2 Sets of Wheels, the SL65 ones (new Tires) and for the Winter 18' 5 spokes...
Old Nov 24, 2011 | 02:15 PM
paresh_gem's Avatar
E320 AMG W211
W211 E320 AMG 19 inch Tyre size HELP !!!!
Hi All, I'm new to this forum so excuse me if I'm going over old ground.
I have a W211 E320 AMG and am looking to replace the current 18" wheels to New 19" AMG Type 3, (CLS 5 spoke), 8.5j Front and 9.5j on rear.
Ideally I do not wish to lower the suspension and need advice on the best tyre profiles. Thinking of having 245 40 19's on the front and 255 35 19's on the rear.
PLEASE HELP - Any advice is appreciated, (pls attach pics if possible).
Old Nov 24, 2011 | 02:16 PM
paresh_gem's Avatar
E320 AMG W211
Old Nov 24, 2011 | 09:35 PM
dunwoodydtailr's Avatar
2006 e55, 2005 S55
A little off but I got 20x10 on the rear of my 55 with a 295-25-20 fits perfect :-)
Old Nov 25, 2011 | 12:44 AM
Nanky's Avatar
2007 E63, 2007 BMW 335i Coupe & 1991 Honda Accord
Pardon my ignorance but what does the "T" in E55-T stand for?
