Boost Measurement
2 questions regarding this.
1. If I tap a source after the IC before the TB, what boost levels should I be seeing on a stock 55? I know they are rated to run .8bar (11.5 psi), but what type of loss is seen in the intercooler?
2. If I wanted just a temporary source, is there any available temp sources? MAP, FPR, etc...that could be used for a single pull just to monitor the levels? Obviously, neither of those sources are good sources, but I hate having to tap into something permanently simply to monitor the boost for one pull basically. Same for why I would not install a gauge, I will simply tape this to the window, or drag a vacuum line into the cabin temporarily.
Thanks,
Scott
Thanks,
Scott
I agree with it being too long since we met, maybe we should try setting something up.
-m
Mercedes
Very funny. No, I don't have a boost gauge, it's so I can measure boost on the dyno. Have you seen how many times my before/after boost chart has been used on the forums lately? ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
-m
-m
Alexandarr,
I don't have a gauge in my car. We put it on for tuning/dyno purposes - so when I strap onto the dyno we have an easily accessible boost source. I could put a gauge on it but boost is fairly static with parasitic superchargers - it's not like a turbo car...
-m
-m
Mercedes
Alexandarr,
-m
-m
what would be nice is boost, oil pressure maybe oil temp and a\f ratio if you are tuning, tripple gauge in the center console like the w201 190e 16 2.3 16valve .
or a single digital gauge that reads all.. i think that would be best for the modern sophisticated e55 kompressor.
1 Post
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
right here works great.,, find a place where it will not interfear with TB or any thing then remove either side the manifold drill , tap it what i did was tighten the fitting into the maniflod ,,then count the thds inside sticking through,, remove the fitting, grind off those thds so i had a smooth surface inside, . good luck,, have fun . I made my own pillow pod,, found one that almost fit heated it with heat gun and remolded it to fit,. jim
![](http://i264.photobucket.com/albums/ii177/amx1397/boostgaugedrilledlocation001.jpg)
![](http://i264.photobucket.com/albums/ii177/amx1397/crossfireAFRgaugeandpillerpod004.jpg)
